Thanks Thanks:  3
Likes Likes:  3
Page 7 of 21 FirstFirst ... 3456789101117 ... LastLast
Results 91 to 105 of 309
Thread: Dreambox 500s
  1. #91
    25 Jul 2007
    Netherland
    Default Re: DREAMBOX 500
    Gemini v4.00:
    Technical Infos:
    * Enigma of: 24.08.2007
    * GCC 3.4.4 Original CVS
    * Web Interface: 6.0.2-Expert
    * Busybox 1.01
    * Tuxtxt V1.99
    * CIFS 1.44
    Remotecontrol:
    * BLUE - Blue Panel (BP)
    * 2x BLUE - BP -> Extras/Settings
    * YELLOW - Quick-Button (can be configured via BP)
    * RED - EPG list for active channel
    * 2x RED - EPG style menu
    * GREEN - subservices
    Addons:
    * own Addon-Server via Internet
    * adding additional functions via internet from the Gemini-Server and install them automaticly
    * Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
    * Create your own Satellites.xml, which only contains the Satellites you realy need
    Camd:
    * Different Camd´s can be linked to channels/provider (Autocam)
    * Changeing the name and settings via own menu.
    * Creation of a 2nd socket (/tmp/cam1.socket)
    Daemon / Server / Clients:
    * Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
    * Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
    * Upnp Client and Server (for DM500 - DM7000 must be installed from our Gemini-Server)
    * Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
    * Inadyn (Daemon for different DYNDNS-Services)
    * little Apache (HTTP-Server based on HTTPD)
    * NFS-Server (based on the NFS-Kernel-Modules)
    Infobar / OSD / Skin / Background-Pictures:
    * Position of the Infobar can be changed without editing the skin files
    * Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
    * Display of EMM, ECM or "Expertinfos" are switchable
    * Picon (displaying the Channel-Logo)
    * Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
    * Background picture can be turned off (Plasma - Fix)
    * Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
    * Changing Bootlogo via menu ( 7020 only)
    * Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
    * Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
    Files / Devices
    * Support for CDROM/DVD no matter using IDE or USB
    * JPEG´s ca be rotated and dislaying of the EXIF-Tags (not DM500)
    * Support for OGG/Vorbis
    * Random function for MP3 and OGG
    * Backup function
    * 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
    Extras:
    * Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s)
    * System Info: Many extra box infos like stream-rates, kernel-, memory- and prozessinfos.
    * Own scipts can be started via Blue Panel
    * Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
    * Additional EPG-functions (Dishnetwork, cache, storage location)
    * Font and Libfribidi e.g. for arabic
    * Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
    * alarm-clock with volume offset playing own WAV-Files
    * Calander for iCalander format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc(ical
    * Support for DreamDVD no matter wether a DVD-Drive is available or not
    * New screenshot routines (have a look at the Webif)
    New:
    * Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
    * EPG-Infos of all recorded movies can be showed without starting the record.
    * Infoszeile im Sendermenu jetzt wie in Enigma2.
    * Infobar in the channelmenu is now like in E2.
    * Changed the addon routines. There will be a preview available by many addons and skins (due to the new structure of the addons we also did the version jump)
    * own RSS und Weather Plugin (for 7000 and 500 you have to install it)
    * eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
    * disable the TV-out (scart out) while you take a record (onle makes sense with the 500)
    * Completely reworked DreamNetCast
    * ECM-Expert+ now using a separate window
    Fix + update:
    * see CVS
    nterfaces WebIF:
    http://127.0.0.1/cgi-bin/GeminiInfo
    http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/InitCam
    http://127.0.0.1/cgi-bin/ResetCam
    We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
    This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
    Recommendation:
    If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
    if several processes running in background.
    Download via Database
    Thanks a lot and have fun
    Your Gemini-Team
    Download : http://www.sateliti.org/upload/index...0files/Imagini
  2. #92
    Super Member
    15 May 2007
    salutare!
    am si eu o intrebare: am Dolce (nu prea il folosesc), 2 cartele deci.
    am DSB790 de la echo dar nu pot sa share nimic cu el, in primul rand nu e server, in al doilea nu am conexiune permanenta la internet.
    intrebarea mea este: ce as putea sa vad daca dau Dolcele in share? sau daca nu il pun la share, pot sa vad ceva in plus, conectat la internet, fata de Echolite?
  3. #93
    12 Aug 2007
    La ce foloseste cartela Firecrypt ce o da unele firme cu receptorul Dream 500 ?
  4. #94
    13 Feb 2007
    Earth
    Smile Re: DREAMBOX 500
    salut , cartela este pt. vizionarea unor programe xxx , nu mai stiu care si cate : 1,2,3 canale .bafta .
  5. #95
    25 Jul 2007
    Netherland
    exista posibilitate sa pun la un dm500 un hdd !! astept pareri ca sa nu il desfac dejeaba!
  6. #96
    01 Apr 2007
    La dm500 nu .La dm600 merg hdd de 2,5' iar la dm70xx merg puse hhd de 3,5'
    Daca-ti convine inregistrezi prin lan pe PC cu CIFS sau Ngrab
  7. #97
    25 Jul 2007
    Netherland
    cu ngrab trag si acu dar as vre sa nu mai tin si calculatoru deschis si prin ngrab calitate e mai proasta
    prefer sa trag cu skystar 2 daca tot tin calcu deschis
    multam de info
  8. #98
    01 Apr 2007
    Ar mai fi o posibilitate :
    NAS ( Network Acces Storage ) = harddisc in retea ; dar preturile la cele capabile ( sa stie NFS / CIFS si sa aiba viteza suficienta ) sint peste DM8000+DM7025
    Asa ca , stringem ronii in porcusor si luam Kathrein UFS 910 , pina atunci poate vor face functionala S-ata implementata hardware
  9. #99
    Ce protocol (http, ftp, ...) foloseste dreamul pentru gbox?
  10. #100
    01 Apr 2007
    desi intrebarea este absurda ( sau cel putin asa o vad eu ), gboxul comunica prin protocol UDP
  11. #101
    De unde sa comand un Dream 500S original cu holograma? Recomandati un vanzator serios!
  12. #102
    Super Member
    11 Feb 2007
    www.elstar.ro sau www.peruvision.ro
  13. #103
    http://www.elstar.ro/?page=shop/brow...952df9f85d474b
  14. #104
    13 Feb 2007
    Earth
    www.prosat.ro , din Cluj .
  15. #105
    12 Aug 2007
    Am abo la d**i si vreau sa am cartela in Dream 500 , ce treebuie sa fac ? Nu are rost sa tin o intrare libera la comutator si sa am un receptor si o telecomanda in plus.
    Maine sper sa am si obiectul ptr experiente ...
