Thanks Thanks:  5
Likes Likes:  5
Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 31 to 45 of 130
Thread: Images Vu+ Solo 4K
    Thumbs up Open Source Image 3.0 ----------------Update 29/01/2016
    http://code.vuplus.com/download/boxi...=30&m=vusolo4k
    Thumbs up OpenNFR 5.1 VU+ Solo 4K Image
    openNFR Update Februar 2016
    Neuigkeiten / Änderungen
    add Gst 1.7.1
    add multiboot for vu+ solo 4k
    Treiber Stand 31.01.2016
    Treiberupdate VuPlus 4K (inkl. chromiumOS & youtubeTV)
    Fix
    Fix LCD-Display
    Fix Skin
    Fix Übersetzungen
    Fix diverse kleinere Fehler
    http://dev.nachtfalke.biz/nfr/feeds/...160129_usb.zip
    Thumbs up openATV 5.1 VU+Solo4k Image
    Thumbs up VTi "Vu+ Team Image Solo 4K" - V 9.0.2
    25.01.2016 - Software Update
    - update dvbapp2 (2016-01-25)
    Timeshift: map function transform timeshift to REC button
    Timeshift: remove duplicate menu entries
    REC button: add transform timeshift to configuration choices
    - update vtipanel (ver. 3.37)
    fix image restore/flash tools
    03.02.2016 - Software Update
    - update dvbapp2 (2016-02-03)
    Timers: fix repeating timers
    Timeshift: enhance naming scheme for timeshift files
    Timeshift: do not switch to live TV after event change
    Timeshift: add option to to use < and > buttons for switching timeshift events
    Timeshift: change default configuration for behaviour at event change
    - update hbbtv (ver. 20151228) (solo4k)
    - update skin mutespectator (ver. 2.9)
    see TimeShift screen for new source TimeShiftService
    05.02.2016 - Software Update
    - update plugin camofs (ver. 11.0)
    - update plugin fritzcall (2016-02-05)
    - update plugin permanenttimeshift (2016-02-05)
    keep compatibility to new dvbapp2 functions
    - update plugin picturecenterfs (ver. 7.22)
    06.02.2016 - Software Update
    - update dvbapp2 (2016-02-06)
    Common: fix releasing memory at loading epg data
    - update plugin camofs (ver. 11.01)
    07.02.2016 - Software Update
    - update dvbapp2 (2016-02-07)
    Timeshift: fix naming scheme of ts files
    Timeshift: try to set correct file name for saved event
    Timeshift: do not stop timeshift when channel selection will be closed without service change
    - update gstreamer-plugin-dvbmediasink
    fix sound dropouts at some media files
    08.02.2016 - Software Update
    miscellaneous bug fixes
    fix AC3/DTS playback when PCM tracks are present
    09.02.2016 - Software Update
    - update dvbapp2 (2016-02-09)
    [Timer] add option to avoid simultaneous timer starts
    [Timeshift] add function to transform old timeshift events
    [Timeshift] use begin time of event for ts file name
    [Timeshift] add option to hide timeshift files in movie list
    http://speedy.sh/gh7XV/vti-image-vus...-9-0-2-usb.zip
    http://images3.mynonpublic.com/opena...160212_usb.zip
    http://dev.nachtfalke.biz/nfr/feeds/...160210_usb.zip
    OpenPLi-4.0-beta-VU+ Solo 4K Image
    http://openpli.org/download/vuplus/vusolo4k/
    Thumbs up OpenSPA 5.0.005 for VU+ Solo 4K NEW UPDATE 2016-02-16
    Changelog:
    - WeTek Play :
    Kernel 3.10.93 and Drivers 2016-01-29
    Improvements and fixes Enigma2
    New plugin Selection Remote Contorl with support in the Wizard
    - Gigablue:
    Kernel 4.0.1
    New drivers
    GStreamer 1.7.1
    - Zgemma:
    New drivers 2016-01-21
    - Kodi 15.2 for Vuplus Solo2, Solo SE, Duo2 and Solo 4K (thanks mx3l)
    - New OpenSPA updates wizard (Allows install new firmware keeping settings and data)
    - New skin Confluence 1080: based in Confluence_openspa
    - Updated skin OpenSPA_JRLG1080 (more screens included)
    - Updated plugin openSPA_JR (added new infobars, channel selection and chance to choose dark or light style)
    - Updated GStreamer 1.6.x to 1.7.1
    - Fixed issue with ecm line in infobars, because it was always shown in some skins.
    - Translate improvements.
    - Other minor fixes.
    Password FTP/Telnet : openspa
    To report bugs :http://openspa.info/forums/reportes-...n-openspa.265/
    http://openspa.info/resources/opensp...d?version=1766
    Thumbs up openATV 5.2 VU+Solo4k Image
    Thumbs up VU+rudream-5-------Vu+Solo4K-----22.02.2016
    SatDreamGr v4.0 ------------VU+ Solo 4K
    http://sgcpm.com/satdreamgr-images-e...l/vu/vusolo4k/
    Backup Vu+ Solo4K Satdreamgr v4.0 by Prekon:
    I put emulators Oskam-1.120, Wicardd-1.19
    https://yadi.sk/d/rR4TV8oEpwzA9
    update new
    Thumbs up OpenSPA 5.0.006 for VU+ Solo 4K NEW UPDATE 2016-03-18
    What is new?
