Page 16 of 21 FirstFirst ... 6121314151617181920 ... LastLast
Results 226 to 240 of 307
Thread: Amiko HD 8260+
  1. #226
    RSP - TEAM konstantine's Avatar
    Post Thanks / Like
    Am pățit și eu aceeași chestie.S-a rezolvat cu un downgrade la versiunea sw. 2.3.51.Si cel mai important să respecți setarile din atașament.
    Citat din Ram Daas:“The quieter you become, the more you can hear.”
  2. #227
    21 Mar 2016
    Post Thanks / Like
    Multumesc.O sa ii fac un downgrade de software sa vad.Multumesc pentru reply.Programul ala are o limita de encodat?Ma refer ca dupa ce a ajuns la 100% a ajuns la 150% si dupa a scris -150% si a inceput sa scada.
    Sent from my LG-H815 using Tapatalk
  3. #228
    Post Thanks / Like
    Procentajul pt. progresia decriptarii , e eronat.Atunci cand se oprește singur , e gata procesul.
  4. #229
    21 Mar 2016
    Post Thanks / Like
    Salut.Am facut downgrade la 2.3.51.Cel mai mult merge decriptarea din video 23 de minute.Dupa care apar macroblocuri pana la final
    http://s.go.ro/hbxwbhkn
  5. #230
    Post Thanks / Like
    Problema e de la tine , insa nu-mi dau seama...La mine a mers fara probleme pe un film intreg peste durata medie.
    VideoID                          : 802 (0x322)
    Menu ID                     : 1 (0x1)
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format profile              : High@L4
    Format settings, CABAC      : Yes
    Format settings, ReFrames   : 4 frames
    Codec ID                    : 27
    Duration                    : 1h 58mn
    Bit rate                    : 5 193 Kbps
    Width                       : 1 920 pixels
    Height                      : 1 080 pixels
    Display aspect ratio        : 16:9
    Frame rate                  : 25.000 fps
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Interlaced
    Scan type, store method     : Separated fields
    Scan order                  : Top Field First
    Bits/(Pixel*Frame)          : 0.100
    Stream size                 : 4.28 GiB (93%)
    Color range                 : Limited
    Color primaries             : BT.709
    Transfer characteristics    : BT.709
    Matrix coefficients         : BT.709
  6. #231
    21 Mar 2016
    Post Thanks / Like
    Cu ProTV si altele nu am probleme.Problema e mea doar strict la Nagra/Irdeto.Asta e.Posibil sa nu mearga HBO decriptat intotalitate.
  7. #232
    Post Thanks / Like
    In cazul ăsta , cred c-ar trebui să pui prio(amiko are un fisier asemanator prio.Se numește smapdata)Dă-i un search pe forum.Am mai scris despre asta.
  8. #233
    Post Thanks / Like
    Daca n-a avut bunul simt sa "citeze sursa" , a mai si modificat fisierul read.me.
    Un "exemplu" de creativitate !
  9. #234
    21 Mar 2016
    Post Thanks / Like
    Salut konstantine.Sper ca nu te deranjez dar nu am gasit fisierul ala prio (smapdata).Daca ma poti indruma unde l-as putea gasii ar fii perfect.
  10. #235
    Post Thanks / Like
    #    hsdata.cfg#    need copy this file to C: of ur usb stick. then put receiver to read
    #    cmd ->   cfg~lock~hide~pass
    #    sample   cfg~1~1~00110022     means , u will lock the server info menu. also hide the server info.  the password to watch is 00110022
    #    cmd ->   protocol~host~port~user~pass~des
    #    sample   newcamd~192.168.2.3~10000~dummy~dummy~0102030405060708091011121314
    #    sample   homecamd~192.168.2.3~10000
    #    sample   homecamd2~192.168.2.3~10000
    #    sample   cccamd~192.168.2.3~10000~dummy~dummy
    #    sample   nasscamd~192.168.2.3~10000
    #    sample   deltacamd~192.168.2.3~10000~dummy~dummy~0102030405060708091011121314
    #    cmd->note~detial
    #    sample   note~service map 1.0  , 2011.12.27
    #    cmd->smap~degree~tp~service_id~caid~ecmpid~chid~commit
    #    sample   smap~130~11420~567~500~789~00~abc tv
    #    for smap cmd.  degree, tp should be decimal ,  service id, caid, ecmpid, chid should be hex. max support 256 service map
