Results 1 to 13 of 13
Thread: OpenPLi-4.0-beta Vu+ Duo/ Duo2
    Thumbs up OpenPLi-4.0-beta Vu+ Duo/ Duo2
    Thumbs up OpenPLi 4.0 Japhar Vu+Duo/ Duo2 Image
    with IPTV and GStreamer 1.6.2 released
    - Gstreamer (v1.6.2) has been updated to master git which carries many fixes.
    - No more internet connection required during bootup.
    - Feeds online for online update of image and future updates/fixes if necessary.
    - IPTV List and Jam Panel are now pre-shipped.
    - Japhar Addon Manager 5.2 included.
    - IPTV List built-in with 750+ IPTV FREE Channels.
    - Many dvbmediasink fixes.
    - Many stuff I forgot
    https://mega.nz/#!Io4jHBzS!bdkQlhyZO...P17Vm7huMtQru4
    https://mega.nz/#!E0ZwlLgD!TiJzLnpnA...n12yFtJy0nbnAw
    Thumbs up OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-01-05
    Please reflash your receiver since a software update will most likely fail.
    Especially on spark/spark7162.
    Changes since previous release:
    - Gstreamer snapshot updated to 1.7.1:
    * The mp4 issue when playing from remote locations has been fixed upstream, so I've dropped the revert.
    * Libsoup has been updated so I've dropped the revert for the old libsoup as well.
    - DM800Se V2 and DM500HD V2 kernel config has been cleaned and more in sync with PLi's config for the other Dreambox models.
    - More free space by adding a task before do_package_write_ipk which will upx compress some binaries.
    * This should give us a few more MBs to work with (Dreambox *cough*).
    - Major rework of the meta-fulan BSP for spark thanks to Tapaat for helping me out.
    * Now using Tapaat's drivers which fixes the frambuffer (and 22khz?) issue.
    * Enable of the zram module.
    * Shipping his wifi drivers.
    * VFD time is now synced every 5 minutes using a cron job.
    * Software update and plugin-installation has been fixed.
    * Using Tapaat's lirc config for spark and spark7162.
    - The usual batch of dvbmediasink fixes by Christophecvr and mx3L:
    * A brand new divx/xvid bitstream unpacker by mx3L should fix playback of avi files with wrong fourcc.
    - Libsoup has been updated to 2.52 (from master-next).
    - Refactor wifi drivers a bit on Linux 2.6.18, not auto-loading the mt7600 anymore, the correct driver should hopefully be loaded when you plugin your wifi stick.
    Changes compared to openpli-oe-core gst-1:
    - Ships with gstreamer upstream master git:
    Using the same patches as openpli-oe-core gst-1 with only these changes:
    Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
    because this patch was already checked in upstream.
    - Every receiver uses christophecvr's multibox dvbmediasink.
    - Using libtrmp and rtmpdump from oe-alliance.
    - Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
    These are only applied for Dreambox receivers.
    - AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
    - IPTV Player from samsamsam included (thx to Athoik for the recipe).
    - Large list of public IPTV streams included thanks to the Japhar Team.
    - Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
    - DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
    added si2166b blindscan support.
    - Using aio-grab source from oe-alliance which includes fixes for spark receivers.
    Known issues:
    - DM800 first boot will take a while, please be patient. The next boot will be faster.
    - On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
    Please use 'duckbox' instead.
    - On Zgemma Star you cannot use full HD skins.
    This is a hardware/driver limitation.
    Please don't try it, it will crash enigma2.
    - Some Dreambox remotes may behave very sensitive.
    This causes button presses to register multiple times instead of just once.
    As a workaround you can adjust the key interval:
    Go to: Menu - System - Input devices - dreambox remote control (native).
    Set "Change repeat and delay settings" to yes
    Set "Interval between keys when repeating:" to 200ms or 300ms.
    Press green button (OK)
    Now set the same delay for: "dreambox advanced remote control (native)" as well.
    TODO:
    - Linux 2.6.18: Create a plugin / ppanel to select which Realtek/Ralink driver to load on startup (eg. rt3070, rt55xx, mt7600), since they cannot be loaded at the same time.
    - Linux 2.6.18: Look into the v4l usb drivers.
    - Add Spark specific plugins by gorski.
    - Add meta-ini from OE-Alliance and shape it up for openpli-oe-core.
    Link:
    https://mega.nz/#F!z08HlZyA!Upawo32I...e-soQ!y0tFyK5R
    Thumbs up OpenPLi-4.0-beta Vu+Duo/ Duo2 Image
    Thumbs up OpenPLi 5.0 (next-master preview) Vu+Duo2 Image
    http://epg.giclub.tv/spark2combo/ope...2_kodi_usb.zip
    Thumbs up [BKP]Unofficial OpenPLI Vu+Duo2 Kodi 15.2
    Backup date 31/01/2016
    Kernel 3.13.5
    Last Update 09/10/2016
    Splash Screen PLI by robijay
    Bootlogo by robijay
    Spinner from arctic skin
    Setting Whannibal Quadrifeed 13,0+19,2+23,5+28,2+DTT Italy
    Language: English
    Password FTP and Telnet: linuxsat
    Whats Included ?
