Results 16 to 30 of 31
Thread: IPBOX 9000 **SIFTEAM firmware**
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default SifTeam 0.1.8-r8340
    NEW RELEASE r8340: Added or improved Function
    1. Add video resolution in Additional banner
    (press "i" button two times)
    2. Show the kinds of supporting format for video plyer
    (divx, xvid, mpeg, mpg, trp, vob, avi)
    3. Fixed the bug staying power on without signal
    http://www.upload-drive.com/3348/Sif...r8340_9000_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default SifTeam 0.1.9 r8421
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    O zi frumoasa! Snow's Avatar
    Default Re: IPBOX 9000 **SIFTEAM firmware**
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default SifTeam 0.1.9 r8718 ipbox9000
    1. Added "post-descrambling with CAM" function on system settings menu
    : When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
    and then you can descramble the recorded file later.
    - The channel in record cannot be watchable.
    - The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
    - even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
    (Caution)
    The recorded file must be performed ˇ°descramblingˇ± before the next smartcard update.
    If descrambling is not running, it is impossible to do the file descrambling anymore
    or able to damage the smartcard since the smartcard has already been updated.
    2. Added HUB function for USB host.
    3. Fixed record programs with DVB subtitle.
    4. Support adjust LipSync using page up/down buttons in Videoplayer
    5. Support NFS function for Linux System in Mount manager
    - changed NFS config in /etc/exports
    ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
    - Removed the firewall of system
    - Removed the firewall of IP table when your system is Fedora
    # iptables -F
    6. Support displays elapsing time on banner of MP3 player
    7. Support Sort function on TMP folder in Recorded files menu
    8. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
    9. Updated language table for Slovak, Bulgarian, Polish and Russian
    10. Fixed DVB EPG bug for HB13 10891
    11. Fixed elapsing time error when schedule recording.
    12. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
    13. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
    14. Added WSS function through SCART
    http://dreambox.sifteam.eu/index.php?dir=9000HD/r8718/
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default SifTeam 0.1.9 r8728 9000HD
    1. Support *.mkv with video player.
    - If the file needs higher class CODEC, the file will not be playback with video player .
    - In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
    2. Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
    3. Fixed some bug for schedule recording.
    4. Fixed record subtitle.
    known issue : DVB subtitle color problem.
    http://www.upload-drive.com/6224/900...noboot_img_zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default SifTeam 0.1.9 r8833 9000HD
    fixed are
    - Recording bug fixed
    - DVB subtitels ok now
    and added
    - new scan options
    - rewind function in Video Player
    blind scan replaced by
    default scan
    advanced scan
    reset scan
    fast forward/back only works ok on divx, on vob files it crashes box.
    - They have added age range symbol in livebanner too (small change)
    - photo menu got background now.
    http://dreambox.sifteam.eu/index.php?dir=9000HD/r8833/
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    VIP PETER36's Avatar
    18 Jan 2009
    Default Sifteam 0.1.9 r8873 9000HD
    SifTeam 0.1.9 r8873 released ipbox9000-910-900-250HD-200HD SifTeam 0.1.9 r8873 released
    1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet.
    press once FF or REW button, the interval is 10 seconds.
    press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
    2. Add Scan option on Channel Scan Menu
    When there is no channel list, all these options create with the same result.
    - Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list.
    - Smart scan : remove current channel list , and scan, and then update FAV list according to the new channel list.
    - Reset scan: remove all of the current channels and FAV group, then scan with new channel data.
    3. Add USB upgrade menu
    - Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode
    it is useful for software upgrade with USB morory stick.
    4. Fixed EPG contents Display
    - inserted new line on the screen for EPG and extended EPG information as well
    5. Fixed DVB subtitle - color table
    6. Fixed OSD teletext - some old data not updated occassionally
    7. Fixed wrong duration with the file after schedule recording with EPG
    8. Fixed Local time auto update
    - When the last channel time of the Satellite is different from the STB time within 10 minutes,
    the STB time is automatically adjusted with the Satellite time during the STB booting.
    9. Updated Polish language table.
    10. Updated Web-interface
    11. Fixed small bugs
    known issues : sync with audio and subtitle
    artefact with premiere HD channels from satellite and cable
    no audio with such as Digifilm channel
    adjust color table of DVB subtitle for some channels
    descarga
    02 Feb 2007
    Default SifTeam 0.2.0 r8873 9000HD
    Version 0.2.0
    Added default password as "sifteam"
    Added script "advanced.command.sh" ..for:
    Add NFS disk
    Remove NFS disk
    Make USB for use as Disk (in congiuntion with NFS option is very good)
    Move /var in part1 of disk or USB (part1 = first partition)
    Removed any files (script)
    Added script for see proper card permission
    ftp://9000hd.sifteam.eu/r8873/9000HD...ate.img.tar.gz
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    05 Nov 2008
    Slovakia
    Default SifTeam 0.2.0 r9047 9000HD
    IP BOX 400S, IP BOX 910, SS2,
    02 Feb 2007
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Standard RSP member coburn's Avatar
    02 Apr 2007
    Exista doar un lucru bun, stiinta, si doar unul rau, nestiinta.
    25 Dec 2008
    Default Sifteam r11453
    http://dreambox.sifteam.eu/index.php?dir=9000HD/r11453/
    O imagine mai noua care se misca destul de bine si are un meniu diferit fata de imaginile precedente.
    Avand in vedere ca la mine timpul este scurt si linuxul destul de complicat ...................
    29 Nov 2008
    Cu capu' in nori
    Ai mai multe sanse sa-l vinzi daca postezi la sectiunea Shopping, aici intra userii doar sa caute softuri.
    Bafta.
    25 Dec 2008
    Scuze. L-am trecut la Shopping.
