Dislikes:
- 83
NLB r8728 mini
CubeRevo/IP9 Series nlb8728-v1.23
WEBIF
login: root
password: relook
First time boot with freeze/panic, is not fixed yet.. sorry!
Reboot at lang screen and all is okay.
Prepared by : Dexter
Release date : December 26. 2008
Changes:
* update: - SVN8728 from DGStation.
* SVN - Support *.mkv with video player.
* - If file needs higher class CODEC, file will not be played with video player . In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
* - Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
* - Upper card reader.
* - Fixed some bug for schedule recording.
* - Fixed record subtitle.
* - Added "post-descrambling with CAM" function on system settings menu.
* - Added HUB function for USB host
* - Support adjust LipSync using page up/down buttons in Videoplayer
* - Support displays elapsing time on banner of MP3 player.
* - Support Sort function on TMP folder in Recorded files menu.
* - Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
* - Updated language table for Slovak, Bulgarian, Polish and Russian
* - Fixed DVB EPG bug for HB13 10891
* - Fixed elapsing time error when schedule recording.
* - Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
* - Fixed bugs in scanning and zapping of the channels with diseqc and usals.
* - Added WSS function through SCART.
* added - dual recording support with mgcamd, default configs are made for newcs setup.
* added - nlbpanel 1.38: nlb panel only shows skins available.
* added - webepg 0.61: Auto import at boot, of epg data when /var/file.xml.imported exists.
* changes - ushare binary updated to use Kneubi release.
http://rapidshare.com/files/177062821/nlb8728mini.zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Member
Visitor
- 0
Re: IPBOX 900 **NLB firmware**
salutare!!!
care-i parola de conectare pe ftp, ca nu reusesc... pe interfata web reusesc...
merci
- 83
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 83
NLB r8728 v1.25
CubeRevo nlb svn8728 v1.25
for 9000/910/900/250/200
WEBIF
login: root
password: relook
First time boot with Remote not working, is not fixed yet.. sorry!
Release date : January 5. 2009
Changes:
* updated - bootlogo fix.
* fixed - Internal smartcard reader fix for 910/250
* added - IncubusCamd 0.55 real update with dual tuner,pip and recording support.
* added - more information in webif description.
* added - skin fixes for simple infobar, still a dgs bug here if you jump 2 channels.
* added - formatting of Harddrive if box fails to do it during bootup..
* - NOTE: uboot seems to disable some types of HDD during bootup..
* - ----: When box is ready, remove the hdd and connect again.
* - ----: and use this format option to init harddrive.
* fixed - bug in format hdd/usb routine, wrong partition type choosen.
* removed - reset of cam delay when box goes into panic.
* added - webif option to change newcs config file between nordic and german setup in webif..
* added - webif option to change between old and new sci driver (for special card handling)
* updated - vsftpd.conf , updated with 9MB values for max transfer with ftp..
* added - panel 1.39: hotfix update from /var now possible. read features_nlb.txt for information on how to instal, if you got no internet
* added - direct link at top to dgstation original webif.
(get webif update through panel, to fix missing link in webif)
* update - DGS Webif update, for time correction -60 minutes reported in webif using correct GMT.
* added - Execute startup script before main application, found in /var/etc/init.d , script names start with S .
* fix - Cuberevo250 VFD messages fix.
* change - newcs: Default single internal card slot handling for 250/910.
* change - newcs: Default - newcs is not started on 200/900.
Download - CubeRevo mini/Abcom IP900 - nlb8728mini-v1.25
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 83
NLB r8833 v1.27 900HD
CubeRevo nlb svn8833 v1.27
for 900/910
Unofficial Custom release - no limits board --> http://www.nlb.to
WEBIF
login: root
password: relook
Release date : January 18. 2009
Changes:
** special edition based on 9000/Cuberevo firmware *******
* updated - SVN8833 unofficial (BETA) from DGStation.
* Fix - PANIC situation when DGS Webif is open on pc during bootup.
* Changed - HDD Format of ext2 formatted usb/harddrive even if it was ok.
* Updated - multiboot had some issue with usb sticks above 2GB.
* Updated - multiboot install now works on boxes where usb is mounted as harddrive.
* Fix - multiboot webif on port 81 was using old webif directory.
* Changed - ECM info in webif now showing correct info again.
* Added - newcs 1.63 with updated configs (added 357 mhz to all configs).
* plugins - Added shoutcast 0.51, bitrate 0.4, favpip 1.9.4, fps 0.1.3
* skins - deepblue update 3.5 (new livebanner) Thanks to @Crash
* SVN --- - Recording problem with short HD recordings and 2hr stop fixed.
