Thanks Thanks:  30
Likes Likes:  1
Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 76 to 90 of 149
Thread: Images Vu+ Zero
  1. #76
    OpenVIX 4 1 001 Release Image for Vu+ Zero
    http://www.openvix.co.uk/index.php/d...mages/vu-zero/
  2. #77
    VU+OpenLD 2.8 VU+ Zero Images
    http://www.odisealinux.com/VuPlus.html
  3. #78
    Thumbs up Satdreamgr-4.0-gst1 Vu+ Zero Image
    http://sgcpm.com/satdreamgr-images-e...415.ziphttp://
  4. #79
    OpenPli 4.0 Beta VU+ Zero Image
    http://downloads.pli-images.org/buil...160419_usb.zip
    OpenHDF- 5.4 VU+ Zero Image
    http://v54.hdfreaks.cc/
    Open Source 3.0 VU+ Zero Image
    http://code.vuplus.com/download/boxi...?v=30&m=vuzero
  5. #80
    Thumbs up [BKP] Black Hole 3.0.2C Vu+Zero by Robijay [Flash]
    Backup date 20/04/2016
    Kernel 3.13.5
    Avermedia A867 Driver OK
    Splash Screen Black Hole by robijay
    Bootlogo by robijay
    Setting Vhannibal Quadri Feed 13+19,2+23,5+28,2
    Language: ENGLISH
    Password FTP and Telnet: robijay
    Whats Included ?
    Black Hole 3.0.2C
    Panel
    LINUXSAT SUPPORT PANEL HD 1.2
    SATVENUS PANEL HD 4.1
    Plugins
    MEDIAPLAYER2
    SUBSUPPORT
    YOUTUBE TV
    FREE IPTV BY PANDASAT (UPDATE 20/04/2016)
    AUTOBOUQUETS 28,2 (FOR UK USER NEW VERSION)
    COOLTV GUIDE 7.3.0
    KODI DIRECT 3.0 (ALL FIX UPDATE)
    TECTIME TV
    TSMEDIA 11.1
    IPTV PLAYER 121.00.03.00 (LATEST)
    LIVE FOOTBALL 6.0
    CROSSEPG (RYTEC UPDATE)
    GLASS SYSTEM UTILITY 6.55
    OPENMULTIBOOT
    WEBRADIOFS 14.42 (NEW)
    MEDIA INFO 3.0 (NEW VERSION)
    VHANNIBAL NGSETTING 1.4 (NEW)
    AND MORE..........
    Emu
    OSCAM 11230 (LATEST)
    DOSCAM 0.25
    MGCAMD 1.38D
    CCCAM INFO
    OSCAM STATUS VIEW
    Skin
    ORIGINAL
    DOWNLOAD:https://mega.nz/#!coUUVKKS!m8GASevf3...ndLMYw9De7TaG0
  6. #81
    Thumbs up OpenPLi 4.0 IPTV by MastaG with GStreamer 1.9.0.1 VU+ Zero Image
    15/ 04/2016
    Changes:
    - New gstreamer 1.9.0.1 recipes based on christophecvr's github (small changes for PLi4)
    - Upgrade glib2.0 and some other components like gobject-introspection to satisfy the new gstreamer recipes
    - gstreamer1.0-libav is built using it's minimal libav with only support for wma (thank you chris)
    It's pre-installed on all receivers except for the ones with only 64MB of flash (dm800/800se/500hd)
    - Full ffmpeg 3.0.1 package is in the feeds for use with IPTV Player's exteplayer3 (thx to Taapat for the original bbappend)
    Login with telnet and issue: opkg update && opkg install ffmpeg
    - Latest openpli-oe-core changes
    - Latest enigma2 changes
    - spark: libeplayer3 is pre-installed now (also in the feeds) for movie players with support for this library
    Note: servicemp3 still uses gstreamer
    - spark: some OpenPLi enigma2 backports (since Taapat doesn't maintain his enigma2 branch anymore)
    The servicemp3 memleak patch has been applied with some other patches/commits I found useful
    - spark: don't force async mode on the dvbaudiosink anymore, it's now the same as all other receivers again
    - Fixed e-star dm800 image now using correct drivers and working great
    - Add Vu+ Solo 2 Lonrisun V4 (v1 and v2) images + feed
    https://mega.nz/#!nIhljYBL!mto2_g-X0...rAwykzGLBwOJxU
    http://downloads.pli-images.org/buil...160420_usb.zip
  7. #82
    Thumbs up Satdreamgr-4.0-gst1 VU+ Zero Image
    http://sgcpm.com/satdreamgr-images-e...o-20160423.zip
  8. #83
    Thumbs up Black Hole 3.0.2.C Vu+ Zero Image
    Black Hole 3.0.2.C​
    What is new ?​
    -Support customized subtitles.
    - font color, size, opacity, edge style,
    - background color, opacity,
    - subtitle position, align, etc.
    - add quick menu for subtitle​
    -Add OpenMultiboot to Solo4K​
    This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Community members can then download it from our servers.
    This feature provides other benefits such as:
    Increase download speed of EPG
    Download EPG from any channel
    Schedule the download of EPG decoder even during standby
    Users can customize the providers using Add / Remove function
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UPnP Server Mediatomb
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to Pedro_Newbie for Backup script
    DISCLAIMER
    LICENSE (TERM OF USE)
    This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
    Download
    https://mega.nz/#%21sVZ1XQ6D%21vnAGE...hVA-d2ibWpQCBY
  9. #84
    Thumbs up OpenDroid 5.5 VU+ Zero Image
    http://images.opendroid.org/5.5/VU+/...160424_usb.zip
  10. #85
    Thumbs up Open Source 3.0 VU+ Zero Image
  11. #86
    Thumbs up VU+HDMU VU+ Zero Image
  12. #87
    Thumbs up SatDreamGR 4.0-gst1 VU+ Zero Image
    http://sgcpm.com/satdreamgr-images-e...o-20160430.zip
  13. #88
    Thumbs up OpenSPA 6.0 VU+ Zero Image
    User : root
    Pass : openspa
    Quote:
    What is new :
    - New OE-Alliance 3.4
    - Changes in EPG download, now is Movistar+ instead of D+
    - Fix weather info
    - Improvements at confluence 1080. Added new screens and plugins.
    - Improvements at spaqbutton (Remap keys) to add more remote buttons (fav, portal, etc)
    - Kodi 16.1 (Wetekplay/VuDuo2/VuSolo2/VuSoloSE/VuSolo4k)
    - GStreamer 1.8.1 Stable
    - VuDuo2/VuSolo2/VuSoloSE/VuSolo4k/VuZero/GigaBlue support iptables
    - Fixed error in DeviceManager when initialize device in ext3/ext4
    https://openspa.webhop.info/#Descarg...uplus%2Fvuzero
  14. #89
    Thumbs up PKT SVN-3400 HYPERION v5.3.1 VU+ Zero Image
    Quote:
    - [MIPS] new gstreamer 1.9.0
    - [HC] new gstreamer 1.8.0
    - new packages
    - a lot of fixes and updates
    - [sh4] & [HC] new second infobar XL mode
    FTP login: root
    passwd: pkteam
    http://e2.pkteam.pl/index.php?dir=IM...ERION%205.3.1/
  15. #90
    http://downloads.pli-images.org/buil...o-20160504_usb
    http://sgcpm.com/satdreamgr-images-e...o-20160505.zip
