Likes Likes:  2
Results 1 to 10 of 10
Thread: DVB-S2 Omicom S2 PCI Rev. 3
    Thumbs up DVB-S2 Omicom S2 PCI Rev. 3
    DVB-S2 Pro OMICOM S2 PCI 16/32 APSK ACM is a professional PCI card for providers, streaming, control and other custom solutions. Based on STV0900 demodulator.
    Support 8PSK/QPSK/16APSK/32APSK modulation.
    Support really high Symbol Rates:
    DVB-S2 QPSK up to 63 Msps Max.
    DVB-S2 16/32 PSK up to 63 Msps Max.
    Omicom DVB-S2 Pro PCI card is ready to recieve any signal from satellite including modern experimental and reserved for telco data transponders. It can be used in DVB-IP gateways, Home Theaters, satellite data and other solutions.
    You can also use our Omicom DVB-S2 Pro card in PCIe slot. You just need to get the PCI to PCIe adapter as an option. Adapter can be installed in any PCIe slot with 1x lane, 4x, 8x and 16x. And it works fine without any additional drivers with Windows XP, 2003, Vista, 7, 8 and Linux.
    PCI to PCIe adapter
    This adapter is well-tested and works fine with our Omicom DVB-S2 Pro PCI card!
    Email us to order now Omicom DVB-S2 Pro PCI, PCI to PCIe adapter is optional sales@omc-systems.ru.
    Main Features:
    1. DVB-S2/S Transponders Receiving
    2. 8PSK/QPSK/16APSK/32APSK mode
    3. Support Multiple Transport Stream
    4. Support Generic Stream capture
    5. Transponders blind scan
    6. Up to 140 Mbit/s channel bit rate capture
    7. High-speed Data download via Satellite
    8. Windows 7, Windows 7 Media Center, Windows XP, Linux compatible
    9. Supported by DVBDream, DVBViewer, DVBlogic, ProgDVB, Skynet, TSreader…
    DVB-S2 Pro OMICOM S2 PCI 16/32 APSK ACM with STV0900 BAB Revision demodulator specification
    1. Receiving Frequency: 925~2175 MHz Tuning Range
    2. Input level: -69~ -23dBm
    3. DVB-S2/DVB-S DIRECTV 8PSK QPSK 16APSK 32APSK
    4. 8PSK /QPSK/16APSK/32APSK mode
    5. Symbol Rates: DVB-S2 QPSK: 63 Msps Max. DVB- S2 16/32 PSK: 63 Msps Max
    6. Code Rates: DVB-S2 QPSK: 1/4,1/3,2/5,1/2,3/5,2/3,3/4,4/5,5/6,8/9,8/10 DVB-S2 8PSK: 3/5,2/3,3/4,5/6,8/9,9/10 16APSK: 2/3,3/4,4/5,5/6,8/9,9/10 32APSK: 3/4,4/5,5/6,8/9,9/10
    7. DiSEqC 1.2 compliant
    Software compatible:
    SAT TV - WMS7, DVBLink TvSource, ProgDVB, DVBDream, AltDVB, BlazeDTV, SichboPVR.
    SAT Inernet - BDADataEx, Omicom-Data, StreamReaderEx-BDA
    Drivers for DVB-S2 PCI OMICOM rev.3 card (v.2012 / 05/25)
    OMICOM-BDA-V1_3_525_0.zip
    http://s3.dosya.tc/server8/5o7edb/om...2.iso.zip.html
    http://speedy.sh/SKg9U/omicomS2pci-new2.iso.zip
    hxxp://www.skymaster.com.ua/rus/sputnikinet/files/
    thank you for our suport to @anas.tasia, @Rentner
    va multumesc pentru ajutorul acordat @anas.tasia, @Rentner
    18 Mar 2010
    software< -&->hardware
    Felicitari !!!
    Sper sa te bucuri de receptii extreme cu aceasta placa.
    Sunt curios, in privinta pretului si modul de achizitie, din ce am citit pe forumurile rusesti, compania a dat faliment si nu reparau/inlocuiau placile defecte.
    08 Dec 2011
    se gaseste la manelarica asta placa? unde? cum? vreau si eu daca e pret rusesc (adica mai mic)
    merci
    aceata placa se poate cumpara din ucraina de la acest magazin ---hxxp://www.skymaster.com.ua----Ucraina, Vinnitsya, tel / fax: +38 (0432) 65-89-00, 53-11-77
    din rusia nu se livreaza desi se poate plati cu paypal
    sau daca ai cunostinte/prietenii/pasionati in acest domeniu poti sa intri in posesie ei
    costa 300 lei cu transport inclus pana la destinatia ta
    18 Mar 2010
    Modelul "advanced" costa 300lei ? ......eu stiam ca modelele STV0903BAB/STV0903BAC costa atat.
    o clipa va rog ca sa nu provocam discuti/neintelegeri/interpretari
    eu atat am platit 300 lei cu transport inclus (pana la mine acasa )pentru placa prezentata mai sus
    tin sa mentionez ca nici unul dintre intermediari (@anas.tasia, @Rentner) nu si-a adaugat adaos comercial ,ci eu am adaugat 1-2 bere (prietenii stiu de ce)
    tot respectul pentru ei din partea mea deoarece ajuta/neajutam aceasta comunitate mica a pasionatilor de receptie satelitare .
    20 Apr 2009
    Arges
    27 Post(s)
    As fi si eu interesat de o placa de receptie pentru satelit mai buna pentru a scana diverse feed-uri. Am sunat la mai multe firme romanesti dar nu au decat modele de la Technisat si Skystar care nu sunt chiar recomandate si nici nu au suport software prea bun. Desi apar in stoc la satmultimedia cateva modele de la Prof cu pret acceptabil, dupa ce sun defapt nu sunt in stoc.
    Eram curios daca de pe site-ul de mai sus din Ucraina (hxxp://www.skymaster.com.u ) a comandat cineva si ajunge fara probleme cu posta sau curierat. Ar fi prima comanda a mea din exteriorul tarii . Am ceva retineri sa fac comanda si de aceea ma gandeam poate ma ajuta cineva cu vreun sfat astfel incat riscul sa nu primesc nimic sau sa primesc altceva sa fie cat mai mic.
    Vad ca pe acel site e un fel de promotie astfel incat pare sa fie 20 euro la care se va adauga transportul. Atat de putin sa fie ?
    DVB-S2 Omicom S2 PCI Rev. 4--------New Europe sale price! ONLY $ 68,99!
    http://www.omicom.info/index.html
    In ce calculator o pui?