* - simple livebanner (OSD option) still causing crash.
* - DVBSubtitles now pure white with no banner behind.
* - Signal strength bar is now working again.
* - Media player got FastForward/rewind on divx support now (not .VOB files).
* - blind scan - now default/advanced/reset scan.
* - photoalbum now has background.
* - Maturity rating now as agerating number in livebanner.
* - recording with 1tuner boxes, only channels on same transponder shows
in channel list when 1st recording is active.
* NOTE----- this is a BETA, and people with external usb harddrive
can experience recording issues with 2 HD Channel recordings
(Will be seen as STUDDERING and only a reboot solves it).
http://rapidshare.com/files/185446487/nlb8833mini.zip
http://depositfiles.com/files/ldw3wn5kt
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
VIP
- 0
NLB r8873 v1.27 900HD
NLB8873 for IP910 WEBIF
login: root
password: relook
Release date : January 22. 2009
Changes:
* updated - SVN8873 official from DGStation.
* Added - newcs 1.65 with updated configs (added 357 mhz to all configs).
* Added - nlbpanel 1.41 - now option to install pack.tar.gz from /tmp in panel.
* plugins - updated bitrate 0.0.5, favpip 0.9.5
* - DVBSubtitles color fix.
* - EPG Contents display changes
* - OSD Teletext - some data not update occassionally.
* - Fixed local time auto update
* - updated Polish language table
* - WebIf updated wolf1976 skin
- To install Wolf1976 skin
Ftp to /tmp and use NLBPanel "Install pack.tar.gz from /tmp" to install skin
you can now choose wolfskin in panel.
http://rapidshare.com/files/187739242/nlb8873mini.zip
Reason: Gresit link!A fost pt ipbox 910
- 83
NLB r9047 v1.29 900HD
DGStation/Abcom CubeRevo Series NLB
svn9047(binaries) v1.29
WEBIF
login: root
password: relook
FIRST TIME BOOTSCREEN PANIC IS FINALLY FIXED!
Release date : March 7. 2009
Changes:
* updated - SVN9047+ sbox+skin binaries +po files only.
* plugins - updated favpip 2.1.0
* plugins - updated hddtemp 0.0.7
* plugins - all default in /var/plug-in again.
* emu - mbox 0.4 beta 0023
* webif - emu and newcs selection made simpler.
* skins - deepblue and grey updated.
* emu - EVOCAMD is no longer included in NLB image, no support for it.
* cardreader- DGS Release had problems with Nagra3 cards. this one works.
* DGS webif - updated Geckow webif to 1.3.1 (07.03.2009)
Download: CubeRevo mini / IP900 - NLB9047-mini
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 83
NLB r9580 900HD
nlb9580_900HD_release
http://rapidshare.com/files/246958576/nlb9580_900.zip
login: root
password: relook
Image release: NLB-9580
Prepared by : Rainman
Release date : June 21. 2009
Changes:
* updated - Based on DGStation SVN9580
* emu - updated - IncubusCamd 0.85
* emu - updated - mbox 0.6 Build 0006
* skins - "deepblue" updated (please do a reboot after chaging to this skin), "cool" skin not tested
* skins "blue" and "grey" removed ... these skins are selectable in nlb-panel, but please do not try ;-)
* satangels keyupdater included
We recommend to use "deepblue" skin, because it looks perfect on LCD-TV.
To change from "cool" skin to "deepblue" do the following: Menu -> Plugins -> keyupdater.plugin
-> change from "cool" to "deepblue" and reboot your receiver
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
nlb11102_900 release 24.10.2009
Changes:
* updated - Based on DGStation SVN11102
* fixed DGS-dhcp-bug ... quick and dirty solution, but working ;-)
* emu - IncubusCamd 0.93
* emu - mbox 0.4 build 0023 (gbox support)
* emu - mgcamd 1.33 (starts by default)
* other - updated - streamtools
* webif - updated - dgs webif 1.4.03
* plugins - updated - favpip v2.3.0
* keyupdater included
* nlbpanel included
* and some other plugins :-)
* info: only cool-skin installed
known bugs:
* rec and dolby led´s are always "on" ... this minor bug will solved soon
some remark:
* we ask you to not convert your old db.dat and to use in this release ... also not by using new PCEditor 1.2.54
If you still want to use old db.dat, then rename it to db.dat.edited and copy it to /var folder and reboot ...
after reboot existing db.dat will be replaced with your db.dat.edited file ... thanx
http://rapidshare.com/files/29729830...b11102_900.zip
