Results 1 to 15 of 16
Thread: Recomandare Router in reteaua RDS
    11 Oct 2009
    Rosiori
    Lightbulb Recomandare Router in reteaua RDS
    Recomandati-mi un router wireless ptr configuratia PC si Dreambox care sa nu se restarteze de n-ori pe zi. Voi ce router-e folositi??
    Momentan am un belkin care mi-a mancat zilele, am mai avut si un edimax si el face la fel. Buget de maxim 400 lei
    23 Apr 2007
    P3X-888
    Am D-Link DIR-615 ... practic nu stiu ca am router , tine download de 10 MB/s pe cablu iar stabilitatea este excelenta .
    Moderator sorin8m's Avatar
    22 Apr 2007
    Eu am cisco, sunt mai scumpe dar foarte bune (sunt brand).
    25 Jul 2007
    Netherland
    D-link 825 ( 5 x porturi gigabit )
    Firmware: DD-WRT v24-sp2 (12/20/11) std
    Time: 23:00:07 up 38 days, 23:00, load average: 0.00, 0.00, 0.0
    20 Feb 2009
    Dlink 655 Extreme N Gigabit. Rupe. N-ai dureri de cap cu autentificarea PPPoE la RDS, e stabil, are porturi giga pe LAN, wireless 802.11n draft.
    Nu cred ca e singurul performant, p-asta l-am testat, mi se pare ok si ca pret.
    There are only 10 types of people in the world: those who understand binary and those who don't.
    TP-Link 1043ND cu porturi gigabite , wifi n si usb , consider ca are un raport pret/performanta foarte bun ( firmware stock )
    Golden Member mar1us's Avatar
    08 May 2009
    dublin
    Quote Originally Posted by sorin8m View Post
    Si eu am avut un Cisco modem-ruter all in one de la UPC irl si am renunțat la el ...
    11 Oct 2009
    Rosiori
    Eu ma cam orientasem spre Linksys E2500 sau NetGear WNDR 3700-100PES (care are si gigabit). TP-Link 1043ND are un prieten si este oarecum multumit de el.
    16 Oct 2008
    Linksys cu linux.
    Am aschimbat firmware si cu Tomato pot sa ii fac destule, ii maresc si puterea wireless...
    01 Feb 2008
    asus rt-n16 cu dd-wrt.
    Specificații
    Porturi LAN WAN x 1, LAN x 4 RJ-45 for 10/100/1000 Base T
    Support Ethernet and 802.3 with max. bit rate 10/100/1000 Mbps and auto cross-over function(MDI-X)
    Antenă 3 x external antenna
    USB port USB2.0 x 2
    Power AC input: 100V ~ 240V(50~60HZ)
    DC output: 12V with max. 1.25A current
    Size 216 x 161.9 x 40.5 mm
    Weight 470g
    Frecvenţă operare 2.4GHz ~ 2.5GHz
    Rată transfer 802.11n Draft: up to 300Mbps ;
    802.11g: 6, 9, 12, 18, 24, 36, 48, 54Mbps;
    802.11b: 1, 2, 5.5, 11Mbps
    Output Power n mode: 15.8~19.5dBm
    g mode: 15.5~16.5dBm
    b mode: 15.8~19.5dBm
    Sensitivity at 54Mbps data rate
    ANT0 -75dBm
    ANT1 -75dBm
    Encryption Supports 64/128-bit WEP
    WPA-PSK, WPA2-PSK
    WPA-Enterprise, WPA2-Enterprise
    Radius with 802.1x
    Management
    • EZQoS (Easy Quality of Service): Allow multiple network activities (FTP, Game, P2P) to work smoothly at the asame time.
    • DHCP Server: Supports up to 253 IP addresses; Changeable DHCP lease time, IP pool, domain name; Static mapped IP
    • Web-based administration: Support IE 5.5 or later, Firefox 2.0.0.1 or later; Managed from LAN and Internet; Password Setting
    • System Event Log
    • Firmware Upgrade: Web Interface, Bootloader
    • Save/Restore Configuration File
    Network Protocol Automatic IP ,Static IP, PPPoE(MPPE supported), PPTP, L2TP
    Security Firewall: NAT and SPI (Stateful Packet Inspection), intrusion detection including logging
    Logging: Dropped packet, security event, Syslog
    Filtering: Port, IP packet, URL keyword, MAC address
    succesuri!
    22 Apr 2007
    Quote Originally Posted by mar1us View Post
    Dane o explicatie de ce ai renuntat la el?
    Standard RSP member klausz's Avatar
    10 May 2007
    Salut,
    Am cumparat de cateva zile un router Tp-Link WDR3600 si sunt foarte dezamagit. Se deconecteaza intr-una de la ISP. Credeti ca daca pun DD-WRT s-ar rezolva problema?
    Desi fac virtual server nu face forward la port etc..
    O sa incerc cu firmware linux si daca nici asa nu functioneaza il duc inapoi.
    Emme Esse 115cm, h-h Stab 120,Vu+ Solo​2, Samsung UE40ES6710, tevii s660 dvb-s2
    10 May 2007
    Am bagat DD-WRT si degeaba. Tot se deconecteaza. Am modem Huawei in casa din care pleaca si telefon si cablu si internet. Sunt sanse ca la el sa fie problema?
    10 May 2007
    Am rezolvat problema. Am luat un Asus RT-AC66U si cu DD-WRT sfaraie.
    09 Aug 2010
    Default router
    Eu folosesc un D-link Dir-300 cu dd-wrt pus pe el. de 2 ani de zile nu i-am dat restart sau reboot. merge super bine . pretul e de 100 ron in magazine.
    Chiar il recomand .
    Se poate folosi si Dir 600 cu acelasi dd-wrt , pretul la fel 100 ron
