Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: Imagini DM 7000
    03 Aug 2009
    Default Re: Evolution 2.2.DM7000_multiboot
    02 Feb 2009
    Default Gemini Enigma2 v4.40
    For DM800/7020/7025/8000
    Function Buttons:
    * BLUE - Blue Panel (BP)
    * BLUE long - Picture in Picture (DM7025)
    * 2x BLUE - BP -> Gemini Extras
    * BLUE RED - File-Manager
    * RED - Recording (not for DM8000)
    * GREEN - Quickbutton / Subservices
    * YELLOW - Timeshift (not for DM8000)
    * Addon and Plugin Server
    * Cryptinfos of the channel or Cam, Stick Cam to certain channels
    * Function for managing many daemons / server (BP -> Services/Daemons)
    * optical enhancements like HD-skin, additional icons or modification of the channel list
    * Manager for format, setup or mount devices (BP -> Device-manager)
    * Additional EPG-functionality like Autosave, Refresh or different EPG-format view
    * Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
    * Quickbutton, to define functionality of the Green button via menun
    * Detailled information about your Dreambox (Menu -> Information)
    * File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
    * complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
    Information about many other functions, like "the GP2 Controlr", Rezapp or the other settings can be found at the IhaD-Board or our Wiki.
    * HD skin set as standard (800 & 8000)
    * Symlinks for USB-Devices can be added in the device manager
    * CD speed can be edited in the device manager
    * CPU Usage can be displayed in menu -> info -> hardware
    * new boot logo (800 and 8000)
    * a lot of new functions in the files manager for folders and files.
    * to disable complete BP Addon-Server, add (int=hide_addons=9) in /etc/gemini2.conf
    * to disable only Camd-Support add (int=hide_addons=1) in /etc/gemini2.conf
    Fixes + Updates:
    * construction and skin adapt to automount editor.
    * script of cron and syslog
    * jukebox, tracks can be changed faster, display of the title lenght can be changed
    * weather download
    * switch off scart at standby (7020)
    * see CVS
    * In the near future only Images from 3.7 will be supported by our addon-server. This concerns to E1-Images as well as E2.
    This image doesn't contain any keys or softcams!
    Backups or other modified images are not released by us
    and won't be supported in any way!!!
    Thanks a lot and have fun
    Your Gemini-Team
    Member Beginner Gogoman's Avatar
    07 Jun 2009
    14 Feb 2007
    Default SifTeam 1.9.4 DM 7000 & 7020
    About the new image 1.9.4
    Coder: ngc1927
    Help from: tension9000 - MaxZ4
    Betatester and friends:
    Badwolf = Dm7020s - ipbox350
    theseven = Dm7020s
    biondo79 = Ipbox250s - DM500s - DM600PVR
    Costa46 = Qbox-one - Ipbox250
    Morpheus883 = Dm500s
    nikolasi = Ipbox200s - Ipbox250s - skinner
    getdownup = IPBox250 - DM500s
    frog68 = Unixbox500
    zio = Dm500s - dm7000
    piefav = Dm7020s
    genge = Qbox-one
    rrotan = skinner
    arken = new boot logo
    1) CVS updated to 26.07.2009
    2) Now you are able to see info about packs,enable the function trought advanced panel
    3) Now you can see the latest packs and updates available on our panel
    4) Changed webif and boot images
    5) Some changes on code
    6) UPNP is available (SERVER/CLIENT)
    7) Moved vsftpd.conf in /var/etc/
    8) New flashes of qbox one are now ok
    9) Qbox manager updated(some fixes on dtt)
    10) Two new skins by nikolasi sifteam_red e sifteam_blu (thx)
    11) Added Black_Matrix gold by MX mod_RG (thanks matrix) modded by rroatan
    12) Added skin Army omega black (thanks army)
    13) Added all_languages for sifteam 1.9.4
    14) Added and fixed Multiview pack
    For the version ipbox-200@64mb you must:
    1)install the normal img for ipbox200
    2)install "serial_uboot_64.img"
    both with flashtools or Flasher
    * About Programs:
    For all sifteam images, on /var/etc/rcS.d/ you can choose a program to start(there are already some commented examples..remove "#" to active them)
