Dislikes:
Member
- Rep Power
- 53
daca as fii putut as fi facut.dar cum el se repornea non stop nu am avut cum.mai nou cred ca am mai facut o prostie.sper sa nu fie prea mare.am incercat sa pun o alta imagine,asa cum mi-a explicat @gabrield,parea ca totul e in regula dar mi-a aparut pe display o wwwpunctdm800sim2punctcom si ceva cu o eroare si asa sta.nu mai reusesc sa intru in el sub nicio forma.astept ceva sfaturi de la voi.multumesc mult.
Cred ca ai bagat soft cu alt BL.
Iar din cauza ca se tot reseta poate sa fie sursa.
Sent from my GT-I9300
Old Member
- Rep Power
- 87
Scrie aici exact ce fel de eroare ai pe afișaj. O fi asta? www.dm800sim2.com ->error! *ERR01: NO CA FOUND
Member
- Rep Power
- 53
exact aia era eroarea.am reusit totusi sa rezolv cu ajutorul unui tutorial de pe alt site.
This can be done in 2 ways.
1) You have to have a working dreambox.
2) DM800_repair, you alter dreamup to be able to use greyed buttons.
Now for the first sollution.
1) Connect working dreambox DM600/DM800.
2) Open dreamup, press connect.
3) When dreambox is found by dreamup, insert Null-Modem cable in
the broken dreambox.
4) Press flash button, and chose a firmware.
5) The flash progress will probably hang, its OK.
6) Open dreamup again, connect the broken box, press connect. 7) If all went ok, you can now flash box again, (Use only serial
communication)
Now for the second sollution
1) Connect broken dreambox DM600/DM800
3) When you see second loader error popup, just press ok.
4) Open 2nd_stage_pack.rar
5) Drag DM800_repair in front of dreamup, and press dream multimedia logo. 6) Now press the greyed Flash button, and chose firmware. 7) The flash progress will probably hang, its OK.
9) If all went ok, you can now flash box again, (Use only serial
communication)
am pus din nou newnigma 2 ca imagine,am reusit sa-mi refac serverul dar mai am o problema la care nu reusesc sa-i dau de cap.mi-a facut cineva un script pentru update la cardul de tivusat.newnigma 2 nu are crond.persoana care m-a ajutat mi-a instalat un crond care imi facea sa ruleze scriptul in fiecare zi.ma poate ajuta cineva cu ceva sfaturi?multumesc mult.
Old Member
- Rep Power
- 87
Mă bucur că ai rezolvat. Rezolvarea era AICI trebuia doar sa dai un search pe forum.
Member
- Rep Power
- 53
dm800hd care a mers cu newnigma 2.vreau sa schimb imaginea si sa pastrez combinatia cccam_oscam pe care am avut-o pana acum.am instalat dreamelite 4 si nemesis 2.3.pun fisierele care le-am avut in usr/script si usr/bin ,dau atribut 755,restart la dream dar nu imi apare niciunde softcamul.sa ma lumineze cineva unde gresesc.
- Rep Power
- 0
Old Member
- Rep Power
- 87
Originally Posted by
sinangel
ceva teste ? pret?
What?
