Thanks Thanks:  9
Results 1 to 15 of 23
Thread: Tivusat, ma ajuta cineva?
    30 Dec 2008
    Default Tivusat, ma ajuta cineva?
    Card Tivusat 183d, pus in doua receptoare (Vu+ Solo2, intern sau smargo sau DM500+ intern), incercate cateva versiuni de oscam, aceeasi problema
    1970/01/01 02:32:22 10121720 r bla [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=3.68 MHz1970/01/01 02:32:23 10121720 r bla [internal] card detected
    1970/01/01 02:32:24 10121720 r bla [internal] ATR: 3F FF 95 00 FF 91 81 71 FF 47 00 54 49 47 45 52 30 30 33 20 52 65 76 32 35 30 64
    1970/01/01 02:32:24 10121720 r bla [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
    1970/01/01 02:32:24 10121720 r bla [internal]  TEST tempo mhz check = 500 mhz
    1970/01/01 02:32:24 10121720 r bla [internal] Calculated work ETU is 5.93 us reader mhz = 540
    1970/01/01 02:32:24 10121720 r bla [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 5.40 Mhz (nearest possible mhz specified reader->cardmhz)
    1970/01/01 02:32:25 10121720 r bla [internal] detect nagra tiger card
    1970/01/01 02:32:25 10121720 r bla [internal] card system not supported
    1970/01/01 02:32:25 10121720 r bla [internal] Normal mode failed, reverting to Deprecated Mode
    1970/01/01 02:32:26 10121720 r bla [internal] ATR: 3F FF 95 00 FF 91 81 71 FF 47 00 54 49 47 45 52 30 30 33 20 52 65 76 32 35 30 64
    1970/01/01 02:32:26 10121720 r bla [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
    1970/01/01 02:32:26 10121720 r bla [internal]  TEST tempo mhz check = 500 mhz
    1970/01/01 02:32:26 10121720 r bla [internal] Calculated work ETU is 82.67 us reader mhz = 450
    1970/01/01 02:32:26 10121720 r bla [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->cardmhz)
    1970/01/01 02:32:27 10121720 r bla [internal] detect nagra tiger card
    1970/01/01 02:32:28 10121720 r bla [internal] Resync error: readtimeouts 0/0 (max/min) us, writetimeouts 0/0 (max/min) us
    1970/01/01 02:32:30 10121720 r bla [internal] T1 Resync command error, trying to reactivate!
    1970/01/01 02:32:30 10121720 r bla [internal] ATR: 3F FF 95 00 FF 91 81 71 FF 47 00 54 49 47 45 52 30 30 33 20 52 65 76 32 35 30 64
    1970/01/01 02:32:30 10121720 r bla [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
    1970/01/01 02:32:30 10121720 r bla [internal]  TEST tempo mhz check = 500 mhz
    1970/01/01 02:32:30 10121720 r bla [internal] Calculated work ETU is 5.93 us reader mhz = 540
    1970/01/01 02:32:30 10121720 r bla [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 5.40 Mhz (nearest possible mhz specified reader->cardmhz)
    1970/01/01 02:32:30 10121720 r bla [internal] card system not supported
    1970/01/01 02:32:30 10121720 r bla [internal] THIS WAS A FAILED START ATTEMPT No 1 out of max alloted of 1
    1970/01/01 02:32:30 10121720 r bla [internal] card initializing error
    1970/01/01 02:32:31        0 s init for all local cards done
    Am incercat diferite setari in [reade], eroarea actuala data cu acestea
    [reader]enabled = 1
    label = bla
    protocol = internal
    device = /dev/sci0
    caid = 183D
    rsakey = A92............B5
    ecmwhitelist = 91
    ecmheaderwhitelist = 80308ED387,81308ED387
    detect = cd
    nagra_read = 2
    mhz = 368
    cardmhz = 2700
    ident = 183D:000000,005411
    group = 2
    emmcache = 1,1,1
    blockemm-unknown = 1
    blockemm-g = 0
    blockemm-u = 0
    Vreo idee ??? Ca eu sunt depasit...
    Cardul face lumina in camul lui sau in cccam (la acesta fara nici un fel de setare speciala). Intr-unul din cititoarele interne ale vu plusului mai am un HD+ 1843 care merge fara probleme....