    PLI Unofficial Image with KODI Isengard 15.2
    Panel
    LINUXSAT SUPPORT PANEL 1.2 FULL HD
    Plugin Bouquets
    AUTOBOUQUETS FOR 28,2 (NEW VERSION)
    VHANNIBAL NGSETTING 1.3(NEW)
    Addons
    XBMC LAUNCHER
    Repositories & Addons For XBMC Launcher Can Be Downloaded From LINUXSAT SUPPORT Addons
    EPG IMPORT RYTEC
    2BOOM'S M3U/XML BOUQUETS CONVERTER
    COOL TV GUIDE 7.3.0
    IPTV PLAYER 98.04.00.01
    LIVE FOOTBALL 6.0
    GLASS SISTEM UTILITY 6.5.0
    LCD4LINUX
    IPTV WORLD PLUGIN 2.0
    MEDIAPLAYER2
    SUBSSUPPORT PLUGIN
    PICON MANAGER 2.2 (MOD)
    WEBRADIOFS
    ALTADEFINIZIONE 1.1.7 PLUGIN (SOON ON MEDIASTREAM 7.0)
    CASACINEMA PLUGIN 1.0.0 (SOON ON MEDIASTREAM 7.0)
    DARKSTREAM PLUGIN 1.0.0(SOON ON MEDIATREAM 7.0)
    FILMXTUTTI PLUGIN 1.1.0 (SOON ON MEDIASTREAM 7.0)
    GUARDARESERIE PLUGIN 1.1.4 (SOON ON MEDIASTREAM 7.0)
    ITASTREAMING PLUGIN 1.0.0 (SOON ON MEDIASTREAM 7.0)
    FOURTUBE XXX PLUGIN 1.0.2 (SOON ON MEDIASTREAM 7.0)
    FULL FLASH BACKUP ON USBB/HDD
    FULL FLASH BACKUP TO USB
    MEDIAINFO 2.8 (NEW)
    XBMC WEATHER
    AND MORE..........
    Emu
    OSCAM 11209 (LATEST RELEASE)
    DOSCAM 0.25
    CCCAM 2.30
    OSCAM STATUS VIEW
    CCCAM INFO
    Skin
    ORIGINAL
    MTERIXHD-MOD (DEFAULT)
    Picons
    13,0+19,2+DTT ITALY (INCLUDED THX TO NEO_3)
    23,5+28,2 (INCLUDED OKTUS)
    DOWNLOAD:https://mega.nz/#!0hNyzJSK!QLnC2nuaO...UxKXCIdMyXpcZQ
    Thumbs up OpenPLi 5.0 test 3.02.2016 Vu+Duo/ Duo2 Image
    https://dl.dropboxusercontent.com/u/...kodiv2_usb.zip
    Thumbs up OpenPLi-4 / Gstreamer 1.7.1 (master git) images 2016-02-17
    Hi folks,
    It took me a while to build these because there were lots of small bugs and user requests.
    I did my best to answer them all.
    But due to my limited time I couldn't fulfill all of them, so my apologies if I didn't respond to a PM or forum-post.
    So anyways.. there are lots of changes compared to my last images.
    Too much for me to remember, so I guess:
    - Added new receivers: Zgemma H5 and LC, Vu+ Solo 4K, XpeedC (whatever that is) and Atemio Nemesis (user-request, not tested at all so beware).
    There are no Wetek builds and I ain't gonna build them, so don't ask.
    - I've fixed the feed for mips32el-nf receivers (et4x00, hd1100, hd500c and xp1000).
    - Oscam bumped to rev. 11211 with Joeuser's patch (yes I know you guys were waiting for this one).
    - Lots of fixes for spark and spark7162 with the help of my great friend Taapat, they should be of equal quality as other PLi 4 images now.
    The libeplayer versions are in the "eplayer" directory, everything else is gstreamer.
    - No more patches to enigma2's servicemp3.cpp (except the one for aac transcoding), so it should reflect the current state now.
    - Latest gstreamer 1.7.1 master head as of today.
    - Many backports from master-next and Taapat.
    - Lot's of small things I forgot.
    Note:
    - If you get corrupted jpeg images on spark/spark7162 the hardware decoder is not working for you, simply login using telnet and type:
    rm -f /usr/lib/libmme_host.so
    Then restart enigma2 and they should display fine
    - Zram is now disabled by default on spark/spark7162, if would like to use it anyways, simply login using telnet and type:
    touch /etc/gimme-zram
    Then reboot your receiver.
    If I didn't mess up badly this time, this will be my last round of public images.
    I don't think there's any benefit for releasing gstreamer master head images anymore, since the next stable gstreamer release will hit master-next and oe-alliance anyways.
    And most work went into supporting non-PLi-supported receivers which takes lots and lots of time.
    Thank you all for the great feedback !
    You're the best!
    https://mega.nz/#F!mk8jBRLQ!4_3w31ZR...n_gfA!vwkgGCpa
    Thumbs up OpenPLi-4.0-beta Vu+ Duo2 Image
    OpenPLi-4.0-beta-vuduo2-20160419_usb.zip
    http://downloads.pli-images.org/buil...160419_usb.zip
    20-04-2016
    OpenPLi-4.0-beta-vuduo2-20160420_usb.zip
    http://downloads.pli-images.org/buil...160420_usb.zip
    Thumbs up OpenPli 4.0 Beta VU+ Duo2 Image
    Thumbs up OpenPLi 4.0_ by mamba65 _with Panda FREE IPTV
    ~~What's Included On VU+DUO 2~~
    -Plugins-
    PoverVu Key Updater
    M3uTo Bouquet ConverterPlugin
    TSpanel_7.5
    TS Media latest version
    IpTV Player latest version
    SubTitle Player 4.01
    LCD4Linux
    Clear Memory latest version
    EPG Import
    ...and more
    -Emus with active keys and already prepared-
    Doscam 0.25
    NCam
    -Channel List-
    ciefp-E2-68E-30W-IPTV-& mkv Movies-08.05.2016
    -Skin-
    Tiny HD by mamba65
    PLi-HD_default
    -Booting-
    Restarting & Bootlogo by mamba65
    -Password FTP and Telnet-
    root
    root
    DOWNLOAD: http://www.file-upload.net/download-...65.tar.gz.html
