Thanks Thanks:  5
Likes Likes:  5
Results 121 to 130 of 130
Thread: Images Vu+ Solo 4K
  1. #121
    nu ai inteles......rup de fura....ma refer la imaginile mama...care sant closed sources si fura coduri si rezolvari de la open sources...
  2. #122
    29 Sep 2017
    Bucharest
    The latest Black Hole image is 3.0.5.L Quad PiP
    What is new ?
    branding-compat fix patch
    [libvupl] add missing model
    Remove IMAGE_FSTYPES ext4 from 4k models.
    [directfb] fix segmentation fault on exit
    [RemoteControlCode] fix default type
    *** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM BH 3.0.5.I, 3.0.5.J or 3.0.5.K ***
  3. #123
    Thumbs up SatDreamGR 6.0 Vu+ Solo 4K Image
    http://sgcpm.com/satdreamgr-images-6/vu/
  4. #124
    29 Sep 2017
    Bucharest
    Black Hole 3.0.6
    What is new ?
    • Completely re-written the BH EPG system.
    • Added EPGImport support
    • Added FreeSat, Netmed, ViaSat and Virgin EPG
    • Updated Sky EPG
    • Added options to Load-Save-Delete epg.dat
    • Updated CrossEPG
    • Fixed DVB Subtitles issue on some channels
    • Swapped Buttons around in BH panels to match layout of other images
    • Various Skin updates from MX10
    http://www.vuplus-community.net/boar...34e-zip.39757/
  5. #125
    29 Sep 2017
    Bucharest
    OpenPLi 7.0 » Pre-release test images
    https://openpli.org/download/vuplus/Solo+4K
  6. #126
    29 Sep 2017
    Bucharest
    Black Hole 3.0.7
    What is new ?
    • Many bug fixes
    • Added new feature to let you know when an online update is avaliable
    • Changed default Skin to MX Black Sea
    • New Bootlogo
    • New defualt Spinner
    • Improved Wi-Fi setup
    • Added Duo4K support
    • Reintroduced Support for Solo, Duo, Uno, Ultimo and Zero
    This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
    - Integrated OpenEpg
    - CrossEPG supported
    - EPG Import supported
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to Pedro_Newbie for Backup script.
    DISCLAIMER
    LICENSE (TERM OF USE)
    This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
    https://www.vuplus-community.net/boa...459-zip.40753/
  7. #127
    29 Sep 2017
    Bucharest
    29 Sep 2017
    Bucharest
    The latest Black Hole image is 3.0.9.G Multistream
    • Add Support for spinner to be skin dependant
    *** THIS IS ONLY AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A / 3.0.9.B / 3.0.9.C / 3.0.9.D / 3.0.9.E / 3.0.9.F ***
    ***** IT IS RECOMMENDED TO ONLY USE BH 3.0.9.x IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
  9. #129
    29 Sep 2017
    Bucharest
    O noua versiune venita acum 309 O
  10. #130
    29 Sep 2017
    Bucharest
    *** THIS IS ONLY AS AVAILABLE AS A FULL FLASH UPDATE ***
    ***** I REPEAT THERE IS NO ONLINE UPDATE FROM ANY PREVIOUS BH VERSION TO 3.1.0 Multistream *****
    ***** IT IS RECOMMENDED TO ONLY USE BH 3.1.0 IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *****
