Thanks Thanks:  5
Likes Likes:  9
Dislikes Dislikes:  1
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: DM 920 4K Imagini
    30 Post(s)
    Default DM 920 4K Imagini/Drivere
    Ca sa nu fie ''ghivechiul'' asa mare , pt imaginiile acestui receptor 4K le voi posta in acest thread
    Dincolo sa fie pt discutii/rezolvari de prb/initieri
    Si pt inceput , un back-ul a unei imaginii Gemeni Project 3.3
    - Dreambox DM920 UHD 4K Gemini Project backup
    Las foto sa ''vorbeasca'' in locul cuvintelor
    - http://www.mediafire.com/file/ofkhfz...aumixio.tar.gz
    Imaginea folosita de mine in prezent - NEW DREAM-ELITE-6.0-DM920
    - http://images.dream-elite.net/DE6/in....rootfs.tar.xz
    Imagine purE2 - http://pur-e2.club/OU/images/index.p...rootfs.tar.bz2
    Imagine TS - http://addons.space/colombo555/tsima...0180406.tar.xz
    Drivers for DM 920UHD - 09.04.2018 - https://hotupload.eu/7xt
    update dm920 and dm900 hardware drivers
    - fixed possible mode switching problems on hdmi output with 4K modes
    - fixed support for high bitrate transponders (45000 8PSK 5/6 is now working okay on all tuners)
    - no CI support for transponders with such high bitrates yet!
    30 Post(s)
    Dream-Elite 6.0 Developer (BETA !!!!) - http://images.dream-elite.net/DE6-DE...php?dir=DM920/
    [OE2.5] DMS Image OE2.5 DM 920UHD - http://www.demonisat.info/demonisat-...age-oe2.5/920/
    Update Image 7.1 OE2.5 dm920
    update dm900/dm920 hardware drivers
    Scaricare oscam
    Uscire dal pannello
    Rientra e attiva la oscam
    Download oscam
    Exit the panel
    Return and activate the oscam
    config oscam Ncam
    var/tuxbox/config/OScam
    var/tuxbox/config/Ncam
    Download settings dal menu-Plugin-oppure dal tasto blu
    DemonSetting
    Download settings from the menu-Plugin-or the blue button
    DemonSetting
    30 Post(s)
    TSImage 11.04.2018 - http://addons.space/colombo555/tsima...0180410.tar.xz
    - 09 Apr 2018 (git opendreambox)
    update dm920 and dm900 hardware drivers krogoth
    live555: fixed rtsp teardown
    enigma2-plugin-pzyp4t: bump srcrev
    satip-client: bump rev
    enigma2-plugin-pzyp4t: initial recipe
    dreamliveserver: push to 1.2
    live555: optimized udp throttling again
    gstreamer: backport patch for proper rtsp teardown
    Revert "Makefile: allow to override directory structure"
    dreamliveserver: rtsp optimizations, compatibility fixes for mipsel
    live555: fixed support for older kernel, small udp optimization
    update dm920,dm900 hardware drivers
    enigma2: 4.3.1r27:
    - fixed segfault caused by streamserver on enigma2 startup
    - fixed crash on opening movielist
    enigma2: 4.3.1r26:
    - added new streamserver
    - keymap.xml: update keyboard bindings again
    - Screens.TimerEdit: simplified and fixed timer list handling (fixed broken cursor position after cleanup)
    - added /data/picon* to picon path selection
    - fixed teletext subtitle colors
    - fixed long time bug caused by spinner loading on enigma2 start
    - CEC: fixed physical address related handling (this maybe fixes input selection issuses after cold boot)
    - added HideZero option to ServicePosition for suppressing "-00:00" output
    - skin_default_1080: minor updates by zombi
    - add handling for deadlocks on startup
    - blindscan: - add workaround for driver bug
    - fixed broken blinscan with Si216x2 after range scan
    - add handling for invalid blits (sourceArea cannot have width/height zero (happens in edge cases))
    - draw only 1/4 of the circle for each corner in rounded-label
    - Converter/ServiceInfo: re-add evVideoSizeChanged to "Framerate" interesting events to fix not visible framerate on first service start
    - fixed position gauge misalignment after creation
    - Default-FHD: put back some values to default-fhd for backwards compat with some plugins
    dreamliveserver: force auto replacement of dreamrtspserver
    opendreambox.conf: remove defunct mirror
    build/*/bitbake.env: use hardcoded path to support build being a symlink
    ****-games: bump srcrev
    enigma2: install enigma2-journald
    enigma2-journald: new recipe for journald config overrides
    dreambox-console-image: install busybox-syslog by default
    dreamliveserver: binary release 1.0
    live555: build shared libraries
    live555: add 20180218
    systemplugins-streamserver: require dreamliveserver instead of dreamrtspserver
    python-youtube-dl: bump rev
    build/*/Makefile: use hardcoded path to support build being a symlink
    gstreamer1.0-bad: re-add missing dvdspu dts patch (lost on switch from dora to krogoth)
