Thanks Thanks:  26
Likes Likes:  36
Dislikes Dislikes:  1
Page 13 of 15 FirstFirst ... 39101112131415 LastLast
Results 181 to 195 of 225
Thread: Mut@nt digital technology ULTRA HD HD51 2160p 4K-BOX E2 Linux Receiver
  1. #181
    30 Post(s)
    i7-7700 - Intel® HD Graphics 630 - acum am trecut la ceva mai potent - GTX 1080Ti - 16GB ddr4 plus restul configuratiei
    Cu ''ferrari'' raman pe Merlin 4 si e foarte practic cand vizionez domeniile - 4k/hd/filme ( din cand in cand adult ) de la ambii operatori - portocala + rcs fara sa schimb cam-urile intre ele
    Scuze de off-topic
  2. #182
    02 Sep 2010
    Earth
    Coane mario
    1080Ti are doar 11 si nu 16 si sunt gddr 5 , intradevar seria i7 cu 77xx cu "k" sau fara are intel 630.
    *-cpu
    description: CPU
    product: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
    vendor: Intel Corp.
    physical id: 4c
    bus info: cpu@0
    version: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
    serial: To Be Filled By O.E.M.
    slot: LGA1151
    capacity: 4500MHz
    width: 64 bits
    clock: 100MHz
    capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp flush_l1d cpufreq
    configuration: cores=4 enabledcores=4 threads=8.
    Cat despre 1080ti nu vad sensul de "restul configuratiei". Nu e vorba de mai "potent" ci de o alta arhitectura cu alte instructiuni, primul e intel , gestionat de intel media sdk, a doua e o placa video nvidia gestionata de driverele nvidia iar pentru cei ce intradevar stiu ce fac , se foloseste pachetul cuda complet de driverele nvidia sau nvidia dokker sau Tensorflow.
    Cred ca discutia asta poate fi mutata in alta parte.
    Cerem scuze.
  3. #183
    Chiar nu a testat nimeni Neutrino pe Mutant HD51?
    http://hd51.mbremer.de/FLASH/
    Detalii in curand.
    neutrino pe mutant....https://www.youtube.com/watch?v=ezEvEAZ73EU
    TOP5: Zgemma H9,
  4. #184
    94 Post(s)
    Testatzi fratilor imaginea, .sa stiu daca sap in contunuare portarea pe H7C
  5. #185
    17 Jul 2008
    In Tara
    cine?..
    nu da laleaua openpli si atv nici pa 100 de neutrini.
  6. #186
    30 Post(s)
    Piccolo08 , era vorba de memoria de sistem , stiu ca pl video are 11Gb DDR5 , daca sa inteles altceva ....scuze de off-topic
    Revenind on-topic , nu cred ca multi detin acest receptor in prezent , iar cel mai avizat in cauza .....vorba lui Felix73
  7. #187
    17 Jul 2008
    In Tara
    cei mai multi au in aparate imagini openpli si openatv.
    asta voiam sa spun.
    si nu i intereseaza neutrino sau satdreamgr spre exemplu.
  8. #188
    02 Sep 2010
    Earth
    Sincer nu vad ce a r aduce in plus aceste imagini, nu am testat.
    Eu am nevoie de un decoder sa se miste rapid, sa isi faca treaba pentru care a fost construit.
    Cateva plugin mai interesante si cam atat.
    Nu am avut nici o problema cu mutant@51. imi compilez singur oscam minimaledoar cu ce e strinct nevoie in sistem. elimin tot de ce nu am nevoie. S2x isi face treaba , emu la fel. folosesc combo s2x+t/t2/c si sunt supermultumit.
    Am si un dm900 clone si e la fel de bun, tunerul e din gama mai veche nu e s2x. Ambele merg perfect.
  9. #189
    03 Jun 2008
    OpenATV 6.3 vers.alpha pt HD51 stie cineva daca exista / apare ?
  10. #190
    none
    01 Jan 1999
    acasa
    35 Post(s)
    uite ce zice aici: https://www.opena.tv/openatv-6-3-pub...-3-update.html
    Bei aktuellem oATV6.2 in der Softwareverwaltung online flashen, und mit der blauen Taste von oATV6.2 auf oATV6.3 schalten (wenn schon Images für die entsprechende Box gebaut wurden, sind sie da), online flashen mit Einstellungssicherung, und wiederherstellen lassen. Hat bsiher zu 99,9% geklappt. Aber Imagesicherung zuvor schadet nie.
    gogu translute:
    With current oATV6.2 in the software management flash online, and switch with the blue button from oATV6.2 to oATV6.3 (if images were already built for the appropriate box, they are there), flash online with settings backup, and restore. Has worked to 99.9%. But image backup never hurts before.
    bafta
  11. #191
    17 Jan 2008
    03 Jun 2008
    Mersi Am facut upgrade si adio Kodi pe 6.3
    ...se mai plang si altii
    Trecem inapoi la 6.2
  13. #193
    pure2 ce a mai complexa imagine la ora actuala si nu mai ai nevoie de kodi...plus youtube 4k real....insa nu stiu daca la ora actuala merge fluid sau nu..
    TOP5: Zgemma H9,
  14. #194
    16 Sep 2007
    Poate la acest receptor e ok Pure...dar Pure la Dm 920 au dat xix incearca sa faca imagini dar sunt de toata jena...deocamdata imaginile lor nu au suport sa pui carduri CI si sa mearga cum au alte imagini la care merge perfect. Si nu numai la DM 920 au dat-o in bara dar si la Amiko A5 ca sa te conectezi la receptor nu te poti conecta prin ftp decat prin anumite artificii sa scrii istorii prin Telnet...etc ,etc...le trebuie specialisti la Pure !!!
  15. #195
    94 Post(s)
    Problemele semnalate de tine se datorează suportului limitat oferit de producătorii celor 2 aparate.
    Imaginile Dream sunt închise, teamurile pun doar floricele, iar la A5 e un bug legat de comutarea între android şi enigma2, la care am dat soluţia .
