Dislikes:
- 82
IPBOX 900 **ABCOM firmware**
Aica o sa gasiti firmware pt ipbox 900HD de la ABCOM...
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 82
ABcom r7473
ABcom r7473
Changelog:
add:
- usb automount function.(9000HD only)
- Turkish translation.
- DB updated to R7327. Database will be updated automatically.
- sorting function in PIP sub-channel list
- reco***ng file format was changed.(will be applied from new REC. but old format will be played too)
- using HDD if download large s/w image(for example usb_all_noboot.img).
Need special server configuration.
- switch to live when end of file playback
- improve webinterface function
fixed,modify:
- modify tp information. Hotbird 11278 (need DB update)
- modify many tp information in Turky Sat (need DB update)
- Fixed ORF1HD freeze
- Premiere EPG : show subfeed epg in mainfeed list epg. epg duplication problem.
- CAM work on backgroud reco***ng.
- panic if enter wrong format in IP address.
- remove NTSC mode in AV setting.
- EPG related panic on some channel
- support 12h time mode in EPG
- random panic when play recorded file.
- improve performance on open FAV menu
- clear video plan when channel change
http://www.upload-drive.com/1338/AB_...all_noboot_zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 82
ABcom r7927
AB IPBox HD/900HD_Images - official/AB_900HD_r7927_070808_usb_all_noboor.zip
AB IPBox 9000HD image based on DGS r7927
* R7927 *
* FIXED
- Instant reco***ng with EPG - STB crashed after stop
- MP3 player - doesn´t play next file
- playback dropouts
- time setting
- doesn´t boot without LAN connection
- Polish and Russian menu language updated
* doesn´t fixed
- doesn´t supported USB HDD
* IMPROVED/ADDED
- automount for USB device
- UK/Ireland cable providers database
- plugin start afer cold OFF
- new basic setting for Astra 19.2E, Astra 23.5E and Hotbird 13E with HD channels from Thor 08W
- FAT 32 support for USB stick device
- edit function for photos and MP3 files. You can copy files from USB device to HDD and back.
Recommended uboot 1.3.1 .
Photo album start - Press "Photo" button on RCU
MP3 player start - Press "Music" button on RCU
ftp login/password: root/ipbox
Software upgrade from USB memory stick (host) :
This function supported only uboot 1.3.1 !
• backup important data from memory stick before try to update. Remove all data from it.
• copy image file to USB stick and rename to "usb_update.img"
• run "remove h/w(memory stick)" function on PC. You can see icon on right bottom (left of clock) screen.
• turn off the stb(Standby + OK) and insert the memory stick.
• press and hold Standby button until front display shows “BOOTING” and press UP key
(on the front side of the box, not on RC), then front display shows "USB UPGRADE" message..
• uboot will update s/w with usb_update.img from memory stick
• Wait until DONE message displays. Restart your receiver.
http://www.upload-drive.com/1770/nlb7927mini_zip
Here is some ipkg addons for official abcom image web interface addon facility,
In co-operation with KNEUBI, I have made individual addons for each of his plugins,
Cli-Team-Addon---- this for Full Addon from after flash,, adds uk database for cable,( Sat tuner boxes will also add channels list for 13,19,28e) adds MGC**D etc, and adds extra options to web interface for start/stop client. also adds the 3 Kneubi plugins for an easy to use addon straight from flash to get you up and running quickly.
get here http://www.satkings.org/cuberevo/cli-team-addon.zip
Cli-Kneubiplugins-addon---- this ONLY adds the three Kneubi plugins
get here http://www.satkings.org/cuberevo/cli...gins-addon.zip
Cli-scriptplugin-addon---- This ONLY installs Kneubi's Script-plugin
get here http://www.satkings.org/cuberevo/cli...ugin-addon.zip
Cli-emailplugin-addon---- this ONLY installs Kneubi's email plugin
Cli-hddtempplugin-addon---- this ONLY installs Kenubi's hdd temperature plugin
README Included with ZIP file,, Thanks to Kneubi for his great plugins, and please let me know any issues and i will sort.