    Ms
    none
    01 Jan 1999
    acasa
    35 Post(s)
    salut...
    incearca in vu+ cu:
    PHP Code:
    detect cd
    mhz
    450
    cardmhz
    2700
    bafta
    30 Dec 2008
    Aceeasi problema.
    none
    01 Jan 1999
    acasa
    35 Post(s)
    autospeed enable?
    bafta
    08 Feb 2014
    incearca un upgrade la oscam
    [reader]
    label = TivuSat
    protocol = internal
    device = /dev/sci0
    services = tivusat
    lb_whitelist_services = tivusat
    autospeed = 0
    caid = 183D,183E
    rsakey = A9...B5
    detect = cd
    nagra_read = 1
    mhz = 450
    cardmhz = 2700
    ident = 183E:005411,000000;183D:005411,000000
    group = 1
    emmcache = 2,1,2,1
    auprovid = 005411
    daca nu o ia, ai nevoie de un easymouse2
    30 Dec 2008
    Tot nu merge...
    Va rog sa-mi dati un rsa in pm poate e asta gresit, nu stiu. Cred totusi ca emulatorul e de vina , pentru ca in cccam 230 merge fara probleme cu ecm sub 0,200 in readerul de la Vu+.
    Am 2 Smargo Crystal si doua Smartreadere (Argolis parca) toate de la satmultimedia, nici in ele nu merge minunea asta de card (in oscam). Din ce-mi amintesc nici HD+ din dotare nu mergea in ele (tot nagra), nu mai stiu ce eroare dadea. In schimb au mers mai multe carduri (cworks de ex), ia acum am in ele freesat via si conax si focus care n-au nici o problema.
    Deci daca nu merge in astea care ar fi riscul sa mai iau un cititor de card si sa nu mearga? Nu-mi dau seama daca easymouse2 e ceva diferit sau nu (nu am avut mult timp sa studiez chestiunea... noob)
    Asa arata Crystal
    http://www.tvsatnitra.sk/obchod/acti...-crystal.xhtml
    Are pe el 4 comutatoare
    1: comuta intre 3,3v si 5v
    2: comuta intre SmartMouse si Phoenix
    3: comuta intre o sageata (indreptata catre 4) si 3,579mhz
    4: comuta frecventele : 5mhz, 8mhz, 10mhz si Y5
    Astea nu mi-au mers decat in combinatia : 5v / phoenix / 3,579mhz (cu cardurile care imi merg desigur, de ex cardul freesat viacces, sau tntsat la vremea lui, etc). Nu stiu sa setez asa ceva. :/
    Poate imi ziceti ce sa setez hard sau/si soft (oscam) acest Smargo Crystal... poate... poate....
    Multumesc... simt ca mi-a ramas doar sa ma rog....
    08 Feb 2014
    aici ai tot ce ai nevoie http://sateliti.info/showthread.php/...698#post253698
    are tot ce-ti trebuie mai trebuie configurat readerul
    pentru nagra 5v phoenix 357 mhz mhz 357 autospeed 0(era ideal easymouse cu 368) dar merge si cu asta
    in oscam pe reader intern cu am postat mai sus
    in easymouse2
    [reader]
    label = TivuSat
    protocol = mouse
    device = /dev/ttyUSB0
    services = tivusat
    autospeed = 0
    caid = 183D,183E
    rsakey = A9...B5
    detect = cd
    nagra_read = 1
    mhz = 357
    cardmhz = 357
    group = 1
    emmcache = 2,1,2,1
    auprovid = 005411
    ai si pm rsa
    30 Dec 2008
    tot nimic
    [CODE]
    • 2016/06/18 21:20:22 524E53BF r (reader) TivuSat [mouse] detect nagra tiger card
    • 2016/06/18 21:20:23 1210FE34 r (reader) TvrHD [mouse] providers: 3 (FFF720,025900,025910)
    • 2016/06/18 21:20:23 120FA250 r (reader) HD+ [internal] Buffers readed 0 bytes total time_us 3079908
    • 2016/06/18 21:20:23 1210FE34 r (reader) TvrHD [mouse] Maturity level [F]=no age limit
    • 2016/06/18 21:20:23 1210FE34 r (reader) TvrHD [mouse] ready for requests
    • 2016/06/18 21:20:23 1210FE34 r (reader) TvrHD [mouse] found card system viaccess
    • 2016/06/18 21:20:23 1210FE34 r (reader) TvrHD [viaccess] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
    • 2016/06/18 21:20:23 1210FE34 r (reader) TvrHD [viaccess] card detected
    • 2016/06/18 21:20:23 1210FE34 r (reader) TvrHD [viaccess] serial: ##########
    • 2016/06/18 21:20:23 524E53BF r (reader) TivuSat [mouse] card system not supported
    • 2016/06/18 21:20:23 524E53BF r (reader) TivuSat [mouse] Normal mode failed, reverting to Deprecated Mode
