Thanks Thanks:  7
Likes Likes:  2
Results 1 to 15 of 25
Thread: K1 Plus S2/T2 OpenElec LibreELEC Tvheadend
    Default K1 Plus S2/T2 OpenElec LibreELEC Tvheadend
    ---------- Post added at 14:38 ---------- Previous post was at 13:28 ----------
    Azi am testat mai amanuntit Openelec cu TVheadend.
    Am instalat de 2 zile totul, devea tunnerul dar nu scana.
    De fapt saneaza in fundal.
    A fost nevoie sa desfac carcasa superioara pentru ca se suprancalzeste in timpul scanarii.
    Ajunsese la 80 de grade C procesorul, desi i-am montat un supraradiator.
    Trebuie sa ii fac un sistem de ventilatie prin capacul superior.
    Nu m-a dat pe spate TV LIVE din kodi, se misca destul de greoi.
    E interesant ca poti sa pui partea de client pe un al device si sa te uiti remote prin retea.
    De exemplu pentru receptii terestre DX poti monta undeva sistemul si privesti prin internet la TV.
    ---------- Post added at 15:08 ---------- Previous post was at 14:38 ----------
    Cand am o imagine stabila gata configurata, o postez.
    Cei care nu mai au rabdare gasesc aici un tutorial corect de configurare.
    Ultimul pas in configurare :
    Configuring the frontend
    Now the backend is ok, we need to install and configure the frontend.
    Go to Settings -> Add-ons and find Tvheadend HTSP Client under PVR clients and then install/enable it.
    The default settings should be fine.
    Now go to Settings -> Live TV -> Live TV Enabled. The front end will connect to the backend and retrieve a channel list - you should now be able to watch live TV through the XBMC menus. It may take a while before the EPG data is updated if it is provided with the DVB signal.
    Apoi restart.
    Ce versiune de Openelec?
    6 se face trecerea la 7.
    Ai testat imagini de la wetek sau odroid?
    http://forum.odroid.com/viewtopic.php?f=138&t=20415
    Nu merg cele de wtek, difera filozofia boot loaderului.
    Se poate sapa la asta.
    Configurare OSCAM in imagini :
    Attached Images Attached Images
    Si cateva imagini.
    9000 poate sa lipseasca la listen port in DVBAPI oscam.
    E uitat acolo.
    Cei cu televizoare 4K trebuie sa aleaga 4k 50 hz, altfel au tresariri la ecran.
    Lucrez la conversia listei de canale din E2.
    Daca stiti careva un plugin Kodi gata facut pentru asta va rog sa imi dati lynk.
    Intentionez sa il adaptez la lista enf70 de e2.
    Acum o sa fac doar un script shell care apeleaza o aplicatie py pe aparat si converteste si insereaza lista.
    ---------- Post added at 23:06 ---------- Previous post was at 21:21 ----------
    Nu merg bine softurile cu care am incercat, au facut varza.
    Mai studiez maine de la capat.
    Trebuie sa fac o imagine buna si sa ii fac backup.
    Am reparat in final imaginea, stricasem lista de canale.
    Am gasit si ultima versiune de e2 list import, mai are bug-uri da fiind sursa libera in python e lesne de inteles ce vrea sau reparat unde ma pricep.
    Nu e nici pe departe la nivelul softului DTV din Android calitatea video si sincronizarea av.
    Se vad culorile bine dar pe partea de video cred ca lipsesc frame-uri si nu se poate sincroniza AV.
    Se fac unele chestii soft probabil si astfel apar probleme.
    Imagine SD-card LibreELEC 7.0.2.003
    Am testat-o si merge!
    Pentru SSh avem :
    user = root
    pass = libreelec
    Imagini LibreELEC la zi pentru aparatele cu S905 gasiti aici.
    05 Nov 2011
    Updated versions:
    LibreELEC-Amlogic.aarch64-KI_Plus-7.0.2.004.4.img.gz
    LibreELEC-Amlogic.aarch64-KII_Pro-7.0.2.004.4.img.gz
    - applied kszaq's fixes: removed hardware demux patch and added a change to allow playing very high bitrate videos.
