Results 1 to 5 of 5
Thread: TBS5927 Professional DVB-S2 TV Tuner USB
    Thumbs up TBS5927 Professional DVB-S2 TV Tuner USB
    TBS5927 is a Professional level digital satellite TV Tuner box with USB2.0 connection to PC.
    TBS5927 supports not only normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite receivers, but also ACM, VCM, Multi Input Stream, 16APSK and 32APSK mode,
    Multiple Generic Stream, Combined Single Generic &Single TS, which most satellite receiving devices can’t support.
    The built in hardware blind scan feature allows scanning of unknown satellite transponder with symbol rate as low as 200ksps, while most satellite receiving device can receive no less than 1Msps symbol rate. With use of dedicated TBS tools, those special streams can be captured. Both Windows BDA driver and Linux driver are provided.
    Main Features:
    EUMETCast Compatibility
    DVB-S2/S Transponders Receiving
    CCM, VCM,ACM and Multi Input Stream Support
    Watch & record satellite TV/ radio programs onPC
    Wide range symbol rates support from 200Ksps to 45Msps
    High-speed Data download via Satellite
    Unicable/One Cable compatible
    Blindscansupport
    High reliability
    Specification
    Receiving Frequency 950~2150 MHz Tuning Range
    Input level -69~-23dBm
    Demodulator Yes
    Symbol Rate:
    DVB-S QPSK 0.2~45Msps
    DVB-S2 QPSK/8PSK 0.2~45Msps
    DVB-S2 CCM ACM VCM QPSK+1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
    8PSK+3/5, 2/3, 3/4, 5/6, 8/9, 9/10
    16APSK+2/3, 3/4, 4/5, 5/6, 8/9, 9/10
    32APSK+3/4, 4/5, 5/6, 8/9, 9/10
    DVB-S QPSK+1/2, 2/3, 3/4, 5/6, 7/8
    Data Burst & Tone Burst Support
    DiSEqC2.X and Motor Support
    Carrier Capture Range: ±10MHz ±10MHz
    Applications Data receiving
    IPTV streaming
    Media monitoring
    Digital content distribution
    Power consumption
    Input/Power: +12/
    temperature 0~60℃
    System Requirements Windows 2000/XP/Vista/7/8/10 or Linux
    Available USB2.0 Port
    Satellite Dish and LNB
    Dimension
    TV tuner Boxsize 12x9x2 (cm)
    Net weight 190g
    Gift Box Size 16x16x8(cm)
    Weight 615g
    Package Contents 1 x TBS5927
    1 x Power adapter
    1 x USB cable
    toate pozele apartin lui user @satosk
    45 Post(s)
    Dupa cam 2 saptamani de asteptare la vama Otopeni a ajuns si la mine tunerul TBS 5927. Dupa problemele obligatorii cu vama am probleme si cu tunerul, cred ca este defect dar nu am nicio sansa sa-l returnez in China. Ventilatorul este cam zgomotos dar problema mare este cu driverele. Ultima versiune 1.0.0.4 imi blocheza laptopul daca folosesc dvbdream, ecran albastru, hardware conflict si restartare cam in 7 cazuri din 10. Versiune de driver anterioara 1.0.0.3 nu mai blocheaza calculatorul dar de fiecare data la pornirea calculatorului driverul trebuie reinstalat, altfel nu-l vede. Totusi problema mare este ca placa nici nu simte semnalele Multi Input Stream. Nu vede nimic in plus fata de vechea TBS 5925 sau versiunea simpla combo T/C/S TBS 5520. Cred ca problema este izolata, vreau sa mai comand alt tuner dar din Europa. A intalnit cineva aceleasi probleme sau este un caz izolat cel al meu?
    eu nu detin aceasta placa respectiv TBS5927 si nu pot sa ma pronunt in legatura cu problemele intampinate de dvs
    luati legatura cu cei de la TBS si expune-ti ce probleme intampinati
    in caz ca placa este defecta cei de la TBS va trimit alta
    https://rickcaylor.websitetoolbox.co...eivers-8339856
    @capsmvp
    2 things that bug me about the tbs 5927.
    1. Channel changes are slow with dvbdream.
    2. I have to reinstall the driver every time I turn on my windows 10 computer. It shows in devices with a !
    Would love to have a solution to these 2 issues. Thanks.
    @crazycat
    1. dvbdream BDA module itself buggy and slow 😉
    2. need connect to usb 2.0 port
    45 Post(s)
    de trimis inapoi placa la hong kong si apoi iarasi in romania este mult prea complicat, din cauza formalitatilor vamale. multumesc pentru suport, se pare ca problema mea este asemanatoare cu cea semnalata de @capsmvp. intradevar doar la dvbdream aparea hardware error iar placa este pe port usb 3.0. @crazycat are dreptate, trebuie sa testez pe un usb 2.0 dar laptopul meu nu are decat 3 porturi usb, toate 3.0
