3
4
Vu + Uno 4K
Open Source 3.0 VU+ Uno4k Image
http://code.vuplus.com/download/boxi...043629_usb.zip
OpenATV 5.3 VU+ Uno4k Image
http://images.mynonpublic.com/openat...p?open=vuuno4k
VuPlus FBC DVB S2X ?
VuPlus FBC DVB S2X
a aparut in oferta de la satmultimedia.ro
VU+ Plus UNO 4K UHD DualCore Linux Receiver----------Pret: Lei 1.355
succes tuturor
---------- Post added at 09:31 ---------- Previous post was at 08:48 ----------
http://code.vuplus.com/index.html?ac...&model=vuuno4k
VU+ UNO 4K - Unboxing
https://youtu.be/43QgvM15I-Y
Vu+ UNO 4K - Rýchlosť prepínania programov - Fast Channel Change [SatelitnaTV.sk]
https://youtu.be/H8LGNUiOpX0
Reason: update
New VTi - Vu+ Team Image - VTi 11.0.x
From VTi Team
VTi Panel (Blue Button)
Supported languages:
English, German, Dutch, Italian, Turkish, Danish, Polish,
Russian, Ukrainian, Czech, Arabic, French, Swedish,
Portuguese (Portugal), Greek, Bulgarian, Hungarian
With modular, flexible VTi skins
VTi Bootlogos and Radiomode Logo.
Short press on blue button opens VTi Panel, long press opens Pluginmenu
Support for FTDI chipset cardreader like smargo and easymouse2
Running Softcam shown in the Infobar
MovieList with extended functions
Support for full image backup and restore (not Vu+ Solo 4K / Uno 4K)
Supports VTi image flash online (not Vu+ Solo 4K / Uno 4K)
Restore Plugins, Bouquets, Settings, etc. during installation
Remove preinstalled packages during installation (VTi Zero)
Basic image information
Build tree: openvuplus-3.0 (more)
Kernel: 3.14.28 (Solo 4K, Uno 4K, Ultimo 4K)
Kernel: 3.13.5 (Solo˛, Duo˛, Solo SE, Zero)
Kernel: 3.9.6 (Duo, Solo, Uno, Ultimo)
Gstreamer: 1.6.4
HbbTV-Browser: Opera (Solo˛, Duo˛, Solo SE, Zero)
HbbTV-Browser: WebKit (Solo 4K, Uno 4K, Ultimo 4K)
CHANGELOG
- default skin: VuHD1080p (Solo 4K, Uno 4K, Ultimo 4K, Duo2, Solo2, Solo SE, Zero, Ultimo)
- default skin: MuteSpectator (Duo, Solo, Uno)
- Update OpenWebinterface -> ver. 1.x
- Switch from libav to ffmpeg
- Update dvbapp2
optimize showing available tuners (see: VuHD1080p skin)
CI improvements (e.g. scrambled DVB-S2 / DVB-T2 with H.265 codec)
display tuner name during tuner setup
show correct color button function in InfoBar (see: VuHD1080p skin)
display skin errors
support horizontal listboxes (THX @hmmmdada)
support eWall (THX @hmmmdada)
alternative service list (horizontal)
MediaPlayer: Skip to files with SMS-type input
SleepTimer: allow standby also when screens are opened
support power schedules
new EPG matrix mode (press help to see functions)
support automatic audio-/subtitle-track selection
support Autotimer in all preinstalled EPG views
show Choicelist with button "OK" for setup selections in setup screens
support HbbTV fpr remote channels
show search key at SMS-type input in service list (see: VuHD1080p skin)
map CH+/CH- button for page up / page down in setup screens
map button cross down to list old timeshift files
support autofs for network shares
support extplayer (serviceapp plugin by mx3l)
Upgrade 9.0.X
http://www.mediafire.com/file/nj431b...11-0-0_usb.zip
VU+ Uno4k
https://youtu.be/m2k__vjkffo
se confirma ca tunerul este VuPlus FBC DVB- S2(X)_V1.0 2016.10.18-------------secunda 0.17
thx to:wojtek0706
https://youtu.be/uCakfp33Y9A
OpenViX 4.2. VU+ Uno4k Image
openvix: release 4.2.021
Merge branch 'Dev'
[ButtonSetup] Add streaming clients.
[UsageConfig.py] PEP8 clean up and tidy up (#54)
Use debug and error log level for python loggings (#541)
Hide volumebar when mute and show when unmute
ServiceInfo: Indicate IS_4K with some margin
openvix: developer 4.2.021.005
openvix: developer 4.2.021.004
[MovieSelection] Tweaked context menu.
openvix: developer 4.2.021.003
openvix: developer 4.2.021.002
[Translations] Update FI, thanks Samzam!
Merge pull request #52 from rimasx/patch-1
Update et.po
[About] Remove recently added R/C-info, as it doesn't work properly for all hardware.
Merge pull request #51 from original-birdman/Dev
Ensure that zero does not get written to the remote control proc file.
[TimeShift] add a repeat loop to allow more time to get tuner lock.
openvix: developer 4.2.021.001
[vuplus] Update libvugles2(uno4k, ultimo4k)
[vuplus] [kodi] fix crash bug.
[libdvbsi] update to last git rev
[vuplus] update driver (ultimo4k)
[openatv] azbox e2 patch only for master branch dont merge to 4.0 branch
[ew7362] [vg2000 & vg5000] repack driver zip file
fix build enigma2-plugin-systemplugins-serviceapp with new gcc on arm plattform
[showiframe] fix openvix logo issue and fix play2 greenscreen
[xcore] drivers update Changes Fixed the wake up issue after 18h 13m of deepstandby without timer on OS mini+ and SPYCAT mini+ Added a workaround for few radio channels without PCR
[tripledot] vg2000 and vg5000 fix av out and optimise ci
[entwopia] update drivers ew7362 fix a/v out
dvbsnoop - fix silly mistake last commit...
dvbsnoop - bump PR. had be reverted as it breaks build old boxes.
