Thanks Thanks:  16
Likes Likes:  14
Dislikes Dislikes:  1
Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 31 to 45 of 124
Thread: OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver
    Upgrade Octagon 4K
    https://youtu.be/LTKjK8mbbnM
    Multistream Octagon 4K
    https://youtu.be/_uxiQ8FOF8o
    Octagon4K IPTV
    https://youtu.be/ozrY8XTpQc4
    multumin @antenutze
    Driver (Driver) update O ctagon SF4008 - 15-02-17:
    20170214
    -. EN: Web-inf support (video) fix.
    -. ENG: Web interface video problem fixed.
    Testing by FTP: file linuxtv.ko to lib / modules / 4.1.37 / extra copy and restart the box.
    Download Drivers for:
    5.x Images: http://octagon-forum.eu/test-team/sf...0-20170214.zip
    6.x Images: http://octagon-forum.eu/test-team/sf...0-20170214.zip
    should be in the pictures tomorrow.
    Video T2-MI Octagon SF4008 OpenATV 6.0 4.8 east 12188, 12341
    http://www.dailymotion.com/video/x5bxr62
    T2-MI-4.8east MIS 10 20 30stpierre
    http://www.dailymotion.com/video/x5c...0stpierre_tech
    OPENSPA 7.0.002 Octagon SF4008 Image
    https://openspa.webhop.info/#Descarg...tagon%2FSF4008
    Satdreamgr-4.0 Octagon SF4008 Image
    http://sgcpm.com/satdreamgr-images-e...ctagon/sf4008/
    EGAMI Octagon SF4008 Image
    http://image.egami-image.com/index.php?open=sf4008
    Sat + DVB-C + DVB-T2 Nutzung mit OpenATV 6.0 auf OCTAGON SF4008 4K UHD
    https://youtu.be/hKMxTUTMYtU
    SGC image Octagon 4008 T2MI for 4.8 ° east:
    1-sgc image install
    DOWNLOAD:http://sgcpm.com/satdreamgr-images-e...ctagon/sf4008/
    2-online update via menu
    3-with telnet the lower commands always enter after the other
    Opkg update
    Opkg upgrade
    Opkg install astra-sm
    reboot
    4-satellites.xml and copy / etc / enigma2 copy and restart octagon
    Download:http://www.satdreamgr.com/forum/show...OR-MULTISTREAM
    5- via menu satfinder frequency of 12341 and 12188..how Look in picture ..
    no search only LOOK
    https://s29.postimg.cc/w4zufxitj/4_8...41_H_IS_30.jpg
    https://s29.postimg.cc/9ubzfyljb/4_8...88_H_IS_20.jpg
    6-download this file
    DOWNLOAD:https://mega.nz/#!GZtXzawS!GZZ6RsY18...cm8P3W_XjGi8IA
    7-over telnet enter the commands.
    Init 4
    rm / etc / enigma2 / lamedb *
    from downloadfile from post 6.
    astra.conf in / etc / astra copy
    lamedb and userbouquet.zeonbud.tv in / etc / enigma2 copy
    8-reboot important
    all satellite stations are deleted, New search
    video with result:
    T2-MI PLP Multistream Astra 4A SES 5 4.8°E East Ost Sirius OCTAGON SF4008 4K UHD DVB-S2X 12188 12341 H 30000 Stream 10-20,30,40 ZeonBud.
    https://youtu.be/blr84-Ez11U
    Thanks to MCelliotG, Athoik SGC Team
    OpenESI-4.0 Octagon SF4008 Image
    http://www.openesi.eu/images/images/...p?dir=Octagon/
    these commands are rong
    Opkg update
    Opkg upgrade
    reboot
    ok its
    opkg update
    opkg upgrade
    opkg install astra-sm
    reboot
    ---------- Post added at 12:53 ---------- Previous post was at 12:45 ----------
    wrong and this
    Init 4
    this its ok
    init 4 rm / etc / enigma2 / lamedb *
    19 Post(s)
    @bonou2 --- cineva minte ... fie OpenATV fie prospectul !
    inclin sa cred ca baietii de la OpenATV ...
    ... de aici nu prea se vede 1 Gb de RAM !
