Thanks Thanks:  10
Likes Likes:  24
Page 4 of 4 FirstFirst 1234
Results 46 to 58 of 58
Thread: Oscam emu powervu
  1. #46
    Standard RSP member Alin99's Avatar
    29 Sep 2017
    Bucharest
    Cu asta nu merge nici sa il bati @Laleauaneagra,incercat si curat,fara "balarii" cum spui tu, nu vrea nici de al dracu sa deschida...enigma2-plugin-softcams-oscam-11392_blackhole_armv7ahf-vfp-neon in schimb cu varianta de oscam al lui @Mesteru a luat-o din prima.
    Prime focus 1.90m Ukraina multifeed Astra 28E, Astra 19.2E-Hotbird 13E,Eutelsat 9B Offset 1.30m Terfin single LNB 1W,Vu+Solo2,EMP - Centauri DiSEqC Multimode Switch 8in+1
  2. #47
    Vad ca a facut K3 AU pe thor, e 01 cheie noua.
    Sh40, prime focus 1,5m si altele ...
  3. #48
    Administrator GIGABLUE laleauaneagra's Avatar
    da...da dar doar Atlantic a schimbat..restu la mine merge pe inca pe 00 abcd
    ---------- Post added at 14:36 ---------- Previous post was at 14:34 ----------
    Quote Originally Posted by Alin99 View Post
    am postat aici ce si cum...fara balarii...curat lacrima http://sateliti.info/showthread.php/32017-How-to-PV
    Lumină, mai multa lumină (Licht, mehr licht)” zise Goethe
    FEEL THE BLUE SPIRIT...GIGABLUE.NET
  4. #49
    cu scuzele de rigoare am reeditat toate linkurile in forma bruta
    am verificat toate se deschid
    succes tuturor
  5. #50
  6. #51
    se pare ca doar ATLANTIC a schimbat keya...si merge ok cu ce a de la nenea zildan....restu la mine inca merg pe cele vechi
  7. #52
    30 Dec 2008
    Am incercat sa fac setarile d-lui @laleaua dar n-am avut parte decat de blackscreen, chiar daca arata ca deschide
    Eu am lumina pe 15w, 1w, 4,8e etc, fara AFN si pptv cu urmatoarea configuratie: Vu Ultimo4k, BlackHole 304, oscam 11399
    Afn imi merg fara probleme din share.
    [reader]
    label                         = emulator
    protocol                      = emu
    device                        = emulator
    caid                          = 090F,0500,1801,0604,2600,FFFF,0E00,4AE1,1010
    detect                        = cd
    ident                         = 090F:000000;0500:000000,023800,021110,007400,007800;1801:000000,007301,001101,002111;0604:000000;2600:000000;FFFF:000000;0E00:000000;4AE1:000011,000014,0000FE;1010:000000
    group                         = 2
    emmcache                      = 2,1,2,1
    saveemm-unknown               = 1
    saveemm-u                     = 1
    saveemm-s                     = 1
    saveemm-g                     = 1
    emu_auproviders               = 0604:010200;0E00:000000;4AE1:000011,000014,0000FE;1010:000000
    [dvbapi]
    enabled                       = 1
    au                            = 1
    pmt_mode                      = 0
    request_mode                  = 1
    delayer                       = 60
    user                          = desired-user
    read_sdt                      = 2
    write_sdt_prov                = 1
    extended_cw_api               = 1
    boxtype                       = dreambox
    [account]
    user                          = desired-user
    au                            = 1
    group                         = 1,2
  8. #53
    ce face fiecare si cum....eu nu stiu....mai mult de ata nu pot face....
    ---------- Post added at 22:40 ---------- Previous post was at 20:56 ----------
    ma ajuta cineva cu o keye ptr discovery 12303.....mersi frumos
    ---------- Post added at 23:57 ---------- Previous post was at 22:40 ----------
    Sa lamurim....prin metoda descrisa de mine.....FUNCTIONEAZA DOAR AFN....restu de pe 1W...4.8E.....NIMIC....ca sa nu va chinuiti degeaba...de ce?inca nu imi dau seama dar pana la urma doar afn conteaza ptr mine...si nci asta asa de mutl
    ---------- Post added 14-02-18 at 00:17 ---------- Previous post was 13-02-18 at 23:57 ----------
    In schimb restu merg in STREAM...curat direct din keya din emulator....decodare directa......
  9. #54
    30 Dec 2008
    Hai sa pun cum imi merge mie
    in oscam.server
    [reader]
    label                         = emulator
    protocol                      = emu
    device                        = emulator
    detect                        = cd
    group                         = 2
    emmcache                      = 2,1,2,1
    in oscam.conf
    [streamrelay]
    stream_relay_enabled          = 0
    stream_emm_enabled            = 0
    [dvbapi]
    enabled                       = 1
    au                            = 1
    pmt_mode                      = 0
    request_mode                  = 1
    delayer                       = 60
    user                          = user
    read_sdt                      = 2
    write_sdt_prov                = 1
    extended_cw_api               = 1
    boxtype                       = dreambox
    in oscam.user
    [account]
    user                          = user
    au                            = 1
    group                         = 1,2
    Asta e configuratia pentru receptoarele cu procesor ARM (Ultimo4k, Solo4k etc)
    Pentru receptoarele cu procesor MIPS in loc de
    extended_cw_api = 1
    vom pune
    extended_cw_api = 2
    Pentru aceasta configuratie folosesc o conpilatie de softcam facuta de mine la repezeala din mai multe softcamuri, pentru ca pe un softcam nu mergeau decat discovery, pe altul doar afn, pe altul nu mergeau sis de pe 4,8 e , samd.
    Cu aceasta configuratie merg espn 15w, discoverys 1w, sis 4,8e, anumite canale cum ar fi SRG Swiss, ceva Biss.......... AM SCOS KEYLE AFN din softcam, pentru ca merge perfect din share fara alte balarii in config.
    Numai bine
  10. #55
    ptr afn local...merge fara nici o balarie postata pe toate forumurile....dar am postat deja la HOW TO PW...
    faci un reader de cache fara streamrealy...fara cwapi...il mai dai si in share ca si local....
    doar afn conteaza pana la urma..nici asta asa de mult restu e chiar can-can....cat si keyle din softcam
    asa cum spui ca iti merge din share...renunti la tot ca le vezi din share oricum si iti faci localul tau de afn.....fara nici o balarie si o setare in plus
  11. #56
    In alta ordine de idei..oscam emu o cam da in balarii...la general vb nu ma refer la pw....ma refer la share
    mai urmaresc dar trec inapoi la oscam 11399 unde totu e bine si frumos ptr 7 canale mediocre nu se merita
  12. #57
    23 Jun 2008
    A aparut vreun keyuploader mai nou, functional ?
  13. #58
    02 Sep 2010
    Earth
    Confirm, AFN duduie.
    Nu folositi ultima versiune de oscam, e putin parlita.
    folositi xxxx39.
