Thanks Thanks:  34
Likes Likes:  16
Results 16 to 30 of 59
Thread: Caut colaboratori la RSP E2: Alien1, Alien2 si Kathy
    RSP - TEAM
    03 May 2007
    Pot testa imagini pentru Alien 2 si Kathrein UFS910 (14W), desi e foarte posibil ca sa fie nevoie sa incep prin a-mi aduce aminte si a "dezgropa" uneltele si programele cu care o faceam acum mai bine de 2 ani.
    Am avut o zi mai lunga la munca .
    Sper sa am azi timp sa definitivez generatorul la A1.
    Astept un voluntar pentru teste preliminare la imaginea de Alien 1.
    Ar fi bine sa aiba cablu serial sa facem debug !
    08 Apr 2013
    any chance for a test image for the alien2
    thanks Paul
    02 Apr 2007
    Weissenburg
    Pentru consistenta rezultatelor si eficienta actiunii - n-ar fi bun un protocol pe care sa-l urmeze toti testerii si in baza caruia sa se raporteze bugurile descoperite ?
    Cred ca asa s-ar reduce incidenta erorilor intimplatoare si ar creste entuziasmul celor ce vor sa contribuie ...
    Parerea mea.
    160 pounds of star dust
    Exista o sectiune privata a forumului dedicata dezvoltarii.
    S-au imputinat din pacate entuziastii !
    Daca sunt voluntari scriu aici si apoi luam decizii !
    Nu sare nimeni cu A1 sa faca teste preliminare. Mai intarziem !
    24 Apr 2013
    I'm ready.The weekend is here.
    08 Apr 2013
    ok first thanks for the image
    but can we put in a ipk manager, the only way i can install plugins that are ipk is using dreamexplorer
    i also see a list for opkg but see its not implemented yet on the plugin downloads
    but cable for uk is working great and the epg for it ,also softcam working fast but did have problems recording one channel then watching the other i had a blank screen,but that was the same as the last image untill a fix was implamented
    installed autobouquets and crossepg both working fine
    ---------- Post added at 09:04 ---------- Previous post was at 08:17 ----------
    another problem cant get the swap to activate or i dont think i have looked in system options and set to 128 but nothing,and sometimes it bluescreens
    i cant find swap file anywhere on hard drive but find a reference to touch and thats a 0 byte file
    but its still looking good and fast ,thats the main thing
    Firstly thank you for your input.
    Regarding swap, if create a folder named SWAP on the USB stick, swap should be enabled automatically. There's another option creating a SWAP partition (SWAP labeled) on the stick.
    In this beta version many of the RSP Menu option are doubled in System option menu (click, swap, etc).
    They'll be moved into the dedicated "System option" menu with the next version of the beta.
    ---------- Post added at 12:54 ---------- Previous post was at 12:01 ----------
    Make a SWAP directory on stick and after reboot:
    DuckBox_RSP:~# free
                 total         used         free       shared      buffers
    Mem:        116652       114968         1684            0          156
    -/+ buffers:             114812         1840
    Swap:        65528            0        65528
    DuckBox_RSP:~#
    26 Dec 2011
    Agen
    Al meu A1 conectat la retea prin adaptor Wifi, si cu LNB unicable; GM triplex conectat cu un tuner S la unicable, celalalt la LNB normal, tunerul C/T2 inca nefolosit (peste 2 luni ma mut si voi avea doua unicable pentru 2 sateliti diferiti si antena terestra). Pot testa in configurarile de mai sus, la care voi adauga si un switch Diseqc pe A1 intre LNB-ul unicable si cel clasic (am ars déjà unul, trebuie sa fac o separare galvanica mai intai); nu cred ca mai are cineva complicatenia asta
    Evident esti deosebit ! Vei primi link de imagine beta pentru Alien 2.
    Cumpar Alien 1 cu 200 RON doar pt a ajuta comunitatea (aparat de teste).
    Aparatul merita mai mult !
    Vanzatorii doritori ma cauta in PM.
    19 Oct 2014
    Astept si eu sa colaboram si sa testez imaginile noi de la rsp.
    Generez acum imagine Gstreamer Mplayer pt A2.
    Primiti lynk in PM.
    Cumpar Alien 1 cu 200 RON doar pt a ajuta comunitatea (aparat de teste). Sunt in Bucuresti !
    19 Oct 2014
    Astept pm.
