Thanks Thanks:  17
Likes Likes:  39
Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 31 to 45 of 122
Thread: Oscam emu powervu
    merge fara nici o problema e ca si cum te uiti la canalele de satelit....sau IPTV..fara a consuma banda de net ..nu e nici o diferenta
    eu prefer metoda asta...e curata...nu e nici o diferenta...fara sa mi modific config de oscam cu o linie...atat tot
    cine imi poate confirma daca PPTV de pe 4.8...merg?
    multumesc
    deci nu stie nimeni de PPTV???
    30 Dec 2008
    nu merg. Arata ca deschide, dar ecranul e negru
    17 Jul 2008
    In Tara
    [streamrelay]
    stream_relay_enabled = 0
    [dvbapi]
    extended_cw_api = 1
    trebuie sa aveti asta in oscam.config
    si merge...
    daca tot ecran negru,schimba ti imaginea cu una cit mai recenta.
    95 Post(s)
    Default Oscam emu powervu
    K3 face AU si la astea.
    Nici nu stiam de ele!
    Dai pe canal, si dupa 1 -5 minute il deschide.
    Apoi gasesti keya pusa de le la locul ei in emu intern.
    Standard RSP member ag.laur's Avatar
    RO
    vu+zero4k,octagon sf8008
    29 Sep 2017
    Bucharest
    Thumbs up Latest OScam/EMU arm Vu+ Solo4K/Uno4K/Ultimo4K
    New very stable oscampowervu11399 softcam.keys and constant.cw included Powervu opens directly from channel list
    enigma2-plugin-oscampowervu-arm_Vti-11399_all.ipk
    Código:
    https://mega.nz/#!HF1j3LKB!Vt37z3VQR...rR2mrnkNfz5FCE
    enigma2-plugin-oscampowervu-arm_Vix-11399_all.ipk
    Código:
    https://mega.nz/#!DFcmlKKY!8VWvWBUGx...0jFbqs8vvNeqiM
    enigma2-plugin-oscampowervu-arm_Satdreamgr-11399_all.ipk
    Código:
    https://mega.nz/#!yI0l1R5A!_giHuTWLH...YVAMzEiKhyNm64
    enigma2-plugin-oscampowervu-arm_RuDream-11399_all.ipk
    Código:
    https://mega.nz/#!XdEEyQTJ!ue2s-stIG...WGHoMYcYAO_v28
    enigma2-plugin-oscampowervu-arm_Pure-11399_all.ipk
    Código:
    https://mega.nz/#!CFsBxKiL!h6GLokbef...mj8TIvVZQ0iQ-c
    enigma2-plugin-oscampowervu-arm_Original-11399_all.ipk
    Código:
    https://mega.nz/#!uUdHUB4L!ZhN5XIYer...MwWSIlfvTEivCg
    enigma2-plugin-oscampowervu-arm_OpenSpa-11399_all.ipk
    Código:
    https://mega.nz/#!ycFUVI6a!geNfAZzHe...3TwIYKlznxoO4Y
    enigma2-plugin-oscampowervu-arm_OpenPlus-11399_all.ipk
    Código:
    https://mega.nz/#!GNtzTASb!pw6MPhYRE...LVRRhaAwuILQaE
    enigma2-plugin-oscampowervu-arm_OpenPli-11399_all.ipk
    Código:
    https://mega.nz/#!6YtR0IxD!Uavg7p8rQ...gEDT1ai5cwW9Gs
    enigma2-plugin-oscampowervu-arm_OpenNfr-11399_all.ipk
    Código:
    https://mega.nz/#!aNEBnKYC!ouFhuxRPI...Ii1LrauL0DCcAk
    enigma2-plugin-oscampowervu-arm_OpenDroid-11399_all.ipk
    Código:
    https://mega.nz/#!SMkXiSqS!RIs0Clc5v...w7JKQUWsbMq2TU
    enigma2-plugin-oscampowervu-arm_OpenBlackHole-11399_all.ipk
    Código:
    https://mega.nz/#!OZ8z0Q7R!lKPDI1T29...kIw9pTTWs3-nqc
    enigma2-plugin-oscampowervu-arm_ItalySat-11399_all.ipk
    Código:
    https://mega.nz/#!fMFDWQDb!_zbLIqwOB...zFhEQDm-_vKEE4
    enigma2-plugin-oscampowervu-arm_BlackHole-11399_all.ipk
    Código:
    https://mega.nz/#!OYdUQK5b!_4ll3z6rT...G8vfh8lhevXIP8
    enigma2-plugin-cams-oscampowervu-arm_OpenAtv-11399_all.ipk
    Código:
    https://mega.nz/#!qccUFZoR!5Lg92X4OK...EeLjtpEEiWgIrg
    link uri criptate
    vad ca nimeni nu ma lamureste cu link urile astea...vroiam sa dau si eu jos .....dar na asta e
    revenind on topic....am gasit solutia simpla si curata de a vedea afn direct din emulator...ca si cum ar fi local...ecm time de fapt cache ...iar timpul este intre 0,008 si 0,012 ms..
    am luat toate postarile de config postate de unii si altii...am vazut o gramada de setari aiurea...si inutile ce nu au ce cauta in configurile voastre....posibil ca unii le au rezolvat..Doamne nu sant eu Mohamed...dar am sa postez stric ce trebuie facut..curat sa fie config vostru....
    revin cand am timp...
    ---------- Post added at 19:04 ---------- Previous post was at 18:20 ----------
    Rectific..totu este din cache...timpul de raspuns este intre 0,001 si 0,009 ms...nu exista ...ecm ok
    nu conteaza imaginea si receptoru......aiurea...
    testat in openpli.....o sa merg si pe atv...dar nu are nici o importanta...
    nu stiu cum e in share ca nu am cu cine testa
    RO
    eu asta folosesc pe un vu+ solo se v2 cu black hole 3.0.5A functioneaza perfect
    http://www.girlshare.ro/3490053144.6
    29 Sep 2017
    Bucharest
    Am pus configurile trimise de @mesteru in privat si merge brici dar...numai dupa ce am instalat si varianta de oscam folosita de el respectiv oscam r11399,in concluzie...multumesc frumos pentru tot @mesteru,
    merge cu orice oscam ...cu orice receptor....cu orice imagine....fara nici o setare aiurea si fara balarii in config dar fiecare isi face damblaua cum stie mai bine...