    • 2016/06/18 21:20:23 524E53BF r (reader) TivuSat [mouse] Buffers readed 0 bytes total time_us 75222
    • 2016/06/18 21:20:23 1210FE34 r (reader) TvrHD [viaccess] provider: 1, id: #################, sa: ########, geo: empty
    • 2016/06/18 21:20:23 0A3A637C r (reader) Focus [smargo] type: Conax, caid: 0B02, serial: ##########, hex serial: ########, card: v64
    • 2016/06/18 21:20:23 0A3A637C r (reader) Focus [smargo] Providers: 1
    • 2016/06/18 21:20:23 0A3A637C r (reader) Focus [smargo] Provider: 1 Provider-Id: 000000
    • 2016/06/18 21:20:23 0A3A637C r (reader) Focus [smargo] Provider: 1 SharedAddress: ########
    • 2016/06/18 21:20:23 0A3A637C r (reader) Focus [smargo] found card system conax
    • 2016/06/18 21:20:23 0A3A637C r (reader) Focus [conax] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
    • 2016/06/18 21:20:23 3ACE4178 r (reader) Freesat [smargo] type: Conax, caid: 0B02, serial: ##########, hex serial: ########, card: v64
    • 2016/06/18 21:20:23 3ACE4178 r (reader) Freesat [smargo] Providers: 1
    • 2016/06/18 21:20:23 3ACE4178 r (reader) Freesat [smargo] Provider: 1 Provider-Id: 000000
    • 2016/06/18 21:20:23 3ACE4178 r (reader) Freesat [smargo] Provider: 1 SharedAddress: ########
    [CODE/]
    08 Feb 2014
    In pagina de. Oscam ai debug bifează de la 1la 32 și tine pornit doar reader-ul de tivusat
    Trimis de pe al meu Nexus 5 folosind Tapatalk
    ---------- Post added at 21:28 ---------- Previous post was at 21:28 ----------
    08 Feb 2014
    30 Dec 2008
    hmmmmm
    [CODE]
    • 2016/06/18 22:54:00 00000000 s (main) waiting for local card init
    • 2016/06/18 22:54:01 5270C3B1 r (reader) TivuSat [internal] card detected
    • 2016/06/18 22:54:02 5270C3B1 r (reader) TivuSat [internal] ATR: 3F FF 95 00 FF 91 81 71 FF 47 00 54 49 47 45 52 30 30 33 20 52 65 76 32 35 30 64
    • 2016/06/18 22:54:02 5270C3B1 r (reader) TivuSat [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
    • 2016/06/18 22:54:02 5270C3B1 r (reader) TivuSat [internal] Calculated work ETU is 7.11 us reader mhz = 450
    • 2016/06/18 22:54:05 5270C3B1 r (reader) TivuSat [internal] Buffers readed 0 bytes total time_us 3099274
    • 2016/06/18 22:54:06 5270C3B1 r (reader) TivuSat [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
    • 2016/06/18 22:54:07 5270C3B1 r (reader) TivuSat [internal] detect nagra tiger card
    • 2016/06/18 22:54:07 5270C3B1 r (reader) TivuSat [internal] type: NAGRA, caid: 183D, IRD ID: ############
    • 2016/06/18 22:54:07 5270C3B1 r (reader) TivuSat [internal] ProviderID: 00 00 54 11
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [internal] ready for requests
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [internal] found card system nagra
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [nagra] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [nagra] ROM: T I G E R 0 0 3
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [nagra] REV: R e v 2 5 0
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [nagra] SER: ############
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [nagra] CAID: 183D
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [nagra] Prv.ID: 00 00 54 11 (sysid)
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [nagra] Activation Date : 01/01/2009
    • 2016/06/18 22:54:08 5270C3B1 r (reader) TivuSat [nagra] Expiry Date : 01/01/2038
    • 2016/06/18 22:54:08 00000000 s (main) init for all local cards done
    • 2016/06/18 22:54:08 00000000 s (emmcache) loading emmcache disabled since no reader is using it!
    • 2016/06/18 22:54:08 00000000 s (emmcache) loading emmstats disabled since no reader is using it!
    • 2016/06/18 22:54:08 00000000 s (anticasc) anti cascading disabled
    [CODE/]
    ---------- Post added at 22:58 ---------- Previous post was at 22:56 ----------
    SI........................
