2
Dislikes:
- Rep Power
- 127
VU+ AcestreamPlayer Plugin for Enigma2 Version 2.0
Attached is the new version of Acestreamplayer - a plugin to play streams from a. Acestream server.
Method :-
Acestream Player How to
1. If you do not have Ace Player HD (vlc) already installed on your pc - first uninstall any installed vlc mediaplayer. Next find and install :-
Ace Player HD 2.2.6 (VLC 2.0.5)
2. Start Ace Player HD (vlc). Configure player :
Tools -> Preferences -> All -> Interfaces -> Main Interfaces -> Select Web -> Exit
3. Configure host :
Find the path to the folder player by rightclick on the Ace player icon. Mine is (for example) -
"C:\Documents and Settings\username\Application Data\ACEStream\player\ace_player.exe"
Then do - ACEStream\player -> lua -> http - find file HOSTS. Insert the receiver ip (without #)
(Sometimes ACEStream deletes this change after pc reboot. So check.)
4. Install plugin AcestreamPlayer (attached). Start plugin. Config - insert server ip and
location of your user acestream url list. Default location /media/usb. Save config and Restart enigma.
Example acestreams list attached.
Acelist.txt
File size:
958 bytes http://sendfile.es/pokaz/769191---bfeu.html
AcestreamPlayer-howto-EN.zip
File size:
897 bytes http://sendfile.es/pokaz/769193---2eqd.html
enigma2-plugin-extensions-acestreamplayer_2.0_r0_all.ipk
File size:
12 KB http://sendfile.es/pokaz/769196---duna.html
