Thanks Thanks:  22
Likes Likes:  30
Page 1 of 13 1234511 ... LastLast
Results 1 to 15 of 187
Thread: Discutii si ajutor ALi HD & SD
    叛徒 kosar's Avatar
    25 Feb 2013
    覆盆子灌木
    Default Discutii si ajutor ALi HD & SD
    Bun venit noului receptor din familia Amiko !
    The brand new Amiko MicroHD has arrived! Our latest compact size Satellite Receiver & Media Player with Over The Top content.
    Imagini cu receptorul:
    Urmarind imaginiile chiar pare un microreceptor.
    Specificatii tehnice:
    System Resources
    Main Processor: 400MHz based CPU
    Flash Memory: 64MBits
    DDR RAM: 1024Mbits
    MPEG TS A/V Decoding
    Transport Stream: MPEG-2, MPEG-4 (H.264)
    Input Rate: Max.120Mbit/s
    Aspect Radio: 4:3, 16:9, Letter Box
    Video Decoding: MPEG-2, MP@ML, MPEG-4 part 10/H264
    Video Resolution: 720*480p/i, 720*576p/i, 1280*720p, 1920*1080p/i
    Audio Decoding: MPEG-1 layer I/II, MPEG-2 layer II, Dolby Digital
    Audio Mode: Left / Right / Stereo/ Mono
    Sampling Rate: 32, 44.1 and 48KHz
    A/V & Data Input/Output
    AV OUT: Video CVBS output, Audio L/R output (Jack Type)
    LAN: RJ-45 Ethernet Connection
    RS-232C: Transfer rate 115.2Kbps, (Jack Type)
    IR IN: External IR Connection (Jack Type)
    USB: One USB 2.0 slot Compatible
    HDMI: VER1.3, Type A, Dolby Digital Bit-Stream Output
    Tuner & Demodulation
    Tuner Type: DVB-S2
    Input Connector: F-type, Connector, Female
    Signal Level: -65 to -25 dBm
    LNB Power: Vertical: +13V/+14V,
    Horizontal: +18V/+19V
    Current: Max. 350mA
    Overload Protection
    22K Tone Frequency: 22±1KHz
    DiSEqC Control: Version 1.0, 1.1, 1.2, USALS
    Demodulation: QPSK, 8PSK
    Input Symbol Rate: 2-45 Mbps,
    FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
    Physical Specifications
    Size[W*H*D]: 75 mm * 115 mm * 22 mm
    Net Weight: 0.25 Kg
    Operation Temperature: 0°C~+45°C
    Storage Temperature: -10°C~+70°C
    Storage Humidity: 5%~95% RH (Non-Condensing)
    sau aici: http://www.amikostb.com/?q=product&id=203
    Software-ul oficial se poate descarca de aici.
    11 Apr 2008
    Fost mebru
    In specificaţii nu apare ce-i mai important ... producătorul procesorului
    叛徒 kosar's Avatar
    25 Feb 2013
    覆盆子灌木
    Dupa specificatiile tehnice seamna izbitor de mult cu Alma s2200, pana si extensia software-ului, pana si descrierea, pana si lungimea fisierului cu firmware-ul.
    Intr-o zi cu putin mai mult timp liber, am sa incerc sa incarc software-ul pe Alma, cine stie ce hibrizi o sa rezulte
    Standard RSP member vic5's Avatar
    26 Dec 2011
    Agen
    O caramida, dar mai mica...
    GM Spark Triplex, Amiko Alien 8900, DM 500s, Echosmart HD 7109 LAN; HH Strong.
    17 Nov 2008
    ALBA
    Pai modelul asta de receiver a aparut de muuuult de la golden media.
    Se gaseste la peruvision.
