Thanks Thanks:  3
Results 1 to 15 of 18
Thread: Plugins Vu+ Solo 4K
    konstantine's Avatar
    Default Plugins Vu+ Solo 4K
    Plugins pentru Vu+ Solo 4k
    Latest Version of OScam arm Vu+ Solo4K
    The Solo4K uses an ARM CPU and not MIPS so for now the only working emu is Oscam.
    This file has been configured with both internal readers working for UK Freesat card and Tivusat Card.
    Thanks Dumnonia
    enigma2-plugin-cams-oscam_11077_all.rar---------------https://www.sendspace.com/file/0kxbuv
    Here is OScam 11086 with emu and @Informed keys, the only config files are oscam.conf and oscam.usr
    Thanks Informed® and Dumnonia
    enigma2-plugin-cams-solo4k-oscam-emu_11086_all.rar--------------------https://www.sendspace.com/file/3f5j2j
    OScam for VU+ Solo 4K
    BlackHole
    enigma2-plugin-cams-oscam-svn11086-solo4k_blackhole_all.ipk
    https://www.sendspace.com/file/eemwye
    openATV
    enigma2-plugin-cams-oscam-svn11086-solo4k_openatv_all.ipk
    https://www.sendspace.com/file/b4pffh
    openVIX
    enigma2-plugin-cams-oscam-svn11086-solo4k_openvix_all.ipk
    OScamEmu 11105 for VU+ Solo 4K
    BlackHole
    Solo4kOscam11105EmuBlackhole.rar
    https://www.sendspace.com/file/9hkj01
    15 Sep 2007
    cine ma ajuta si pe mine sa instalez oscam-ul?
    am imag vti
    dau si 2-3-4 beri
    15 Sep 2007
    cred ca e mai complicat,am impresia ca trebuie completate oscam.conf,server, etc.
    daca ai timp si poti sa ma ajuti,cu teamviewer,cumva sa o scot si eu la capat.
    mersi
    Thumbs up Vu + Solo 4k E-Panel 5.7-r10
    E-Panel for the image based on OpenPli / OA (system panel)
    ipk enigma2-plugin-extensions-epanel-5.7-r10.ipk
    http://speedy.sh/sHS6R/enigma2-plugi...el-5.7-r10.rar
    Thumbs up Vu + Solo 4k openATV Softcam Feed
    Update 12/07/2016
    Quote:
    solo 4k/ultimo 4k/uno 4k, mutant hd51/52, AX 51/52, Xtrend ET11000/120000, Spycat 4K, Edision 4k, Octagon 4k usw
    softcam-feed-arm-ahf_1.1_armv7ahf-vfp-neon.ipk.zip
    http://speedy.sh/WtRJt/SoftCam.zip
    MGCamd 1.35a for Openpli (Solo 4k)
    MGCamd 1.35a for Openatv (Solo 4k)
    http://speedy.sh/trjnr/enigma2-plugi...f-vfp-neon.ipk
    http://speedy.sh/6DGkD/enigma2-plugi...f-vfp-neon.ipk
    25 Oct 2007
    Chisinau
    Am Openpli 5, oscam nu e la panel aşa că am căutat pe net şi l-am pus manual şi l-am pornit tot manual. Am doua probleme: 1. După restart reciver nu porneşte oscam automat, trebuie mereu să-l pornesc manual. 2. Nu deschide din softcam.key nici Biss, nici altele, doar din linii. E vreo setare specială pentru aşa ceva? ...
    31 May 2009
    LCD4Linux ipk all : http://www.megafileupload.com/89uq/e...4.6_r4_all.rar
    testat pe BH 3.0.2H , plugin-ul de la serverul de download oficial nu functioneaza .
    Standard RSP member klausz's Avatar
    10 May 2007
    Salut,
    Are cineva cunostinta de un link, sau de un nume de ipk, ceva, ce mi-ar permite sa instalez key si sa functioneze pe cablu? Thx! Momentan folosesc un cam, dar vreau sa eliberez slotul.
    Emme Esse 115cm, h-h Stab 120,Vu+ Solo​2, Samsung UE40ES6710, tevii s660 dvb-s2
    31 May 2009
    oscam emu , cu soft.cam.key ai incercat ?
    oscam: /usr/bin
    oscam config files: /etc/tuxbox/config/oscam
    softcam: /usr/keys
    detalii mai gasesti aici : http://www.sat-universe.com/showthread.php?t=293482