    [CODE]
    • 2016/06/18 22:59:01 1D3B755F c (ecm) bibisor (183D/B7): not found (2 ms) by TivuSat
    • 2016/06/18 22:59:01 05FE196A c (ecm) Polliia (183D/91): cache1 (1 ms) by TivuSat - Rai 1 HD
    • 2016/06/18 22:59:01 791108C0 c (ecm) petiofi (183D/91): found (193 ms) by TivuSat - Rai 1
    • 2016/06/18 22:59:03 05FE196A c (ecm) Polliia (183D/91): cache1 (1 ms) by TivuSat - Rai 1
    • 2016/06/18 22:59:09 791108C0 c (ecm) petiofi (183D/91): cache2 (125 ms) by TivuSat - Rai 1 HD
    • 2016/06/18 22:59:09 38BAD023 c (ecm) anonymous (183D/91): found (193 ms) by TivuSat - Rai 1 HD
    • 2016/06/18 22:59:10 05FE196A c (ecm) Polliia (183D/91): found (192 ms) by TivuSat
    • 2016/06/18 22:59:11 05FE196A c (-) -- Skipped 1 duplicated log lines --
    • 2016/06/18 22:59:11 05FE196A c (ecm) Polliia (183D/91): cache1 (1 ms) by TivuSat - Rai 1 HD
    [CODE/]
    ---------- Post added at 23:02 ---------- Previous post was at 22:58 ----------
    Merge !!!!!!!!
    Deci era de la emulator....
    Sa vad cum merge si cu restul cardurilor.
    Danny, la ce te referi cand spui "cu de toate" ?
    Multe multumiri
    ---------- Post added at 23:15 ---------- Previous post was at 23:02 ----------
    Danny, te rog zi-mi setarile corecte pentru fiecare card
    [CODE]
    [reader]
    label = TivuSat
    protocol = internal
    device = /dev/sci1
    services = tivusat
    autospeed = 0
    caid = 183D,183E
    rsakey = A9....B5
    detect = cd
    nagra_read = 1
    mhz = 450
    cardmhz = 2700
    group = 1
    emmcache = 2,1,2,1
    auprovid = 005411
    [reader]
    label = Focus
    description = Focus
    protocol = smargo
    smargopatch = 1
    caid = 0B02
    detect = cd
    mhz = 534
    cardmhz = 600
    ident = 0B02:000000
    group = 1
    audisabled = 1
    [reader]
    label = Freesat
    description = Freesat
    protocol = smargo
    device = /dev/ttyUSB1
    smargopatch = 1
    autospeed = 0
    caid = 0B02
    detect = cd
    mhz = 600
    cardmhz = 600
    ident = 0B02:000000
    group = 1
    audisabled = 1
    [reader]
    label = HD+
    protocol = internal
    device = /dev/sci0
    caid = 1843
    boxkey = A7.........7C
    rsakey = BF......D5
    detect = cd
    mhz = 450
    cardmhz = 2700
    group = 1
    dropbadcws = 1
    audisabled = 1
    [reader]
    label = TvrHD
    description = TvrHD
    protocol = mouse
    device = /dev/ttyUSB2
    smargopatch = 1
    detect = cd
    group = 1
    audisabled = 1
    [CODE/]
    08 Feb 2014
    Cardmhz=357 la toate readerele externe in rest e bine. MHz definește frecventa setata pe fiecare reader. La cele neagra ar trebui cardmhz=368(pe readere externe). In
    19 Post(s)
    tiger_rsakey =
    A92DA72FEEACF2947B003ED652153B189E4043B0138C368BDF6B9ED77DDAD6C0761A2198AEB3FC97A19C9D01CA769B3FFFE4F6E70FA4E0696A8980E18D8C58E11D817121346E3E66457FDD84CFA72589B25B538EFC304361B54845F39E9EFA52D805E5FD86B595B366C35716ABC91FA3DC159C9F4D8164B5
    tiger_ideakey = 37373737373737373737373737373737
    [CODE]
    [reader]
    label = TivuSat
    protocol = internal
    device = /dev/sci1
    services = tivusat
    autospeed = 0
    caid = 183D,183E
    rsakey = A9....B5
    detect = cd
    nagra_read = 1
    mhz = 450
    cardmhz = 2700
    group = 1
    emmcache = 2,1,2,1
    auprovid = 005411
    Buna ziua, am o rugaminte la cei care stiu, as vrea sa-mi cumpar o cartela Tivusat si cam, ce sfat imi dati?
    Activarea ei in Romania cum se face?
    P.S.as vrea sa o folosesc in oscam.
    ms
    7 Post(s)
    Salut, in comerț găsești doar carduri verzi sau negre(1856 caid) care nu merg in CS doar in cam tivusat, cat despre cardurile vechi e riscat de oare ce nu sti daca va-fi dezactivat(183D -tig02-tig-03) care sunt doar hd, cardul galben (tot hd nu deschide 4K) rar de gasit cu caid 183D sunt imortale, cardurile gri (183E) nu mai fac au doar in cam original tivusat, dar sunt anumite script-uri care trimit emm corect la acest card daca este in oscam.
