Thanks Thanks:  31
Likes Likes:  24
Page 1 of 5 12345 LastLast
Results 1 to 15 of 70
Thread: Ferguson Ariva 4K and Ferguson Ariva 4K Combo
    13 Post(s)
    Thumbs up Ferguson Ariva 4K and Ferguson Ariva 4K Combo
    Ferguson Ariva 4K and Ferguson Ariva 4K Combo - Explore the power of Android on your set-top-box!
    Main features:
    4K UHD - Support for ultra-high resolutions
    H.265/HEVC - Support for hardware decoding
    DVB-S2 - H.264 Full HDTV 1080P
    Support for pay TV card reader (CA)
    Dualband Wi-Fi - 802.11 b/g/n 2.4Ghz/5Ghz
    Ethernet modem (LAN) for interactive communication with local network and Internet
    Bluetooth - Support for connecting the keyboard and mouse or other devices
    SD Card Reader
    Hard drive ready - Support for easy hard drive installation for TimeShift and programs recording
    Android 5.1.1 Lollipop
    Kodi Media Center - Advanced multimedia support
    Netflix, HBO GO - Excellent cooperation with almost all Video On Demand (VOD) services
    DLNA, Miracast i AirPlay - Support for media streaming to the device
    Inputs/Outputs:
    LNB IN
    USB
    AV
    Ethernet
    HDMI 2.0
    OPTICAL
    Power
    USB
    Recovery Switch
    Micro SD Card Reader
    Pay TV card reader (CA) (on the side)
    Slot for HDD mounting (on the bottom)
    Universal Remote:
    Ariva 4K is supplied with an extremely convenient and intuitive RCU-660 remote. The pilot sits perfectly in the hand allowing you to conveniently operate all the functions of the receiver. Note: it is possible to service the receiver using any device based on Android or iOS through the free app: NesTV.
    Technical Specifications:
    Chipset: Amlogic S905-B, Quad core Cortex A53 @ 2.02 GHz
    Flash Memory: EMMC 8GB
    DDR III Memory: 1GB
    DVBS Tuner Type: On board
    DVBS Frequency Range: 950~2150MHz
    DVBS Demodulator Mode: DVB-S (QPSK, ETS 300 421) and DVB-S2 (QPSK/8PSK, ETS 302 307)
    Video Decode:
    H.264/H.265 HEVC MP L5.0 up to 4K UHD 60fps
    H.264/H.265 AVC MP L5.1 up to 4K UHD 60fps
    H.264/H.265 MVC up to 4K UHD 60fps
    MPEG-4 ASP L5 up to 1080P 60fps
    AVS Jizhun Profile up to 1080P 60fps
    MPEG-2 MP HL up to 1080P 60fps
    MPEG-1 MP HL up to 1080P 60fps
    RealVideo 8/9/10 up to 1080P 60fps
    WebM up to VGA
    Video File Format Support: MKV, WMV, MPG, MPEG, DAT, AVI, MOV, ISO, MP4, RM, JPG, BMP, GIF and others
    HDMI Output: HDMI 2.0
    Video Resolution: 4K 60Hz, 4K 50Hz, 1080p/i, 720p
    Wi-Fi: Built-in 802.11 b/g/n, 2.4G/5G dual band
    Ethernet: Bilt-in 100M Ethernet RJ-45 modem for communication with Internet network
    Audio Decode: Dolby Digital/Digital Plus, MPEG, OGG, OGA, FLAC, ALAC, APE, M4A, RM, MPEG-1 layer1/2, MPEG-2 Layer II (DTS passthrough)
    Sampling Frequency: 32KHz, 44.1KHz, 48KHz
    PVR Record: Instant Record and Timer Record, EPG Timer Record
    Time-Shift Support: Auto Time-Shift
    File System Support: NTFS, FAT32
    Operating Temperature: 0°C-40°C
    Storage Temperature: -10°C-65°C
    Humidity: <95%
    Dimension (width x depth x height): 258mm x 158mm x 43mm
    Input Voltage: 12V 2.0A
    Power Consumption: Max 24W
    Power Consumption in Standby Mode: <0,5W
    Main features:
    DVB-S2 - H.264 Full HD 1080P TV
    DVB-T/T2 - also support for H.265/HEVC standard
    DVB-C - Cable television
    SD Card Reader
    Inputs/Outputs:
    ANT IN
    LNB IN
    USB
    AV
    Ethernet
    HDMI 2.0
    OPTICAL
    Power
    USB
    Recovery Switch
    Universal Remote:
    DDR III Memory: 1GB
    DVBT/T2/C Demodulator Mode: ETSI EN 302-755 V1.3.1 and EN 300-744 V1.6.1 compliant
    DVBT/T2/C Frequency Range: 52.5MHz to 866MHz
    Video Decode:
    WebM up to VGA
    Humidity: <95%
    Chipset: Amlogic S905-B - Pacat ca este varianta fara suport VP9 , care e foarte important la redarea videoclipurilor YT 4K
    13 Post(s)
    Ferguson Ariva 4K UHD H.265 Combo Wifi Bluetooth Receiver ohne HDD------189,00 € (satking-hm-sat)
    Pre-order now, before: 11.07.2016
    in spania este cel mai ieftin
    Disponible a finales de julio
    Primer receptor satélite + tdt T2 + cable Ultra 4K ¡al precio de un receptor HD!