    Merge branch "krogoth-stable" into krogoth
    distro-feed-configs-deb: store cached packages in a ramdisk
    packagegroup-opendreambox-gstreamer-1.0: install dashdemux (for hbbtv 1.5/2.0)
    enigma2: fixed endless blindscan on some satellites with Si216X2-D60
    libvc5dream: repackaged version 1.0.5 (header file was missing)
    enigma2: some small patches
    update dreambox hardware drivers
    libvc5dream: update to 1.0.5
    enigma2-plugins: bump SRCREV
    enigma2-plugin-extensions-partnerbox: bump SRCREV
    enigma2-plugins: bump rev so we rrecommend epgsearch plugin
    partnerbox: bump srcrev (again)
    - 10 Apr 2018 (TSimage)
    update enigma2-tspanel to 3.5-r16.0
    update enigma2-plugin-extensions-dbackup to 0.95
    update enigma2-cams-ncam-git to 20180306
    update enigma2-cams-oscam-unstable to svn-11414
    30 Post(s)
    DMS Image OE2.5 dm920
    Update Image 7.2 OE2.5 dm920
    enigma2-plugins: push SRCREV's for stable release
    Scaricare oscam
    Uscire dal pannello
    Download oscam
    Exit the panel
    config oscam Ncam
    DemonSetting
    DemonSetting
    - https://www.file-upload.net/download...0-7.2.zip.html
    30 Post(s)
    Drivere - Update 25/04/2018 - https://ufile.io/2lpgd
    update dm920/dm900 hardware drivers:
    - bcm45208/45308x: longer tune timeouts for low symbol rate transponders
    - fixed possible demux deadlock in combination with a fbc tuner and dm920
    - fixed possible race condition on open/close audio/video encoder from different processes
    30 Post(s)
    - Update drivers - update dm920 hardware drivers (fixed a possible demux deadlock) - https://ufile.io/8ffab
    - Update Image 7.5 OE2.5 dm920
    Scaricare oscam
    Uscire dal pannello
    Download oscam
    Exit the panel
    config oscam Ncam
    DemonSetting
    DemonSetting
    Date: 2018-05-14 19:43:49.614312
    Distro: opendreambox 2.5.0
    Drivers: 3.14-1.17-dm920-20180514-r0.0
    Enigma2: 4.3.1r28-r0.0
    Kernel: kernel-image-zimage, kernel-image-3.14-1.17-dm920, kernel-image-zimage-3.14-1.17-dm920 3.14-r0.1
    MD5: b82679de399a40bba69058b0004fae1a
    Machine: Dreambox DM920
    SHA256: 3694096e5577b91a0670c648bf77e9dde2f2ec97c3080f9a1d cfe5db033c57b0
    30 Post(s)
    OpenPLI 6.1 - https://ufile.io/kivmw
    - fix typo
    - dm9x0/dm820: add patch to fix service searching menu items
    -- OpenPLi/enigma2@cc5162f
    -- triggers the triple tuner configuration bug which we still have in Enigma2.
    -- nimmanager.somethingConnected() returns alway False and due to that users have no menu option like Fast Scan,
    -- Automatic scan, Manual scan, Positioner setup and signalfinder.
    - exteplayer3: update patch
    30 Post(s)
    Ca tot se discuta/face reclama la imaginea ''pureE2'' pe alt thread de pe acest forum ( e adevarat nu e DM )
    - pureE2 6.2 DM 920UHD - https://ufile.io/xs0rb - https://ufile.io/av6tk
    30 Post(s)
    Peter pan - stealth -oe 2.5
    PETER PAN - STEALTH -
    -----------------------ooOoo----------------------
    IMAGE INFO
    Based on the new OE2.5 Krogoth experimental image
    ooOoo
    FEATURED INFO
    Brand new Standard HD skin with its own setup plugin - Create your own skins LIVE!
    Make up to 20 favorite skins with Standard HD skin setup - Switch between them easily!
    Choose between 53 background images and hundreds of other graphic items for your skin favorites
    Choose a Standard skin with or without video preview window - this makes transparent skins possible
    Major fixes and further developement within Standard skin - It now covers over 400 screens for different plugins out there!
    Setup your LCD style with LCD&Picon setup plugin
    New and convenient Extended Number Zap plugin enabled at startup
    Added ECM info for most of softcams out there to our Second Infobar
    Fantastic main Infobar with all the information you need
    ooOoo
    OTHER CONVENIENT INFO
    OScam 1.20 preinstalled and ready to use
    Preinstalled satellites.xml cover satellite positions from 75E to 58W and supports 2SX multistream tuners
    ooOoo
    PERFORMANCE INFO
    Finally fixed long lasting time consumption problem when changing channels!
    ooOoo
    PP PLUGINS INFO
    PP Settings - Costumize the PP image as you like it
    PP Remote Setup - Choose whatever remote control you like for your tuner or download a keymap you like
    PP Satellite XML Generator - Create your satellite.xml file in an instance (not multistream yet)
    PP Boxkey Generator - Make en STBID from your original tuner easily
    PP standard skin setup - Lots of fun in one place!
