Dislikes:
- 82
Mbox 0.4 BETA build 0023 4-th REUPLOAD
0.4 BETA build 0023
-Fix problem with returning wrong boxid in (cached) DCW message.
-Few changes in cache code.
-Few changes in code for cards reshare.
-Added support for SSSP protocol, S line in mbox.cfg, tested only on Windows OS, on Linux OS still doesnt work!!.
-Added support for triple dragon receiver(set D on 5 in mbox.cfg).
-Few changes in code for Qbox HD receiver(set D on 6 and A on 1 in mbox.cfg).
-Information in stat.info file is just for mbox peers!!.
-Added mapping , from 1815 to 1801 in H line (mbox.cfg).
-Few changes in sssp code, affect just mbox.exe file.
-Fix problem mapping 1815 to 1801, add mapping from 1822 to 1801.
-Few changes.
-From now gboxx and mbox protocol is seperated. They are compiled in seperated files(mbox with only gboxx is in "mboxg" folder). For mbox protocol G line stay for peer.
-Added SSSP code for Linux OS, it wasnt tested!!.
http://www.upload-drive.com/8777/mbox_all_rar
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
Re: Versiuni Mbox
Mda se pare ca si-au bagat piciorul si in mbox.
Prin separarea din nou a mboxului de gbox ce mare realizare sa facut ??