    Ferguson Ariva 4k UHD Combo + Android
    149,00 € Precio final
    Pacat ca e un receptor 4K "incomplect"
    Probabil ca de aceea si pretul e pe masura
    13 Post(s)
    https://youtu.be/6gqaC8IwhZw
    minutul 1.40---FunBox 4K
    13 Post(s)
    Ferguson Ariva 4k Video configuration and demostration
    https://www.youtube.com/watch?v=8OrUADdToxk
    _______________
    13 Post(s)
    Ferguson Ariva 4K Combo - recenzja cz 1 - unboxing
    https://youtu.be/AYb0veRMASk
    Ferguson ARIVA 4K Combo test / recenzja cz.2
    https://youtu.be/ojD4bOPM3g8
    Ferguson Ariva 4K Combo - Como instalar aplicaciones por usb
    https://youtu.be/uxVdvwDkRSo
    in italia este cel mai ieftin
    Ferguson Ariva 4K Decoder 115.00 €
    Ferguson Ariva 4K Combo Decoder 125.00 €
    13 Post(s)
    Ferguson Ariva 4K Combo - Como poner cccam con el mando
    https://youtu.be/Mt7SLEyDiTg
    Ferguson Ariva 4K Combo - Reproduciendo vídeos 4K por usb
    https://youtu.be/X0gHQP5yQnM
    13 Post(s)
    13 Post(s)
    cine doreste sa achizitioneze un Ferguson Ariva 4K Combo
    va recomand acest mag ( muholdastv.hu ) Ungaria
    pret de achizitie +transport ---MultSat Magyarország Kft sent you an invoice for 40,400 HUF.---
    ---38900 HUF a 4k combo és 1500 ft a szálitási dij---
    Nota:
    Ferguson Ariva 4K Combo se poate achizitiona si de la alte magazine de specialitate din europa
    fiecare face cum crede de cuvinta (bani va apartin)
    mult succes tuturor
    13 Post(s)
    new orginal firmware
    -> Ariva-4K-20160927-v01.01.1438
    http://www.ferguson-digital.eu/?wpfb_dl=1251
    -> Mcas-20160901-v2.0.9.29180
    http://www.ferguson-digital.eu/?wpfb_dl=1219
    09 Jan 2016
    E pt combo?
    C***merge?
    Inviato dal mio GRACE utilizzando Tapatalk
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    @bonou2, ti-ai cumparat receptorul asta ?
    09 Jan 2016
    Si eu il am...merge!!am vers 01.01.1443 pt mcas trebuie sa pui vers "buna"
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    Eu nu prea il consider un receptor care merge. Lista de canale in format Enigma 2...e o poveste, neimplementarea limbii romane in subtitrari si in audio duce la butonari in plus, lipsa editor de canale, ramanerea fara imagine la zappingul canalelor 4k de pe un satelit pe altul. Astea sunt doar cele descoperite de mine. Mai e mult de munca la el. Pretul il recomanda. Atat !
    Are cineva o lista de canale cat de cat decenta, ce poate fi importata ? Lista lui @zipper subtiata destul de mult, este importata cu erori grave.