Revert "dvbsnoop: move to PersianPros on github."
Merge branch '3.4-iptables' into 3.4
vuplus: bump kernel
vuuno4k: add iptables modules
vuultimo4k: add iptables modules
vusolo4k: add iptables modules
vusolo2: add iptables modules
vuzero: add iptables modules
Merge pull request #144 from persianpros/patch-1
[azbox] update e2_pcr.patch for openatv
[vuplus] fix uno4k pvr
chromium fix depends issue multi build environment
add missing module
vusolose: iptables
[OpenWebif] Fix truncated lines
[OpenWebif] Fix last commit
[OpenWebif] Prepare 1.1 No. 2
[vuplus] update drivers(uno4k, ultimo4k) - Fix HDMI IN(ultimo4k) - Fix DVB-CI and PiP
[3rd-party-feeds] Update.
[openatv] wetek e2 merge now to atv main e2 git
openbh: release 0.6.020
[openMips] roll out packages themes webtv vxg of enigma2-plugin-extensions-openwebif only for boxes not having MACHINE_FEATURES smallflash
[vuplus] update more drivers
[OpenATV] PR bump
[OpenATV] OWIF module selection All machines: - WebTV
[OpenWebif] Prepare for 1.1 - READ! Beginning with version 1.1 OWIF will be modular: You can have OWIF with or without Themes and with or without WebTV and with or without VXG (WebTV support for Chrome) (more features as modules might come later)
http://www.openvix.co.uk/index.php/d...ages/vu-uno4k/
iBlack Hole 3.0.3 Kodi VU+ Uno4k Image
Merry Christmas from the Black Hole Team
What is new ?
- Add Support for Uno4K and Ultimo4K
- Update default skin MX HQ10 for extra tuners
- Update skin api
- Update OpenMultiboot
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Community members can then download it from our servers.
This feature provides other benefits such as:
Increase download speed of EPG
Download EPG from any channel
Schedule the download of EPG decoder even during standby
Users can customize the providers using Add / Remove function
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
https://www.easypaste.org/file/NeFtq...86.zip?lang=pl
VTi 11.0.1- Vu+ Uno 4K Image
Vom VTi Team
VTi Panel (Blaue Taste)
New VTi - Vu+ Team Image - VTi 11.0.1
From VTi Team
23.12.2016 - Software Update
- increase image version: VTi 11.0.1
- update driver 20161223 (solo4k, uno4k, ultimo4k)
fix motorized dish (ultimo4k, uno4k)
fix PES filter
fix FastForward
fix DTS media playback problem
support 2160p24, 2160p25, 2160p30 video mode
support DTS-HD MA Passthrough (needs modified gstreamer)
fix Refresh rate
fix misc and add more video codecs
- update dvbapp2 20161223
[MovieList] improve grouping movies
fix misc. bugs
- update plugin videomode autoframerate
[INFO] autoframerate is not needed anymore for uno4k, ultimo4k, solo4k
driver supports now frame rate swapping
choose frame rate multi or multi (50/60/24p)
https://www.4shared.com/zip/LRHyRsZY...612231237.html
rudream-5.0 VU+ Uno4k Image
update :23-12-2016
rudream-5-vuuno4k_usb
https://docviewer.yandex.com/?url=ya...c=585e4a7ecbb3
http://code.vuplus.com/download/boxi...165848_usb.zip
Vu+ Uno4K Tested for You
Thanks @Evo
Vu+ Uno4K Review.pdf:https://www.sendspace.com/file/5b9xdm
Black Hole 3.0.3.A Kodi VU+ Uno4k Image
What is new ?
- Update default skin MX HQ10 to fix some plugin issues
- Update skin api to fix some plugin issues
- Update Unicable and Unicable II LNB support
http://www.4shared.com/zip/10AJ1t3eb..._usb_rele.html
https://docviewer.yandex.com/?url=ya...c=586a43af5259
Backup VU+Uno 4k by mika22
http://www.mediafire.com/file/a55tu3...up_vuuno4k.rar
openATV 5.3 backup by @mika
http://venuscs.net/SvPverzijaAUTO/en...el_6.1_all.ipk
http://www.openvix.co.uk/openvix-bui...uuno4k_usb.zip
http://code.vuplus.com/download/boxi...170018_usb.zip
SFTEAM image 5.1 VU+ Uno4k Image
http://images.sfteam.es/download.php...d4w8y5j2j3u6n8
OpenPLi-5.0-beta-kodi16.1 VU+ Uno4k Image
http://www48.zippyshare.com/v/r7XCSEUT/file.html
Open ATV 6.0 VU+ Uno4k Image
http://code.vuplus.com/download/boxi...172842_usb.zip
OpenViX 4.2.030 VU+ Uno4k Image
http://code.vuplus.com/download/boxi...170955_usb.zip
OpenDroid 6.0 VU+ Uno4k Image
http://images.opendroid.org/6.0/VU+/...170219_usb.zip
http://code.vuplus.com/download/boxi...164538_usb.zip
OpenESI 4.0 VU+ Uno4k Image
http://www.openesi.eu/images/images/...VU%2B/vuuno4k/
http://code.vuplus.com/download/boxi...165116_usb.zip
http://images.opendroid.org/6.0/VU+/...170225_usb.zip