**Installation**
1)copy "cli-***-addon.ipk" to /tmp
2)connect to box with webinterface ( write IP adress of your box to internet browser)
3)use login/password : root/ipbox
4)go to menu addons
5)press install
6)wait for STB reboot
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Re: IPBOX 900 **ABCOM firmware**
http://rapidshare.com/files/14821978...oboot.zip.html
********* Changelog Fixed: - can read old versions of USB stick - EPG on UPC Direct and Cifra+ - support HDD sleep - can't deleting reco***ng file Add: - support Multi Mount Manager - support RGB output - page skip with L/R button in FAV list Recommended uboot 1.3.2 . Photo album start - Press "Photo" button on RCU MP3 player start - Press "Music" button on RCU You need use e-SATA HDD or USB key with multimedia files ! ftp login/password: root/ipbox Software upgrade from USB memory stick (host) : This function supported only uboot 1.3.1 or 1.3.2 ! If you use older uboot, upgrade first uboot 1.3.1 with serial cable and Flash tools from PC. • backup important data from memory stick before try to update. Remove all data from it. • copy image file to USB stick and rename to "usb update.img" • run "remove h/w(memory stick)" function on PC. You can see icon on right bottom (left of clock) screen. • turn off the stb(Standby + OK) and insert the memory stick. • pres
AB IPBox HD/900HD_Images - unofficial/SF addon for AB images/addon_version-900HD_sh4_240908.zip
- 82
ABCOM r8430
http://www.upload-drive.com/3356/AB_...all_noboot_zip
Addons Sifteam
http://www.upload-drive.com/3357/add...sh4_231008_zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 82
ABCOM r8430b 21/10/08
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 82
Re: ABCOM r8430b 21/10/08
Here is a simple ipk addon to add mgcamd,evocamd,mbox,incubus support to abcom web interface.
Is based on 900 but should work fine for 910 also.
No binarys ( emus ) are inside the addon, simply adds basic SF type addon with cam support.
NB: scripts need binary to be named "incubusCamd" in /usr/local/bin or /var/bin
FTP this .ipk to /tmp and goto Web interface>addons>manual .... install
http://www.upload-drive.com/4754/cli...bcom-addon_zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 82
ABCOM r8630 15/12/08
AB_900HD_r8630_151208_usb_all_noboot.zip
- PVR trick/record length bug - Fast scan bugs - crash problem When schedule recording - Nova HD EPG fixed - crash problem after press EPG button in Bulgarian menu Changed/improved : - add DVB and TTX subtitle support - Change Date format(dd.mm.yyyy) - add support for DreCam - You need installed "addon DreCam support...." - improved LAN connection speed (now is speedy) - for 9000HD : add post descramble option with CAM΄s You can record scrambled channel and descramble before playback: Go to record files list, select scrambled record, press Record button, select CAM with card for descramble and press OK. STB create new descrambled file. - support youth protectioon - support nfs mount recording . remove access to /media/ . mount remote directory to /media . mount -o nolock,soft IPIRECTORY /media/ - display video resolution in info banner - upgrade Finnish, Russian, Polish, Bulgarian, Czech and Slovak languages - Support HDMI with compressed Dolby digital audio - Add F
http://www.upload-drive.com/5907/AB_...all_noboot_zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 82
ABCOM r8873 900HD
AB release r8873: ( 23/Jan/2009)
1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet.
press once FF or REW button, the interval is 10 seconds.
press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
2. Add Scan option on Channel Scan Menu
When there is no channel list, all these options create with the same result.
- Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list.
- Smart scan : remove current channel list , and scan, and then update FAV list according to the new channel list.
- Reset scan: remove all of the current channels and FAV group, then scan with new channel data.
3. Add USB upgrade menu
- Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode
it is useful for software upgrade with USB morory stick.
4. Fixed EPG contents Display
- inserted new line on the screen for EPG and extended EPG information as well
5. Fixed DVB subtitle - color table
6. Fixed OSD teletext - some old data not updated occassionally
7. Fixed wrong duration with the file after schedule recording with EPG
8. Fixed Local time auto update
- When the last channel time of the Satellite is different from the STB time within 10 minutes,
the STB time is automatically adjusted with the Satellite time during the STB booting.
9. Upgrade setting
10. Updated Web-interface
11. Fixed small bugs
12. Support *.mkv with video player.
- If the file needs higher class CODEC, the file will not be playback with video player .
- In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
13. Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
14. Fixed some bug for schedule recording.
15. Fixed record subtitle.
16. Added "post-descrambling with CAM" function on system settings menu
: When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
and then you can descramble the recorded file later.
- The channel in record cannot be watchable.
- The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
- even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
(Caution)
The recorded file must be performed ˇ°descramblingˇ± before the next smartcard update.
