Thanks Thanks:  30
Likes Likes:  1
Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 31 to 45 of 149
Thread: Images Vu+ Zero
    Thumbs up OpenATV 5.1 Vu+ Zero Image
    OpenATV 4.2 Vu+ Zero Image----------GST 0.10 Images
    http://images.mynonpublic.com/openat...hp?open=vuzero
    OpenATV 5.1 Vu+ Zero Image----------GST 1.5.1 Images
    Thumbs up Black Hole updates
    Black Hole updates
    There is a new online update available to update to 3.0.1.E
    This is available as an online update from 3.0.1
    There will be a full flash update available soon
    Changes since 3.0.1.D:
    16/12/15
    Merge git://code.vuplus.com/git/openvuplus_3.0 into vuplus-3.0-current​
    15/12/15
    transtreamproxy updated.​
    14/12/15
    [gstreamer1.0-plugin-dvbmediasink] apply patch files.
    - audiosink_mpeg4_aac_header.patch, thanks to mx3L <mx3ldev@gmail.com>
    - videosink_ffmpeg_mpeg4_nofourcc.patch, thanks to christophecvr <stefansat@telenet.be>​
    13/12/15
    [opera-hbbtv] update hbbtv​
    e2 bump subversion​
    11/12/15
    skin_users_vusolo4 little fix​
    09/12/15
    update en language​
    08/12/15
    new skin_user_vusolo4k by Ev0
    e2 bump​
    Thumbs up Vu+ Eurosat 2.0 Vu+ Zero Image
    OpenLD VU+ Zero-----OpenLD 2.5
    http://www.odisealinux.com/Firmwares/VuPlus/
    SatDreamGr 4.0 Vu+ Zero Image
    http://sgcpm.com/satdreamgr-images/vu/vuzero/
    http://sgcpm.com/satdreamgr-images-e...tal/vu/vuzero/
    Thumbs up Open Source VU+ Zero Image 3.0 Update 23/12/2015
    http://code.vuplus.com/download/boxi...?v=30&m=vuzero
    VU+ Zero HDMU Image
    http://www.hdmedia-universe.com/boar...d=1&box=vuzero
    Thumbs up VU+ Zero HDMU Image
    Thumbs up Powerboard-Image 5.1 Vu+ Zero Image
    Neues Powerboard-Image 5.1 fur die VU+
    Diesmal mochten wir euch sehr fruh mit unseren neuen Werken bekannt machen. Soll heissen, das aktuelle hier vorgestellte 5.1er Image ist ein Beta-Werk mit vielen Verbesserungen, aber eben halt ohne ausgiebigen Test.
    Wir mochten euch das jedoch nicht vorenthalten, also viel Spass damit.
    WICHTIG - neues Passwort: powerboard
    URGENT - new pasword: powerboard
    Wir haben das Image zwar umgebaut, aber an den bekannten Funktionalitäten nichts geändert.
    - neues Enigma2 mit wesentlich mehr Funktionen
    - aktueller Kernel und Treiberstand
    - GStreamer 1.6.0
    - Expert-Installer
    - Auto-Systemupdate
    - script-Starter
    - Piconpfadanpassung
    - logfile-viewer & remove (logs unter /home/root)
    - Autorestarter fur Anwendungen
    - LCD-skin-Selektor
    -neuer oscam Standard-Pfad
    uvm.
    We havn`t completly rebuild the Image, but didn´t changed anything in the familiar functions.
    - a brandnew Enigma2 with a bunch of more functions
    - actuell Kernel and Driversrelease
    - GStreamer 1.6.0
    - Expert-Installer
    - Auto-Systemupdate
    - script-Starter
    - adjustable Piconpath
    - logfile-viewer & remove (logs under /home/root)
    - Autorestarter
    - LCD-skin-selektor
    -new default path for oscam
    http://anonym.to/?http://www.pb-down...151008_usb.zip
    VU+OpenDroid 5.2 --------Vu+ Zero Image
    http://images.opendroid.org/5.2/VU+/vuzero/
    VU+rudream-5-------VU+ Zero Image-----09.01.2016
    http://www.speedyshare.com/TdcXG/zero.rar
    http://www.mediafire.com/download/00...e-X3.0_CAM.zip
    Thumbs up OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-01-05
    Please reflash your receiver since a software update will most likely fail.
    Especially on spark/spark7162.
    Changes since previous release:
    - Gstreamer snapshot updated to 1.7.1:
    * The mp4 issue when playing from remote locations has been fixed upstream, so I've dropped the revert.
    * Libsoup has been updated so I've dropped the revert for the old libsoup as well.
    - DM800Se V2 and DM500HD V2 kernel config has been cleaned and more in sync with PLi's config for the other Dreambox models.
    - More free space by adding a task before do_package_write_ipk which will upx compress some binaries.
    * This should give us a few more MBs to work with (Dreambox *cough*).
    - Major rework of the meta-fulan BSP for spark thanks to Tapaat for helping me out.
    * Now using Tapaat's drivers which fixes the frambuffer (and 22khz?) issue.
    * Enable of the zram module.
    * Shipping his wifi drivers.
    * VFD time is now synced every 5 minutes using a cron job.
    * Software update and plugin-installation has been fixed.
    * Using Tapaat's lirc config for spark and spark7162.
    - The usual batch of dvbmediasink fixes by Christophecvr and mx3L:
    * A brand new divx/xvid bitstream unpacker by mx3L should fix playback of avi files with wrong fourcc.
    - Libsoup has been updated to 2.52 (from master-next).
    - Refactor wifi drivers a bit on Linux 2.6.18, not auto-loading the mt7600 anymore, the correct driver should hopefully be loaded when you plugin your wifi stick.
