Thanks Thanks:  16
Likes Likes:  14
Dislikes Dislikes:  1
Page 1 of 9 12345 ... LastLast
Results 1 to 15 of 124
Thread: OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver
    Thumbs up OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver
    The long wait has now come to an end!
    Octagon proudly presents the new 4K UHD receiver SF4008.
    3x tuner selection in the versions with the new standard DVB-S2x, DVB-C and DVB-T2 HD, as well as USB 3.0 port,
    Gigabit LAN interface, HEVC265 video decoding will open new prospects for the full spectrum of new 4K experience to enjoy.
    Experience a new 4K feel with the new Octagon SF4008.
    HARDWARE:
    - Broadcom chip BCM 7251S
    - 12K DMIPS (12000) processor
    - 2 x 1700MHz Dual Core (2 x 1.7GHz)
    - NAND Flash 4GB eMMC
    - RAM 1GB DDR4
    - HVEC / H.265 video decoding
    - DVB-S2X Standard Support
    TUNER:
    - DVB-S2x DUAL (DVB-S2X support) Tuner
    - DVB-C / T2 DUAL
    - As PNP version, up to 3 tuners maximum possible
    FRONT (FRONT):
    - VFD dot-matrix display white 16 digits
    - Power button / off in Touch
    - CI module bay
    - card reader
    - 1 x USB 2.0 port
    BACK (REAR):
    - power switch
    - Dolby S-PDIF input
    - 2 x Plug & Play tuner input
    - LAN RJ45 Gigabit Support (1000Mbps) network connector
    - 2 x USB 2.0 port
    - 1 x USB 3.0 connector
    - HDMI 2.0 connection
    INSIDE (inside):
    - HDD 2.5 inch SATA
    UNDER GROUND (Bottom):
    - With 4x rubber feet
    DIMENSIONS:
    - 260 x 135 x 45mm
    Tuner information for OCTAGON SF4008 UHD 4K 2160p Triple E2 Linux Receiver
    General Tuner Info:
    - Number of tuners Slots: 2
    - Available Tuner:
    - DUAL (2xEingänge)
    - -> DVBS S2 Dual (DVB-S2X Support)
    - -> DVBC -T2 Dual
    - unit or processor can control up to 3 tuners simultaneously!
    - tuner slot 1 detects 2 tuners such as DVB-S2 or DVB-C / T2
    - tuner slot 2 detects 1 tuner as DVB-S2 or DVB-C / T2
    Tuner Combinations:
    - Tuner Slot 1: DVB-S2 tuner Slot 2: empty -> 2xSAT available
    - Tuner Slot 2: DVB-C / T2 tuner Slot 2 empty -> 2xDVB-C / T2 available + C- T2 Soft 3xTuner usable mi5V control!
    - tuner slot 1: DVB-S2 tuner slot 2: DVB-C / T2, -> + 2xSAT 1xDVB-C / T2 used
    - tuner slot 1: DVB-C / T2 tuner slot 2: DVB-S2 -> 2xDVB-C / T2 + 1xSAT available
    - tuner slot 1: DVB-S2 tuner slot 2: DVB-S2 -> 3xSAT available
    - tuner slot 1: DVB-C / T2, Tuner Slot2: DVB-C / T2, -> 3xDVB-C / T2 can be used
    PACKAGE:
    1x Octagon SF4008 4K UHD Receiver depending on desired tuners
    1x Remote Control
    1x Manual (German / English)
    1x HDMI cable
    2x batteries (AAA)
    1x power supply
    Available from: 30.12.2016 (Pre-order available)
    OCTAGON SF4008 4K UHD 2160P DVB-S2X first look OpenATV
    https://www.youtube.com/watch?v=lBwTkB2Bc4o
    https://www.youtube.com/watch?v=cZ3kPTE55XI
    OCTAGON SF4008 UHD 4K 2160p Triple E2 Linux Receiver - Video 2 (DVB-S2X Support)
    https://www.youtube.com/watch?v=bxm8G57f5cM
    OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver with 2x Sat (DVB-S2) tuners----------------------------------------------------- € 210.00
    OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver with 2x Hybrid (DVB-C / T2 / T2 HD) tuners----------------------------------------€ 219.00
    OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver mit 2x Sat (DVB-S2) + 1x Hybrid (DVB-C/T2/T2 HD) Tunern-------------------------€ 245.00
    OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver mit 3x Sat (DVB-S2) Tunern-------------------------------------------------------€ 250.00
    OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver mit 2x Hybrid (DVB-C/T2/T2 HD) + 1x Sat (DVB-S2) Tunern-------------------------€ 250.00
    OCTAGON SF4008 4K UHD 2160p Linux E2 Receiver mit 3x Hybrid (DVB-C/T2/T2 HD) Tunern--------------------------------------------€ 259.00
    OCTAGON SF4008 4K UHD DUAL Twin DVB-S2X Tuner H.265---------------------59,90 €
    OCTAGON SF4008 4K UHD DUAL Twin DVB-C/T2 Tuner H.265--------------------64,90 €
    The new SF4008 UHD 4K comes with some highlights.
