Likes Likes:  1
Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 82
Thread: Schimbare MAC permanent prin FTP - DM500
    Default Re: Schimbare MAC permanent???? Cine se incumeta?
    Multumim! Util generatorul!
    11 Apr 2008
    Fost mebru
    Am modificat si eu MAC-ul la o clona. Am pus gemini 4.30 , aveam acces la blue panel. Am pus 4.40. Deocamdata e OK
    Fost membru al acestui forum
    11 Apr 2008
    Fost mebru
    A depasit uptime 24 de ore. Am testat diverse (net , reboot etc) si totul e OK.
    Quote Originally Posted by delta2k2 View Post
    Atunci dai un reboot de vre-o 3 ori la interval de 12min[din aparat cat si scotindul din priza in timpul functionarii] si vezi tot asa ramane?
    11 Apr 2008
    Fost mebru
    Numai un reboot crezi ca am dat ? Am dat destule , si legat la net si fara net.
    7 Post(s)
    @delta2k2 de precizat cred ca ar fii fapul ca ai pus probabil 4.40 care nu atre bomba iar in al 2 rad nu sugerez nimanui sa foloseasca gp 4.31-4.40 varianta timebomb care isi fac treaba normal in cazul in care modificarea sa facut cu pacheME xx xx....... daca e cineva care ma poate contrazice e ok. sunt un pic curios daca a riscat cineva
    eu zic asa pacheME si 4.40 notime bomb se inbina perfect
    12 Aug 2007
    Am bagat gp 4.4 de pe ihad pe clona cu mac schimbat de patchME , am dat reboot de multe ori si flash erase de vreo 10 ori inainte de a baga gp (sa vad daca ramane mac-ul). Deocamdata e ok
    30 Apr 2008
    Quote Originally Posted by zappa View Post
    Am gasit pe un forum de afara (www.dragteam.info) o modalitate de schimbare a MAC-ului permanent fara a folosi jtag.
    http://rs34.rapidshare.com/files/112...ER_toolkit.rar
    http://rapidshare.com/files/11225772...e-mac-hack.img
    HOW TO USE :
    ATTENTION : Don't forget to make a backup image !
    1st Download FLASH WIZZARD and upload the modified firmware image "brainwave mac address changer.fw2" to dreambox
    2nd Reboot dreambox and then, connect using telnet (use dhcp, and find the assigned IP in the control panel).
    The login/password are the default credentials (root/dreambox).
    3rd execute the script calling it like this :
    /var/patchME XX XX XX XX XX XX
    The XX XX XX XX XX XX is the desired MAC ADDRESS. Do not use colons to separate the bytes.
    example:
    This is ok --> /var/patchME 00 09 CC 01 AA 55
    This is not ok --> /var/patchME 00:09:CC:01:AA:55
    Congratulations ! Mac address permanently changed.
    Feel free to upload your backup image.
    If you have any questions, PM me at http://www.dragteam.info/forum
    bra|wave
    Puteti sa puneti doar fisierul pachtME, va multumesc!
    11 Apr 2008
    Fost mebru
    Quote Originally Posted by gobi2000 View Post
    Nu , am pus gp 4.40 de la mama lui.
    Chiar daca se intampla ceva , exista JTAG.
    7 Post(s)
    Quote Originally Posted by maximuss View Post
    in mod mormal time bomb defapt ce face ,verifica macul si in prealabil daca e original nu il schimba dar in timp il verifica si daca al gaseste invalid il schimba!
    11 Apr 2008
    Fost mebru
    Quote Originally Posted by Alexandru View Post
    S-ar putea sa fie o imagine modificata care prermite rularea si executia corecta a patch-ului.
    Nu am testat doar patch-ul pe alta imagine.
    7 Post(s)
    ai dreptate daca te sti cu jtag-ul si ai si mana buna eu zic ca e ceamai buna si sigura solutie!
    11 Apr 2008
    Fost mebru
    Time bomb-ul verifica daca MAC-ul este "original". Daca nu este original sterge boot-loaderul (care se poate rescrie doar cu JTAG-ul).
    7 Post(s)
    corect mo!
    Time Bomb verifica MAC si daca nu e valid rescrie master boot-ul facand receptorul inutilizabil si apare numai ADIOS AMIGOS!