    - Kodi 16 "Jarvis" for Vuplus Solo2, Duo2, Solo SE and Solo 4K
    - Fixes in EPG plugin to assign what screen you want to EPG button.
    - Added new wget to improve safety.
    - Fixes in OpenSPA updates wizard.
    - Fixes in spaqbutton (remap keys).
    - Added new renderer for better XPicons performance.
    https://openspa.webhop.info/#Descarg...genes%2FVuplus
    openATV 5.3 VU+Solo4k Image
    http://images.mynonpublic.com/openat...?open=vusolo4k
    VU+rudream-5-------Vu+Solo4K-------24.03.2016
    https://yadi.sk/d/I4i6yYG4mKfWF
    Thumbs up OpenDroid Image V.5.4 Image VU+Solo4k
    New Release Opendroid V.5.4
    The openDroid image Today is a brand new structure, Thank you all for the New Test !!!
    New: OpenDroid 5.4
    **developers Image openDroid**
    gimsy,formianodicastellone
    A special thanks to all the beta testers
    Skinner:
    Mmark
    Porting e Mod Skin oDreamy:
    Formianodicastellone,Satinfo
    BootLogo and splash:
    robijay
    Picon default:
    robijay
    Beta Tester Spark:
    juvent,
    Very Thanks juvent!!!
    New:New!! OE-Core 3.3
    New:Bitbake: 1.27.1 to 1.29.0
    New:Compiler: GCC 4.9.2 on GCC 5.3.0
    New:Busybox: 1.23.2 to 1.24.1
    New:Python: 2.7.9 to 2.7.11
    Newhttp://www.satdreamgr.com/forum/imag...es/redface.pngpenssl: 1.0.2d on 1.0.2f
    Newhttp://www.satdreamgr.com/forum/imag...es/redface.pngpenssh 6.8p1 server on 7.1.p2
    Newhttp://www.satdreamgr.com/forum/imag...es/redface.pngpkg 1.0.2.4 to 1.0.3.1
    New:Libcom 1.42.9 to 1.42.99
    New:mtd util 1.5.1 to 1.5.2
    New:libssl 1.0.2d on 1.0.2f
    New:libcdio12 0.82 to 0.93
    New:liborg 0.4.23 to 0.4.24
    Newhttp://www.satdreamgr.com/forum/imag...ies/tongue.pngam-plugin-group 1.1.6 to 1.2.1
    New:bluz5 5:32 to 5:37
    Enigma2: (New:structur 2016-03-26)
    Enigma2: Fixed and Update many file!!!
    Remove: CrossEPG download it from feed
    GStreamer: 1.7.1
    Fixed: Mkv file
    Fixed: MiniTV
    Improved graphics!
    New: bootlogo!
    New: splash
    New: Picon default
    New: Translate ITA
    New: Translate DE
    New: Translate EN
    New: Translate UK
    Local Feed Opendroid
    We thank the developers of the Opendroid image, Oe-Alliance and all betatesters for reports !.
    Special thanks goes to Mmark for Skins, Satinfo and formianodicastellone for porting and **** the skin oDreamy, robijay and gimsy for several graphic parts including Bootlogo and Splash, Vhannibal for AUTOSETTinG plugin, and all their coder
    NB: Not all third-party plug-ins have been tested and are guaranteed to be compatible
    NOTE: Because there is not any kind of official support for these Opendroid-team receivers will deploy custom images using only our addons server that mirrors the standard server Opendroid and that will allow for online updates when available.
    OpenDroid-Team-Not recommended to make On-Line software update !!!
    possibly use the image on flash
    http://images.opendroid.org/5.4/VU+/...p?dir=vusolo4k
    Thumbs up OpenNFR 5.2 VU+ Solo 4K Image
    Thumbs up openBH 0.4 Image VU+Solo4k
    Whats New:
    Completely new image
    Based on OE-A core
    Solo4K supported
    Updated to Gstreamer 1.7.1
    Updated to Python 2.7.9
    Main Features:
    MX HQ9W Full Hd skin (1920x1080)
    Kodi 15.2 (Solo4K, Duo2, Solo2, SoloSE)
    OpenMultiBoot (Solo4K supported)
    OE-A Plugins
    Black Hole:
    Blue panel
    Green Panel
    Extra Settings
    Addons panel
    Compatible with OE-A and PLi plugins and Skins
    What is openBH ?It is an exciting project from the same team that produce the Black Hole images.
    This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
    This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support, OpenGLes Animations and we have included Kodi 15.2.
    As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
    Do I have to upgrade to this new openBH image ?
    No you don't have to upgrade to the new openBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
    What about the Black Hole and Black Hole Prism Images ?
    For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new openBH image is an additional project and we are fully committed to all images.
    Where can I find the openBH git ?
    The openBH git is located here: https://github.com/BlackHole
    http://speedy.sh/M7wy9/openbh-0.4-vu...se-00abe27.zip
    DISCLAIMER
    THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
    THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
