Thanks Thanks:  11
Likes Likes:  18
Page 1 of 6 12345 ... LastLast
Results 1 to 15 of 86
Thread: DIABLO CAM (incepatori si stiutori)
    Standard RSP member gessle's Avatar
    tg ocna;jud. BACAU
    Default DIABLO CAM (incepatori si stiutori)
    In acest exemplu ,vom actualiza firmware-ul,folosind cas 3(vezi imaginea1).Aceasta e deschiderea de ecran "impuscat" de cas3,faceti click pe module cam:
    Se face click pe Diablo cam(img 2-vezi):
    apoi faceti inca o data click ca-n img 3 pt a rula prog
    .de
    13 Feb 2007
    Earth
    Post Re: DIABLO CAM(incepatori si stiutori)
    salut, intai , felicitarile mele lui @gessle pt tutorialul de mai sus , sper sa nu se supere pe mine , mai jos aveti video tutorialul ( explicat foarte bine de catre @gessle ) , il pun doar pentru cei ce doresc sa vada si filmuletul video .
    ( How to Flash Diablo Cam Firmware.
    A Video Tutorial to help newbies use Cas Studio.
    14 Feb 2007
    Default Re: DIABLO CAM(incepatori si stiutori)
    Multumim pt tutoriale @gessle & @savin, intr-adevar o informatie utila.
    11 Apr 2007
    M-am pricopsit cu un Prussian Galaxy5 - FUN 7? Pot face ceva cu el daca am Diablo v2.3 si cas3? In fata grafica a cas3, pt smardcards nu apare mentionat!
    tg ocna;jud. BACAU
    Fausto card server worked with any client via:
    - linux box
    - diablo wifi
    - diablo wireless
    - season interface
    - receivers supporting HSIC & SSSP protocol
    (informations found on text file)
    If you want to share card go under option CARD & read card inserted on card progger (phoenix mode)
    Then after, define your servers lines under FaustoServers.cfg
    (follow instructions syntax wrote under file FaustoServers Example.cfg)
    Don't forget to insert username/password allowed on servers
    When done back on Servers MANAGER option & press START button
    If you want to share emulator too, go under MONITOR & load KEYS.BIN
    Now fausto ready to share card & emulator with any client
    example of server lines gived on file FaustoServers Example.cfg
    N: 127.0.0.1 25000 0102030405060708091011121314 {090F/000000}
    N: 127.0.0.1 25050 0102030405060708091011121314 {0100/000030}
    This 2 servers line worked with Fausto internal emulator mean keys.bin must be loaded under MONITOR
    Now you must define your client, in my case using cccam
    I'll open CCcam.cfg and i'll enter those 2 client lines
    N: 127.0.0.1 25000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    N: 127.0.0.1 25050 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    Save file & transfert file under linux box & cccam will connect to fausto card server like client
    Side server/client replace 127.0.0.1 by your card server ip adress (ethernet ip of linux box for example)
    Fausto emulator is very fast on decoding/zapping like emu inside box, cards decoding/zapping have normal speed
    Card server function is not specific to one material you need only client, tested and worked after 5 minutes in home card share with my linux box, all informations are under Fausto folder in text files, just read & try it.
    Season interface can be used with fausto to connect like client or/and use Fausto internal emulator, do not make confusion between CLIENT & SERVER.
    -who knows more then this one,take a note on it,please!
    .de
    30 Dec 2009
    planeta S-F
    Default ce face tipul ca nu inteleg
    Quote Originally Posted by dMd View Post
    http:/.........................http://www.youtube.com/watch?v=ElHzM...1&feature=fvwp
    Standard RSP member xnetbogdan's Avatar
    23 May 2007
    Am un cam diablo wifi rev 2.3 care mi-a dat eroare la formatare cu cas2 si dupa aceasta eroare nu imi m-ai recunoaste camul in cas2.ce pot sa fac ?
    19 Aug 2011
    UTC+13
    Mi-am luat un diablo wifi, am pus pe el Underworld 2.28, l-am configurat cat de cat, pagina web se incarca, incepe sa se faca lumina pe unele posturi, insa cea mai mare problema este ca nu ma pot conecta la el pe FTP.
    A mai avut cineva aceasta problema?
    muta sobolanu` de aici
    04 Jun 2007
    Default diablo
    @tutri verifica la configurarea wireless domain-sa fie acceeasi treaba care e scrisa pe routerul tau FCC . In rest daca ii dai user si parola buna ,trebuie sa mearga ftp-ul.
    19 Aug 2011
    UTC+13
    Totul este OK.
    Tocmai am citit ca pe 2.6 nu mai merge FTP.
    19 Aug 2011
    UTC+13
    Tot eu. Nu reusesc sa deschid posturile care apar la mai multi provideri. De exemplu posturile DIGI merg, dar care sunt cuplate cu altii, adio arme.
    Iecsista vre-o solutie? sau e nevoie de revolutie?
    04 Jun 2007
    la ver 2.3 in meniul underworld pui pe off sistemele de criptare care nu te intereseaza
    19 Aug 2011
    UTC+13
    Al meu a inceput sa faca figuri iar, se agata si ... in oscam vad doar:
    "anonymous disconnected from 192.168.*.*"
    Cateodata un power cycle al televizorului il rezolva, alteori nu il ajuta nimic si ma obliga sa ma uit la altceva.
    26 Dec 2011
    Agen
    Incearca sa pui in oscam/config/cccam o versiune intre 2.0.11 si max 2.13 (+restart) si vezi daca se mai intampla; si fara filtrare dupa MAC in router.
    03 Oct 2008
    Salut,am si eu o problema cu diablo,nu imi deschide canalele hd digi satelit,pe cele sd da.
    daca stie cineva solutia rog sa ma ajute.
    Multumesc anticipat
