Ultimate IPTV is an addon that scrapes a blog for IPTV m3u8 lists.
The blog is daily updated with new lists. If a stream doesn't work, try another one.
The default playback mode is F4mProxy.
In the addon settings, you can change it to 'Direct', so it doesn't use F4mProxy.
Searching every list for the streams you need can be annoying with for example 1800 streams.
So in the addon settings you can set a filter. Like if you're looking for romanian streams, set it to 'ro'.
Or if you want all Sky channels, set it to 'sky'. It's case insensitive.
Installation instructions for Ultimate IPTV:
***If you already have Fusion installed skip to step #5***
  1. Select from the submenu under SYSTEM, FILE MANAGER
  2. Double click on ADD SOURCE
  3. Enter http://fusion.tvaddons.ag and click DONE
  4. Enter the name Fusion and click on OK
  5. Go to HOME and select SYSTEM
  6. Select ADDONS
  7. Select INSTALL FROM ZIP
  8. Select the red icon labeled Fusion
  9. Select xbmc-repos
  10. Select xxx-adult
  11. Select repository.whitecream-2.0.*.zip *latest version
  12. Wait until KODI refreshes all the repositories and
  13. Select install from repository
  14. Select WhiteCream repo
  15. Select Video Add-ons
  16. Select Ultimate IPTV
  17. Select INSTALL
  18. You now have successfully installed the Ultimate IPTV add-on on your KODI system!
  19. You can find it in Video -> Addons -> Ultimate IPTV