    To enter in Control Panel from Emu panel you can press the yellow button (added also on webif)
    The menu Script can be opened from Control panel pressing 0(zero)
    To change the positions of Channel name or Clock you can modified by telnet the values
    (Horizontal)(50 & 80 are the default values)
    echo 50 > /var/etc/SifTeam/conf/altOraOSD
    echo 80 > /var/etc/SifTeam/conf/altCanaleOSD
    (Vertical)(10 is the default value)
    echo 10 > /var/etc/SifTeam/conf/oriOraOSD
    echo 10 > /var/etc/SifTeam/conf/oriCanaleOSD
    If the following message appear "..curl_global_init.."...please restart enigma(Menu-5-restart enigma)
    * The option Move OSD is no longer available but you can install it as external plugin
    To use the old /Var you should edit the file /var/tuxbox/config/enigma/config
    and change the text "s:/ezap/ui/skin=/share/tuxbox/enigma/skins/golden.esml" in
    ** The Q-box has not all the functions of the other boxes...for example to open the Control Panel you must press blue>yellow
    11 Apr 2008
    Fost mebru
    Post Gemini Project 4.70 DM7000
    Download :
    Gemini 4.7:
    Technical Infos:
    * Enigma of: 19.12.2008
    * GCC 3.4.4 Original CVS
    * Web Interface: 6.0.4-Expert
    * Busybox 1.01
    * Tuxtxt V1.104
    * CIFS 1.44
    * 2x BLUE - BP -> Extras/Settings
    * YELLOW - Quick-Button (can be configured via BP)
    * RED - EPG list for active channel
    * 2x RED - EPG style menu
    * GREEN - subservices
    * own Addon-Server via Internet, many addons with preview
    * Retreiving additional functions via internet from the Gemini-Server and install them automatically
    * Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
    * Create your own Satellites.xml, which only contains the Satellites you really need
    * Manual installation or deinstallation of addons
    * Different Camd´s can be linked to channels/provider (Autocam)
    * Changing the name and settings with a menu of its own
    * Possibility of establishing a second socket (/tmp/cam1.socket)
    Daemon / Server / Clients:
    * Automatic test whether the box is connected with the internet or not (To be shown in the infobar)
    * Dropbear (SSH) can be set on and off (DM500 - DM7000: Standard->off)
    * Added editor to configure the cron-daemon
    * Little Apache (HTTP-Server based on HTTPD)
    * Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
    * Inadyn (Daemon for different DYNDNS-Services)
    * Settings for syslogd
    * Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
    * Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Perfect for DVD- or Net-Drives (Editor can be found in the BP)
    * NFS-Server (based on the NFS-Kernel-Modules, not for DM500, DM500+ and DM56xx)
    Infobar / OSD / Skin / Background-Pictures:
    * Position of the Infobar can be changed without editing the skin files
    * Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins supports this function)
    * Display of EMM, ECM or "Expertinfos" are adjustable
    * Picon (displaying the Channel-Logo)
    * Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
    * Background picture can be turned off (Plasma - Fix)
    * Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
    * Changing Bootlogo via menu ( 7020 only)
    * Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
    * Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
    * Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
    Files / Devices
    * Support for CD-ROM/DVD-drives ,regardless of using IDE or USB
    * Random function for all kind of soundfiles
    * Backup function
    * Two new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
    * Support of the bigger remote on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
    * Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
    * Functions for SWAP (virtual memory). Create, delete, size and location.
    * Device-Manager for HDD / DVD / CF / USB
    * Drivers for USB-Cardreaders are now included in the Image but are not loaded automatically!