    Driver (Driver) update Octagon SF4008 - 17.03.17:
    Testing via FTP: file linuxtv.ko to lib / modules / 4.1.37 / extra copy and restart the box.
    Download drivers for:
    5.x Images
    http://octagon-forum.eu/test-team/sf...0-20170317.zip
    6.x Images
    http: // octagon-forum .eu / test-team / sf4008 / sf4008-drivers-4.1.37-6.3.0-20170317.zip
    20170317
    -. Fixed on the SNR% issue (SF4008-I-55)
    . Improve dB displaying.
    -. Fixed grep issue (SF4008-i-65)
    -. Fixed minor bugs on tuner
    . SNR% display improved.
    -. DB display.
    -. Reading / proc / stb_values ​​blockage grp fixed.
    -. Div. Small tuner improvements
    Driver (Driver) update Octagon SF4008 - 22.03.17:
    5.x Images
    http://octagon-forum.eu/test-team/sf...0-20170322.zip
    6.x Images
    http: // octagon-forum .eu / test-team / sf4008 / sf4008-drivers-4.1.37-6.3.0-20170322.zip
    20170322
    -. DB Value corecture
    -. DB (value) Display corrected
    New] OE-A 4.0 [oe-alliance-core]
    [Update] Egami-base 1.0r2
    [Update] Egami-enigma2 1.0r6
    [Update] GStreamer 1.11.2.1
    [Update] Python 2.7.12-r1.3
    [Update] GCC 6:20
    [Update] Blibc 2.2.4
    [Update] Bitbake 1:32
    [Update] Multistream
    [Update] EGAMI Multiboot
    [Update] EGAMI SpeedUP
    [Update] Enigma Wizard
    [Update] oDreamy-FHD
    [Update] Plugins
    [Update] Drivers some available decoders
    [Update] Multi Tuner function boxes with DVB-C / T (Hybrit Tuner)
    [Update] ATSC tuner and EPG for USA and other countries
    [Update] Busybox 1.24.1-r0.34
    [Update] Opkg 1:0.3.3-r0.2
    [Update] Smbclient 3.6.25-r7
    [Update] initscripts-functions 1.0r155.8
    [Update] tuxbox-common -git
    [Update] netbase 1:5.3-r1
    [Update] update Polish translation
    [Update] update French by pr2
    [Update] aio-grab - git
    [New] HD51 has KODI 17.0
    [New] Bootlogo EGAMI 8.0
    [Fix] Parental Control
    [New] [EpgSelection] change for free or repeated timer added
    [New] [InfoBarGenerics.py] Fixed that sometimes the InfoBar didn't show
    [New] Selecting the high badwith resolution for hls streams
    [Fix] [ScanSetup] Send 5v enable option to DVB-T2 blindscan
    prin atasarea unui mic ventilator pe radiatorul procesorul se reduce temperatura
    multumin/thanks to :@rysiuhelix
    Multistream 16APSK Intelsat 33E 904 60.0°E OCTAGON SF4008 4K UHD NURTS Bulgaria BTV NOVA BNT
    https://youtu.be/i5Btrp_Id-E
    How to change Menu Style in pbnigma 6.0 - OCTAGON SF4008 4K UHD Triple DVB-S2X E2 Linux Enigma2
    https://youtu.be/ZhQ3va9W920
    10 Jul 2008
    Inlocuire imagine octagon-sf4008-4k prin cablu RS-232
    Post
    @ghita_49, la Octagon schimbarea de imagine se face cu stick-ul, tu de ce ai vrea sa o schimbi cu cablu?
    by @antenutze
    - se formateaza un stic USB in FAT 32 pe care se copiaza fiserul SF4008 dupa ce a fost dezarhivat si incarcat dn linkul de mai sus;
    - se introduce sticul intr-o mufa USB din fata sau dn spate si se stinge aparatul de la butonul POWER OFF dn spate;
    - se apasa si pe butonul POWER ON din spate si cand pe ecran apare secventa de boot se apasa pe butonul ON din fata
    - cand apare pe ecran RootFille System se elbereaza butonul ON din fata si se lasa aparatul sa isi faca incarcarea si instalarea softului pana ce pe ecranul TVului apare sigla OpenATV 6.0.
