Thanks Thanks:  40
Likes Likes:  22
Results 16 to 30 of 56
Thread: VITMOD-LE K1 Plus S2/T2-C
    94 Post(s)
    Pe scurt in Neutrino se poate porni OSEmu local astfel:
    1. Copiati OSEmu in /storage/vitmod/wicard/ apoi setati 755 la proprietati
    2. Editati /storage/vitmod/wicard/start_wicard.sh (de preferat cu Winscp ) sa arate astfel:
    #!/bin/sh
    # Starts Wicardd emu
    . /etc/profile
    export PATH=$PATH:/storage/vitmod/wicard
    /storage/vitmod/wicard/OSEmu -b -c /storage/vitmod/wicard/ -a emu:emu -p 2222
    /storage/vitmod/wicard/wicardd -c /storage/vitmod/wicard/wicardd.conf
    3. Adaugati in /storage/vitmod/wicard/wicardd.conf
    [reader]
    active = 1
    name = osemu
    type = cs357x
    account = emu:emu@127.0.0.1:2222
    provider = 1801:002011,002111,000000
    4. Adaugati 1801 la prio in acelasi fisier:
    [filter]
    name = dvb
    rule = caid=2600;accept
    rule = caid=0100,1803,0B02,0B0F,0B01,0BAA,090D,090F,09CD;accept
    rule = caid=0500;ident=040600,060A00,060C00,040620,032500,040810,041700,042300,042800,043800,050C00,041200;accept
    rule = caid=098C;ident=000000;accept
    rule = caid=0652;chid=15,FFFF;accept
    rule = caid=1880;ident=002011,002111,000000;accept
    rule = caid=1801;accept
    rule = caid=1843;ident=003411,008011,000000;accept
    rule = caid=1803;ident=007001,007101,000000;accept
    rule = caid=4ae1;ident=11,14;accept
    rule = reject
    5. Copiati in /storage/vitmod/wicard/ fisierul SoftCam.Key.
    Attached Files Attached Files
    94 Post(s)
    VITMOD-LE-K1plus-1.1
    Kodi updated to version 17 RC4
    Added skin Aeon Nox
    Added playlist Torrent TV with http://super-pomoyka.us.to/trash/ttv-list in IPTVsimple, to play it you need to run AceStream
    Fixed EPG display in IPTVsimple
    AceStream updated to version 3.1.14.0
    Updated kernel to version 3.14.79
    Fixed playback of some mpeg2,4, h264, vc1 medafaylov
    Fixed switching between DVB-S / S2 and DVB-T / T2 in the Neutrino
    Reduced volume level for AC3 in Neutrino
    Fixed startup script Neutrino
    Imaginea o scrieti pe SD card cu win32diskimager
    Am reusit sa traduc o documentatie de wicardd pe care o aveti in atasament
    94 Post(s)
    Pentru a configura Neutrino incepem cu a trece Kodi in engleza:
    Acum startam Neutrino:
    94 Post(s)
    94 Post(s)
    94 Post(s)
    Acum sa Configuram VDR
    94 Post(s)
    94 Post(s)
    Dam un restart pentru a repornii emulatorul !
    94 Post(s)
    Setarile OSEmu de aici merg si in VDR daca e configurat ca mai sus.
    Neutrino merge mai "curat" decat VDR-Kodi dar nu are suport de subtitrare.
    Poate reusesc sa inteleg care e problema uneori in VDR-Kodi cu canalele codate.
    ---------- Post added at 18:08 ---------- Previous post was at 17:16 ----------
    Efectiv "nu deschide" anumite canale HD desi in logul wicardd apar ca "rezolvate". Cred ca e o problema de VDR.
    In Neutrino deschide perfect, evident fara subtitrare DVB.
    Am observat ca era doar partial tradusa fila Wicardd FAQ, o atasez aici:
    94 Post(s)
    VITMOD-LE-K1plus-1.2
    Fixed incorrect work of some tuner set-top boxes
    Added support for AAC audio for DVB channels Neutrino
    Added audio track selection for IPTV channels Neutrino
    Kodi updated to version 17.0 final
    04 Feb 2017
    Neutrino The tuner works very well driven!
    Wicardd support is not good. If there is an OSCAM better!
    94 Post(s)
    wicardd-armv7a Version 1.19 (2015-12-28) (beelive)
    replace /storage/vitmod/wicard/wicardd
    chmod 755 /storage/vitmod/wicard/wicardd
    * Server termination of the current client session after a password change
    * DVBAPI update API VDR, support the old and new versions of the plugin vdr-dvbapi-plugin
    * CS378x restored work protocol
    + LOG safelog = 1 does not output the private data in the log
    * Reader tuxbox fix initialization Conax card c PTS
    * Reader CCCAM fix memory leak
    + Server all outgoing packets POLLOUT
    * Reader Irdeto crash on ecm_len> 0x100
    * Reader Conax pincode sending an unsuccessful decoding
    - Core batch module abolished
    + Server added Command Line Interface
    + Reader Conax force_caid option
    + Reader option date_base NDS / Irdeto base date
    * DRE2 support new group EMM
    + DVBAPI camd_socket_file option to use the specified socket, the default /tmp/camd.socket
    * Reader AmLogic corrections for Spark 2
    * Cache caching algorithm changes (smart hash)
    + Core native version for Windows
    + Core support arm eabihf (solo4k)
    + EMU PowerVu algorithm implementation PowerVu
    04 Feb 2017
    I have replaced the run, but still no improvement!
    Can only link to a server, a CA.
    Can not link two servers.
    And even some CA ID can not be identified at all.
    I still want to have an OSCAM run!
    AC3 sound pause, image distortion.:饮料:
    09 Feb 2007
    Bucharest
    Poate nu am intles eu prea bine...aceasta imagine, este pentru K1 + varianta DVB-S2/T2 insa poate reda si DVB-C ? Sau sunt variante cu hardware DVB-C ?
    17 Jan 2008