    * additional functions (e.g. dishnetwork, cache, location)
    * search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
    * Infos of the recorded movies can be shown without starting the movie
    * refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
    * autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
    * Duration of current event in the programm overview ( Menu -> Info -> EPG)
    * general information about the EPG Data (BP -> Info-> EPG-Settings)
    * a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
    * Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
    * RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
    * System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
    * Own scripts can be started via Blue Panel
    * Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
    * change the settings for recording (before Time, after-recording time,, location and recover-function)
    * Create your own satellites.xml including only the satellites you really need.
    * Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
    * alarm-clock with volume offset playing own WAV-Files
    * Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
    * Support for DreamDVD no matter wether a DVD-Drive is available or not
    * New screenshot routines (have a look at the Webif)
    * eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
    * disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
    * update system time via transponder or internet ( Protocol RFC868 )
    * eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
    * create password using the BP (BP -> Extras -> Pwassword)
    * rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
    * Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
    * Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
    * the Jukebox, Please install as addon.
    * records into different folders ( the settings have to be done in the Timer-Menu)
    * LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
    * import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
    * Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
    * USB-Cardreaders can be activeted over the menu (BP->Extra->USB-CardReader
    * With the variables "show_gemini_server" and "show_camd_plugins" the addondownload and the server can be influenced (/var/etc/Gemini.conf)
    Fix + update:
    * After- and Prerun at records increased to 20 minutes
    * after a backup-restore the datas are available immediately, eg. bouquets
    * Crash at web-access to PMT-Pid without a valid PAT
    * Flickering of the popup "Channel change: Service not found"
    * Prevent the popup "Channel change: Service not found" while the rotor is moving
    * have a look at the CVS
    Interfaces WebIF: (ZAHL = number of cam) (ZAHL = number of cam)
    We'd like to thank everybody who participated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized by us, but must be developed by the CVS-Team
    This images doesn't contain any keys or softcams. Backups or other modified Images are not released by and won't be supported in any way!!!
    Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
    The use of this Image is on your own risk.
    If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
    if several processes running in background. We take no responsibility for direct or indirect damages!
    16 Feb 2009
    Default Zombi Backup TDW 7000 Multiboot
    rpobata si rasprobata funtioneaza perfect si are cam tot ce ii trebuie. Si se descarca de aici
    07 Jun 2009
    Default Gogoman Backup DM 7000
    Gogoman Backup Gemini 4.70 - DM7000 Multiboot
    ---------- Post added at 20:26 ---------- Previous post was at 20:24 ----------
    reload by gogoman
    FTP Pass a-s-c-a-n-i-o
    ---------- Post added at 20:28 ---------- Previous post was at 20:26 ----------
    Gogoman Backup PLi® Jade3 - DM7000 Multiboot
    07 Jun 2009
    Gogoman Backup Nabilosat DarkStar II - DM7000 Multiboot
    ---------- Post added at 20:30 ---------- Previous post was at 20:29 ----------
    Gogoman Backup Evolution 2.7 Dreambox 7000
    Instal Evolution 2.7 Dreambox edition
    Put backup.tar.gz via FTP on tmp
    Go to Blue Pannel-Setting-Backup manager-ok
    Install var backup-ok-restart-done
    Download Evolution 2.7
    Download Backup
    07 Jun 2009
    Gogoman Backup EDG-Nemesis-5.0.Beta Dreambox 7000
    DREAMBOX 8000
    DREAMBOX 7000
    Inverto IDLP-001QTF
    STRONG SRT V50/col
    PARABOLA 1,5 m
    07 Jun 2009
    Gogoman Backup TDW 1.70 DM7000 Multiboot
    DREAMBOX 8000
    DREAMBOX 7000
    Inverto IDLP-001QTF
    STRONG SRT V50/col
    PARABOLA 1,5 m
    17 Jan 2010
    Thumbs up ich brauche hilfe
    ich würde gerne disen link downloaden
    das ist der software