    The new Octagon SF4008 UHD 4K is already in a few weeks to enrich the still manageable market at Ultra-HD receivers. The box will be equipped with a BCM 7251S main processor with 2x 1700 MHz power. Four gigabytes of Nand-Flash and a gigabyte of RAM ensure proper storage. As is usual for an ultra-HD receiver, the device will, of course, master the HVEC / H.265 video decoder.
    In addition to various external interfaces, including one for USB 3.0 usage, the device will also support internal hard disks. 2.5-inch SATA data carriers are to be used. At the front, a 16-digit dot-matrix display is to transmit transmitter names and additional information to the user. In addition to free TV signals, encrypted offers with the new Octagon receiver are also available thanks to CA and CI interfaces.
    New and unique in the market is the support of DVB-S2X signals. With this device, packets which are transmitted in the new DVB transmission standard can also be received. These have already been tested intensively by the OpenATV team, who have the receiver available as a preliminary model for software development.
    The SF4008 UHD 4K, as well as a majority of the Octagon devices, will use the Linux operating system Enigma2. Several teams are already developing the images for the cheap UHD box. The start of sales will start in December. The entry-level model with Twintuner will cost just 200 euros, other variants are planned with up to three tuners.
    Source DF http://www.digitalfernsehen.de/Neuer....146469.0.html
    DVB-S2x is built with demod and tuner. Demod is known SI21662-D60 but tuner yet.
    This is the document for the Si21662-D60.
    http://www.silabs.com/Support%20Docu...-D60_short.pdf
    By Si21662-D60 one can very well build a dual tuner.
    The Si21662-D60 has two demodulators.
    The innovation behind DVB-S2X
    whitepaper
    DVB-S2X Demystified
    RO 5% RO 20%
    low roll-off: 5/10/15%
    DVB-S2 roll-off to 5% or 10 % or 15%
    RO RO 20% 5%
    The successor to the DVB-S2 standard is a combination of
    innovative technologies did improve overall efficiency over
    satellite links.
    The technologies Involved in DVB-S2X are:
    • Low roll off, smaller carrier spacing and advanced filter
    technologies
    • MODCOD and FEC upgrades (more granularity,
    adding 64, 128 and 256APSK, Improving FECs &
    MODCODs and Differentiating linear & non-linear
    MODCODs)
    • Wideband implementation.
    • Very Low SNR MODCODs to support mobile
    (land, sea, air) applications
    • Bonding of TV streams
    • Additional standard scrambling sequences
    A few info about the test channel.
    http://www.isatdb.com/de/channel-fre...t-stream--lqyl
    Thumbs up OCTAGON SF4008 4K UHD------poze
    My first pictures of SF 4008
    - Here are some images from inside SF 4008
    * Before installing the hard drive
    * After installing the hard drive
    toate pozele apartin lui user @SSD
    Boot time at power switch on 19 seconds.
    Reboot user interface (Gui restart) 4 seconds.
    Front display: white, with multi-function (icons support).
    Front upper portion: Gold
    TEST`s and Image Info:
    - Image OpenATV, Open Eight, OpenHDF, OpenNFR, OpenPLi, Pbnigma, Egami, TDW-AT, HDMU , more to follow ..
    - PIP HD Support OK .
    - HbbTV available mid November.
    - Wake On LAN - OK
    - GitHub:
    ->oe-alliance-core / meta-brands / meta-octagon at 3.4 * oe-alliance / oe-alliance-core * GitHub
    - recording UHD Stable
    - Play UHD Stable
    - Timeshift OK
    - PIP HD + Up + Timeshift combination OK
    - SSD HDD and SATA HDD OK. (tested brands such as SanDisk and Western Digital)
    - Play, MKV H.265, DTS, etc. OK
    - Multiple RCU Support OK (Multi Remote Support OK)
    - CIP TEST OK
    - DVB-S2X TEST OK
    - ACL Alphacrypt module test OK
    -. .. more info follow .... OCTAGON GERMANY
    Frumos nimic de zi , poate si ''mai'' iute la bootare ( comparativ cu un hdd ) , dar totusi nu e ''pacat'' de acel ssd ?