    #    degree, tp, service_id. make sure which channel u want map.
    #    caid, ecmpid, chid.  make sure only this ecm is used for this service.  all other ecm will be ignored.
    #    sat degree.   if east . like hotbird 13 east degree. will be 13*10 = 130.  for west.  like nilesat 7 west degree , will be (360-7)*10 = 3530
    #    ################################## be care .  the max file size is 15k ####################################################3
    #cfg~0~0~00000000
    #cccamd~abcdef.ath.cx~10000~arbname~asbpass~0102030405060708091011121314
    note~test version
    smap~130~11420~5679~0500~7890~00~abc tv
    in hsdata.cfg se pune fiecare sectiune in parte(UTF-8)
  11. #236
    Post Thanks / Like
    ALI3516_14000A00_galaxy_combo_220_ps_starlight_1CA_1CI_2.4.12
    Test version.(Il am pe receptor si pana in momentul de fata, se comporta ok)
    Dupa update durata de bootare e mai lunga. Fiti rabdatori !
    new bootlogo
    21.01.2017Test firmware ver.2.4.12
    This version of the test will continue to fix, but you can use it.
    Work YouTube, Adult (3 strawberries applications: YouPorn, Tube 8 and Empflix), Lite IPTV, KINO-LIVE and 3ko on the keys are updated directly from the Internet.
    To view the "Adult" application should be:
    - In the "parental control" to enable the position of "Adult",
    - In the "application" in the first column of characters go below the 3rd icon and "the Adult" application will appear.
    Finished testing and running: Plug-Import E2 database.
    Added: Disable the wireless connection, remove the access point (forget)
    Added: Application WEB Server to download the channel playlist in .m3u (at this point in the test)
    Posted: WEB Server application the ability to download LITE IPTV servers (currently in test)
    Posted: Appendix Stalker IPTV (at this point in the test)
    Posted: WEB TV application, sleep timer and change the display format.
    Posted: WEB TV application support ts-proxy playlists from Torrent TV
    Added: Added support for video in media player with a resolution of 1920x800
    Updated: write timer, change the duration to the end of time
    Updated: Function default start channel to OFF.
    Updated: Search TV after the search becomes the last channel in the list.
    Updated: Appendix Kino-live greater stability
    Updated: Appendix RSS, added news feed Sat24
    Updated: BISS List keys on the basic positions
    Fixed: WEB TV application, eliminated hangs when using USB
  12. #237
    Member Beginner nexactor52's Avatar
    02 Feb 2016
    Down on Earth
    Post Thanks / Like
    Am observat la toate versiunile cu web server că durata de bootare este mai mare dacă serverul este setat pe pornit.
    L.E. Pare să se fi rezolvat la versiunea asta. Pornește la fel de repede și cu web-serverul pornit.
  13. #238
    21 Mar 2016
    Post Thanks / Like
    Salut.Am si eu o intrebare.Am vorbit cu cineva care are un Amiko A3 Combi si mi-a spus ca el poate inregistra programele criptate fara a mai face vreo setare.Exista vreun ecas sau vreun emu modificat pentru Amiko 8260+ sa fie posibil acest lucru?Multumesc si scuze daca intrebariile mele au fost uneori cam "tampite".
  14. #239
    Post Thanks / Like
    8260 inregistreaza in clar doar de pe programele necriptate.In rest, e nevoie de utilitarul pe care l-am postat cateva posturi in urma pt. decriptarea inregistrarilor.
  15. #240
    Post Thanks / Like
    Sw. "nou" SAB Titan III adaptat pt. amiko 8250/60/70 RSP_MOD_SAB_ALI3516_14000A00_locus01_mcas_starlight_1CA_1CI_2.3.64
    Versiune MCAS.Daca faceti actualizarea "peste" un sw cu emu , va merge exact ca inainte cu mici exceptii.
    Youtube ok , autoconnect wi-fi ok , afiseaza doar primul rand al subtitrarii in mediaplayer.Fara "adult" in aplicatii.
    Branduit RSP si new bootlogo amiko.