If descrambling is not running, it is impossible to do the file descrambling anymore
or able to damage the smartcard since the smartcard has already been updated.
17. Added HUB function for USB host.
18. Fixed record programs with DVB subtitle.
19. Support adjust LipSync using page up/down buttons in Videoplayer
20. Support NFS function for Linux System in Mount manager
- changed NFS config in /etc/exports
ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
- Removed the firewall of system
- Removed the firewall of IP table when your system is Fedora
# iptables -F
21. Support displays elapsing time on banner of MP3 player
22. Support Sort function on TMP folder in Recorded files menu
23. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
24. Updated language table for Slovak, Bulgarian, Polish and Russian
25. Fixed DVB EPG bug for HB13 10891
26. Fixed elapsing time error when schedule recording.
27. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
28. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
29. Added WSS function through SCART
30. RED BUTTON - stretch picture to full screen if 16:9 movie broadcast in 4:3 mode with black in all sides (Without 91HD)
31. YELLOW BUTTON - direct start of fav PiP plugin (Without 91HD)
32. Installed plugins - bitrate, Fav PiP, e-mail, weather, Shoutcast, pong, Sudoku, Tetris, HDD temp.
known issues : sync with audio and subtitle
artefact with premiere HD channels from satellite and cable
no audio with such as Digifilm channel
adjust color table of DVB subtitle for some channels
http://www.upload-drive.com/7448/AB_...all_noboot_zip
Addon version 230109 for AB Image
Remove Red button for key update, You can update keys only from webinterface.
Upgrade Newcs 1.65 version
For upgrade read instruction in Beginners guide for AB IPBox HD series on this website
http://www.upload-drive.com/7449/add...sh4_230109_zip
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 82
ABCOM r9057 900HD
AB (DGS based)release r9057: ( 10/Mar/2009)
1. Fixed Astra 23,5E, TP 11876, 11992 PANIC problen
2. Added additional channel scan options for TV or Radio
3. Added repeat function in Video Player
4. Added navigation method for TTXT sub-channel
5. Display the summary when searching channel
6. Save the name of recorded file when user want to schedule in EPG
7. Fixed bug Toptext navigation with TTXT
8. Fixed bug which was AB IPBox 91HD and 910HD were not updated
local timer after AC power off even with Automatic time setting
9. Fixed Alphacrypt German Language Encoding bug
10. Included some of the new plugins .
- Thanks as below developper for plugin.
They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
pong, sudoku, tetris, andd weather of Neumoteam.
11. Updated German language translated by Nilse
12. Removed subtitle language setting in Language Settings Menu
users control through subtitle option on RCU.(this function will be back in next versions)
13. Modified pop up message 'Service is not available' disappears after 5~6
seconds automatically
14. Adjusted the position of Pillar box
15. Adjusted color table of DVB subtitle for some channels
Note.
Images marked as "DRE" are especialy for DRE CAM modules use. If you don´t have this CAM, don´t use "DRE" version !
1. Added Multi booting function
If you want to multi-boot, download usb_config.img in our homepage(www.dgstation.co.kr)
Then press number button on RCU which you want booting mode.
Multi-booting support as below. Official image is number 3.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
2. The Digifilm channel works in official CAM.
3. This image include sci.ko and smart_core.ko
known issues :
USALS doesn´t initialized correctly after box crashed
http://www.sateliti-upload.info/inde.../Ipbox%20900hd
AB IPBox HD/900HD_Images - unofficial/SF addon for AB images/SF_addon_for_900ABr9057.zip
SF addon for AB r9057 image
installation:
First update new image version r9057.
Unzip file, rename to "usb_update.img"
Use usb stick or flash tools for update. Is it same as image update.
http://www.sateliti-upload.info/inde.../Ipbox%20900hd&
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
- 82
ABCOM r9580
AB release r9580: ( 29/May/2009)
1. Add function displaying time always on Front panel
2. Add schedule recording title name on webif
3. Fixed video player panic when spdif is off
4. Fixed slow icon on TrickPlay and FilePlay
5. Mapping blue key as check key for 91HD in filebrowser
6. Change HDD clean process on hddinit script
7. Syunchronized sleep Mode as power_control option
8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
9. Update TP information Thor0.8W and Astra 19.2E
10. Fixed many small bugs
Note.
1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
2. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
http://www.upload-drive.com/file/68/...oboot-zip.html
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