    Din ''experienta'' mea cu media playere + hdd-uri de 2.5" pana la urma din varii motive , hdd-ul va deveni ''sursa de prb'' in timp
    Poate daca il tine pornit 24/24 si 7/7 , atunci....... , insa la porniri repetate in timp......
    E folosit pentru record acel device despre care spui, nu pentru boot !
    Si la K1 tot pe un SSD am reusit sa fac record la canalele 4k.
    Zildan , ai incercat sa bootezi k1-unul avand conectat un ssd in locul hdd-ului ?
    Sa vezi ce diferente sunt la timpii de bootare si apoi in timp mai vorbim
    Normal ca pt inregistrari ( printre alltele ) e folosit , insa se "simt" practic si timpii de boot-are intre un ssd si hdd
    konstantine's Avatar
    bono u2 a fost destul de clar in postare : ssd e folosit pentru boot .
    " Boot time at power switch on 19 seconds.
    Reboot user interface (Gui restart) 4 seconds. "
    Si aici ,sa speram ca mario , inceteaza cu flame-ul !
    Alooo ! Aparatul asta nu are Linuxu pe SSD, si deci nu boot-eaza de pe el.
    K1 nu cere timp suplimentar la boot cand are ssd pus pe USB.
    OCTAGON SF4008 4K UHD jetzt zum Vorbestellen (kaufen, advance order, booking, sipariş satın al) E2
    https://youtu.be/m0a1e8O1gjQ
    OpenATV 5.3 OCTAGON SF4008 4K Image
    http://images.mynonpublic.com/openat...hp?open=sf4008
    23 May 2007
    As dori sa stiu daca acest receiver suporta atat CCcam cat si Oscam?
    19 Post(s)
    Doar Oscam ! asa este pe toate receptoarele 4K !!!
    23 May 2007
    Am inteles!Multumesc!
    Multistream TEST OCTAGON SF4008 Astra 4A 4.8°E SES 5 Sirius MIS 12341
    Image: OpenATV 5.3 21.Dez.
    Treiber: 22-12-2016 (Über zeigt falsch an, da per FTP kopiert)
    Test auf 4.8E TP 12341
    5w, 12.5w, wird noch getestet.
    Test on 4.8E TP 12341
    5w, 12.5w, will be test soon.
    Multistream TEST OCTAGON SF4008 Astra 4A 4.8 ° SES 5 Sirius MIS 12341
    Driver: 22-12-2016 (About displays incorrect because copied via FTP)
    Test with OpenATV 6.0 with PLS Mode & Pls Code tomorrow.
    https://youtu.be/LqFzgKIai9U
    Stream ID - Pls Mode and Pls Code Enter Menu Image
    Stream ID - PLS Mode und PLS Code Eingabe Menu Bild
    Multiple Remote control support SF4008
    https://youtu.be/Z_2TDyDTYbo
    Communication:
    launch / delivery OCTAGON SF4008 4K UHD
    19. Dezember 2016
    Verkaufsstart / Auslieferung OCTAGON SF4008 4K UHD
    Ab dem 27.12.2016 werden wir die ersten Geräte ausliefern.
    Wegen den Feiertagen und dem Weihnachtsgeschäft kann es bei der Lieferung evtl. zu Verzogerungen kommen, bitte haben Sie dafur Verständnis.
    Sales start OCTAGON SF4008 4K UHD
    Dear Customers,
    From 27.12.2016 we will start deliver the first devices.
    Please understand that there may be delays in the holidays from DHL and forwarder.
    Sayin Musteriler,
    27.Aralik tarihinden itibaren SF4008 Modelimizin sevkiyatina baslanacaktir.
    Önumuzdeki noel tatilleri yuzunden kargoda olusabilecek gecikmelerde simdiden anlayisiniz icin tesekkur ederiz.
    OCTAGON GERMANY
    Dr.Dish Magazin Folge 47:
    OCTAGON SF4008 4K UHD E2 DVB-S2X 2160p & Messgerät Satfinder SF518 LCD UHD 4K HD
    https://youtu.be/-y2j4-bodtM
    Multistream Test Eutelsat 5 West A (5°W) OCTAGON SF4008 4K UHD (DVB-S2X) - ACM VCM PLS MIS
    https://youtu.be/5nk9xjp4If4
    Multistream Test Eutelsat 12 West B (12.5°W) OCTAGON SF4008 4K UHD (DVB-S2X) - ACM VCM PLS MIS
    https://youtu.be/ctwT4PJAKCs