    PP Skin Manager - Switch between installed 3rd party skins
    PP LCD&Picon Setup - Manage your LCD here
    PP Second InfoBar Setup - Setup your SIB settings
    PP Extended NumberZap Setup - Setup your ENZ settings here
    PP Cam Manager - Download and manage softcams easily
    PP AutoCam - Set up different Cams and let the system switch between them automatically
    ...and lot of other specialized plugins for your needs, made by the PP team
    ooOoo
    HOWTO - TIPS & TRICKS
    How to use PP-Standard-HD skin
    Hvordan bruke PP-Standard-HD skin
    - http://www.mediafire.com/file/aa3uwd...fs.tar.xz/file
    30 Post(s)
    DMS Image 7.6 OE2.5 dm920 - https://www.file-upload.net/download...0-7.6.zip.html
    Scaricare oscam
    Uscire dal pannello
    Download oscam
    Exit the panel
    config oscam Ncam
    DemonSetting
    DemonSetting
    Date: 2018-07-09 10:04:13.726778
    30 Post(s)
    DM920 imagini OneStep [OE2.5]
    Pe imaginile ''test'' sunt adaugate unele plugin-uri , cum ar fi :
    - MetrixStyle HD
    - MetrixStyle piele
    - MediaPortal + extensie
    - Pluginsort
    - Startupservice
    Imagine OneStep test bazata pe GP3.3 - http://www.filehost.ro/3172866588/on..._20180712_tar/
    Imagine OneStep bazata pe Merlin - http://www.filehost.ro/3172866590/on..._20180712_tar/
    30 Post(s)
    SatLodge DM920 UHD PowerVu - http://www.mediafire.com/file/exb772...FN.tar.gz/file
    SatLodge 1.1c with PowerVu full working.
    Just set you local config (tuner and DHCP) staty tuned 10 minutes or less on any AFN channel to get updates.
    purE2 DM920 PowerVu - http://www.mediafire.com/file/2g6yjv...Vu.tar.gz/file
    From Menu=>pManager start CAMD Oscam 11425
    Just edit your correct tuner config and stay tuned around 10 minutes or less on any AFN channel that's it.
    Name=root
    Passw=pure2
    30 Post(s)
    PKT Hyperion 6.1 - https://ufile.io/4l1rr
    30 Post(s)
    - DMS Image 8.7 OE2.5 dm920/dm900 hardware drivers - https://www.file-upload.net/download...0-8.7.zip.html
    Download oscam
    Exit the panel
    config oscam Ncam
    Default/Skin HD
    DemonSetting
    Date: 2019-04-28 12:18:17.038430
    Drivers: 3.14-1.17-dm920-20190312-r0.0
    Enigma2: 4.3.2r5-r0.0
    MD5: 433288d4e07c4fbe08404b9b5b099d6f
    SHA256: bc1143c150081c334513113ec3080cca83daad8c272920f963 52eefc19b21a39
    Skin Default if you want to change go in Menu, Setup, Audio and Video.Skin.. insert the Dreamy
    - Satlodge image enigma2 : 4.3.2r5 26/4/2019 - https://ufile.io/tn7cvxrj
    inportant request image reflash
    (fix)
    enigma2: 4.3.2r5
    - create backtraces and crashlogs already during the initialization of enigma2
    - updated default favourites
    - allow to explicitly ignore unused actions to avoid debug output warnings
    - SoftwareManager: fixed WHERE_SOFTWAREMANAGER handling
    - unicables.xml: added Dura-Sat DUR-line UK119
    - eServiceURI: implemented "setResolvedName"
    - EventView: fixed item duplication in EventView Plugin Blue-Hook
    - ChannelSelectionDisplaySettings: fix handling of /data for small picons
    - updated translations
    - SoftwareManager.Updatecheck: fix value of next update check timestamp when it would actually be in the past
    - don't crash when SoftwareManager is missing
    - fixed possible crash caused by excessive usage of pictures with alpha channel
    enjoy your satlodge team
    30 Post(s)
    NEW DREAM-ELITE-6.0-DM920 - https://ufile.io/vrcx2l3f
    Changelog of 21.06.2019
    update DE enigma2
    - add Bootpanel to DE Panel
    - added Screens from Bootpanel to DE-FHD
    - add Screen of Automatic Timerlist Setup to DE-FHD
    - update german and italian language (for other languages your are free to do the translations and send it to me)
    - added Advanced Audio Settings by dhwz fix in image
    - add possibility to have SDCard on dm7080, dm9x0 and dmOne as picon device or for recordings ecc.
    - update Renderer and Converter
    update DreamOS Core
    - update enigma2-plugins
    - update 3rdparty feed
    update DE Panel
    - update some plugins in Addon Panel
    - update Skins in Addon Panel