    Inutil sa mai amintesc ca orice manevra sau intrerupere de curent va poate face nefunctional aparatul.
    PS. @ghita_49 , tu unde ai vazut mufa rs232 ?
    https://www.imageupload.co.uk/image/BsHM
    DVB-S2X Thor 5,6,7 (0.8W°W) - CD S2X Test Channel Conax - OpenEight 6.0 OCTAGON SF4008 4K UHD
    Thor 5,6,7 Frequenz 12399 Polarisation H Horizontal Europe DVB-S2X 8PSK SR Symbolrate 30000 FEC 25-36
    https://youtu.be/r7VCin3gETI
    DVB-S2X Thor 5,6,7 (0.8W°W) - CD S2X Test Channel Conax - OpenATV 6.0 OCTAGON SF4008 4K UHD
    Conax Telenor 0.8w 0.8°west 0.8 grad 1°W 1 grad Intelsat 10-02 MPEG-4 D.Shimoni Atlantic
    E2 Enigma2 Linux
    https://youtu.be/Xtn7Cw8ibk0
    pbnigma - How to easly mount your USB-HDD - OCTAGON SF4008 4K UHD DVB-S2X
    https://youtu.be/cIsujGOlQTw
    Thumbs up Enigma2-plugin-extensions-ts-sateditor_2 .4_all.zip
    TS-satEditor 2.0.0 enigma2 plugin
    early March, I had mentioned this small satellite-editor program.
    He was very good, nothing could be done with Multistream.
    I asked the developer Dimitrij from Openpli.org if this development would be possible.
    After four weeks of work comes a new version 2.4 with MIS input capability.
    Have tried immediately (45 ° East): works perfectly,
    So many thanks to Dimitrij for his work
    Site found and customized, satedit.py runs
    under / usr / lib / enigma2 / python / plugins / SystemPlugins / TSsatEditor line 365,366
    of
    code:
    1:
    2:
    Self.l.setFont (0, gFont ('Regular', 20))
    Self.l.setFont (1, gFont ('Regular', 15))
    after
    code:
    1:
    2:
    Self.l.setFont (0, gFont ('Regular', 15))
    Self.l.setFont (1, gFont ('Regular', 10))
    https://www.sendspace.com/file/p45p47
    14 May 2011
    7 Post(s)
    Salut. Te rog Bonou2 sa-mi spui de unde ai achizitionat Octagon ?
    NEU: Treiber (Driver) update Octagon SF4008 - 15.05.17
    Testen per FTP: Datei linuxtv.ko nach lib/modules/4.1.37/extra kopieren und Box neustarten.
    [Release Note]
    What's New :
    - Issue [SF4008-i-75] mute symbol in standby is fixed
    - Issue [SF4008-i-56] viasat ci modul is fixed
    INFO: 4 x VTuner (USB) possible (4 x Virtueller USB Tuner moglich)
    OCTAGON GERMANY Support
    6.x Images
    https://www.sendspace.com/file/5pr4tc
    NEU: Treiber (Driver) update Octagon SF4008 - 17.05.17
    [Release Note]
    1. the number of supported vtuner : 4 -> 8
    --> Info: Total 11 Tuners Support at same time!
    2. [SF4008-I-71] ATSC type not accepted by vtuner is fixed
    3. [SF4008-i-77] DVB-T2 is not accepted by vtuner is fixed
    4. Minor bug fix.
    1. VTuner Support auf 8 erhoht (VTuner: virtueller USB Tuner)
    --> Info: Gesamt gleichzeitig 11 Tuner Support!
    2. ATSC Support fur VTuner USB
    3. DVB-T2 (2G, aka) Support fur VTuner USB
    4. Diverse kleine Fehler behoben
    6.x Images
    https://www.sendspace.com/file/h8el7h
    [Release Note]
    4. Minor bug fix.
    6.x Images
    10 Jul 2008
    In"cartea tehnica",de fapt o brosurica a aparatului scrie : RS-232 Cable and other accessories can be purchased separately.
    Asta m-a facut sa cred ca la acest aparat la oareceva,ce nu cunoastem noi deocamdata,se foloseste si un adaptor null-modem.
    Poate spune cineva de aici de pe forum unde este produs Octagon SF4008 4K?