    Changes compared to openpli-oe-core gst-1:
    - Ships with gstreamer upstream master git:
    Using the same patches as openpli-oe-core gst-1 with only these changes:
    Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
    because this patch was already checked in upstream.
    - Every receiver uses christophecvr's multibox dvbmediasink.
    - Using libtrmp and rtmpdump from oe-alliance.
    - Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
    These are only applied for Dreambox receivers.
    - AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
    - IPTV Player from samsamsam included (thx to Athoik for the recipe).
    - Large list of public IPTV streams included thanks to the Japhar Team.
    - Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
    - DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
    added si2166b blindscan support.
    - Using aio-grab source from oe-alliance which includes fixes for spark receivers.
    Known issues:
    - DM800 first boot will take a while, please be patient. The next boot will be faster.
    - On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
    Please use 'duckbox' instead.
    - On Zgemma Star you cannot use full HD skins.
    This is a hardware/driver limitation.
    Please don't try it, it will crash enigma2.
    - Some Dreambox remotes may behave very sensitive.
    This causes button presses to register multiple times instead of just once.
    As a workaround you can adjust the key interval:
    Go to: Menu - System - Input devices - dreambox remote control (native).
    Set "Change repeat and delay settings" to yes
    Set "Interval between keys when repeating:" to 200ms or 300ms.
    Press green button (OK)
    Now set the same delay for: "dreambox advanced remote control (native)" as well.
    TODO:
    - Linux 2.6.18: Create a plugin / ppanel to select which Realtek/Ralink driver to load on startup (eg. rt3070, rt55xx, mt7600), since they cannot be loaded at the same time.
    - Linux 2.6.18: Look into the v4l usb drivers.
    - Add Spark specific plugins by gorski.
    - Add meta-ini from OE-Alliance and shape it up for openpli-oe-core.
    Link:
    https://mega.nz/#F!z08HlZyA!Upawo32I...e-soQ!y0tFyK5R
    OpenPLi-4.0-beta Vu+ Zero Image
    http://openpli.org/download/vuplus/vuzero/
    Thumbs up VU+OpenHDF-5.3 Vu+ Zero Image
    http://v53.hdfreaks.cc/vuzero/
    ---------- Post added at 10:51 ---------- Previous post was at 09:57 ----------
    Thumbs up VU+rudream-5-------VU+ Zero Image-----17.01.2016
    Thumbs up Open Source VU+ Zero Image 3.0 Update 20/01/2016
    http://code.vuplus.com/download/boxi...164444_usb.zip
    VU+VTi 9.0.2 Vu+ Zero Image
    19.01.2016 - Urgent Information
    Please check tuner configuration when tuners are in loop through mode.
    It is not allowed to loop through a tuner multiple times
    19.01.2016 - Software Update VTi 9.0.2
    - increase image version: VTi 9.0.2
    - update drivers (2016-01-19) (solo4k)
    support Chromium OS
    fix DiSEqC problem
    improve power consumption
    fix misc.
    - add Chromium OS to image (including YouTube TV) (solo4k)
    - update dvbapp2 (2016-01-17)
    keep compatibility for extra headers in stream urls
    MovieList: improve handling when leaving movie
    MovieList: add option to hide entries
    when start dir is set to all or new movies
    Timeshift: add separate menu: Menu>VTi>Setup - Timeshift
    Timeshift: map button STOP to live TV (timeshift recording is still in progress)
    Timeshift: map button STOP LONG to stop timeshift
    Timeshift: add function to transform timeshift to regular recording (Please note: short outage in TS file at transforming timestamp)
    Common: add global option for dvbapp2 debug output
    Menu>VTi>Setup - System
    Common: support EPG and picons for 4097 services (e.g IP>TV)
    Common: support recording of 4097 services (e.g IP>TV) -> THX @betacentauri
    Common: fix handling of http timeout at streams
    Common: fix button EXIT when infobar animation is enabled
    EPG: add option to blacklist services for DVB EPG (EIT) updates
    EPG: support for adding extra data to EPG events
    - add plugin epgshare THX @einfall (ver. 0.01 20160117)
    - add plugin tinyfoscamviewer (ver. 1.0)
    - readd plugin mediatombplugin (ver. 1.0-r5)
    - update plugin autoframerate
    fix switching to 24p mode
    - update plugin camofs (ver. 10.01)
    - update plugin devicemanager2 (ver. 1.7)
    fix partitioning for some devices
    - update plugin graphicalmultiepg
    support button mappings
    support custom picon folder
    - update plugin infobartunerstate (ver. 3.0.1 20160108)
    - update plugin lcd4linux (ver. 4.7.-r2)
    - update plugin multiquickbutton (ver. 2.7.14-r6)
    - update plugin openwebif
    switch to standby when transcoding starts (solo4k)
    - update plugin picturecenterfs (ver. 7.03)
    - update plugin seriesplugin (ver. 4.5.0 20151221)
    - update plugin webradiofs (ver. 13.57)
    - update skin atile (ver. 4.2-r0)
    - update skin mutespectator (ver. 2.8)
    - update skin stylefhd (ver. 2016-01-11)
    - update opera hbbtv (2015-12-22) (ultimo,uno,duo,solo,zero,duo2,solo2,solose)
    - update transtreamproxy</itemtext>
    support infobartunerstate plugin
    - update vtipanel (ver. 3.36)</itemtext>
    add favourites list loader (see forum for howto)
    Menu>Setup>Service Searching
    - add package jpegtran-cffi
    - remove xbmc from image (solo4k,duo2,solo2,solose)
    Quote:
    http://www.megafileupload.com/ejeM/v..._9-0-2_usb.zip