    CARACTERISTICI PRINCIPALE:
    • Cititor de cartela Conax incorporat;
    • Full HD;
    • Suport WiFi;
    • Acces direct YouTube si YouPron;
    • Redare video extinsa (Divx,Xvid,MKV,WMV,AVI etc.);
    • 1 x USB pentru inregistrare PVR, redare muzica (MP3), poze (JPEG) sau actualizare software;
    • Iesiri HDMI 1.3;
    • Port Ethernet RJ45;
    • Interfata RS232 pentru actualizare software si lista de canale;
    • Cautare automata a canalelor;
    • Functie de marire (Zoom);
    • Rezolutii video 1080p,1080i, 720p, 576p, 480p, 576i, 480i;
    • Consum de putere in mod Standby sub 0,5W;
    • Functia Blind-Scan;
    System standard: Fully MPEGII/DVB Compliant
    Input Frequency: 950~2150Mhz
    RF Input level: -65~-25dBm
    LNB Control: DiSEqC1.0/1.2
    LNB Power:13V/18V (Max, 400mA)
    LNB tone switch: 22KHZ
    Waveform: 8PSK / QPSK (SCPC, MCPC capable)
    Symbol rate: 2~90Msps
    A/V Mode
    Video format: MPEG-II Main prole/Main level
    Audio format: MPEG-II layer I&II
    Aspect Ratio: 16:9, 4:3
    Audio sampling rate: 32,44.1, 48kHz
    Audio Type: Left / Right / Stereo / Mono
    Graphic display: 1920×1080, 1280×720, 720x480
    Microprocessor & Memories
    RAM: 128Mb DDR
    FLASH: 8 Mb
    Power & Environment Condition
    Supply Voltage: DC 12V
    Supply Power: Max. 20W
    Operating temp: 0°C~40°C
    Dimensions: 108(W) x 70(D) x 18(H)mm
    Net. weight: 0.12Kg
    Connectors
    Satellite IF input: F-type (Digital)
    USB: High Speed USB2.0
    Ethernet: RJ45
    RS232: 3.5mm Jack Type
    IR: 3.5mm Jack Type
    HDMI
    USB
    DC IN: 12V
    Standard RSP member ASiX88796's Avatar
    20 Feb 2013
    LQFP 128
    Post
    Quote Originally Posted by delta2k2 View Post
    Cu alt firmware şi alt ambalaj se vinde şi ca Openbox M3. Chinezii scriu in specificaţii că are procesor ALi3601 / Sunplus 1510.
    叛徒 kosar's Avatar
    25 Feb 2013
    覆盆子灌木
    Alma s2250 HD, acelasi hardware, carcasa diferita !
    Toata lumea fabrica acelasi receiver doar cu denumirea si carcase diferite ??
    Schema cablului serial pentru aceste modele, ca nu au avut loc in carcasa sa introduca o mufa rs232 normala.
    叛徒 kosar's Avatar
    25 Feb 2013
    覆盆子灌木
    Deja a si aparut in magazinele online !
    23 Jun 2008
    Poate are un firmware mai destept decat Alma 2250
    08 Mar 2007
    Arad
    stie client de share ?
    26 Dec 2011
    Agen
    Daca ar exista déjà vreun soft alternativ cum are GMWizard class, da.
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    Tot ce trebuie pentru amiko gasiti aici:http://sat-support.tv/?a=downloads&dir=2
    Standard RSP member Cena133's Avatar
    26 Dec 2007
    Default Amiko HD 8360
    Buna seara , as dori sa stiu daca acest receptor ar merge macar ca si client in reteaua de sharing (cccam)?
    Va multumesc anticipat.
    16 Feb 2009
    merge perfect
    26 Dec 2007
    Default 13025
    Am incercat prin DCC sa intru , dar din pacate nu pot intra deloc pe el , cu totul ca are iesire pe net , am incercat cu DHCP activat sa intru dar tot nu vrea si cu DHCP dezactivat la fel nu vrea , eroarea pe care o am este , ce as mai putea sa fac ca sa reusesc ?
    Va multumesc anticipat,
