E "unstable" !?
Noua imagine PLI -> OpenPLi-unstable-dm500-maxvar-20100120-68.img
Pentru celelalte modele DM, detalii gasiti pe pagina oficiala PLI
DM500S Nemesis 4.4.1 Skin Rihanna blue and CCcam2.1.4 by Marwen
with :
*Easylogo V1.2
*CCcam 2.1.4
*CCcaminfo V1.1
* Rihanna Blue
*Nagrab
*Free space in Var 83%
langueges = arabic+english+french
DOWNLOAD
Code:http://www.4shared.com/file/225841035/102644c8/New_Nemesis_441_Skin_Rihanna_b.html
Nabilosat Darkstar II_Skin Original_SPCS_2.5.16&CCCam_2.1.4_Maxvar_Mod cool753_25.02.2010
Cod HTML:
cool753;
1 st release 25.02.2010
new modification ;
-new bootlogo arabic-sat
-Emu: Spcs 2.5.16 inside (start with image..in blue panel withe volume button for the built-Emu )
-Emu: CCcam2.1.4 inside (start with image..in blue panel withe volume button for the built-Emu )
-send reader.bin in /var/tuxbox/config with ftp
-send CCcam.cfg in /var/ect with ftp
-Skin orginal (Dark)
-French &English language
-big var 77% Free espace with Spcs emu and CCcam and more
-add = CCcaminfo&and Ecminfo&Mgcamdinfo&HackSatKeys V9a&Ngrab recording=inside image (Yellow Button)
-add softcam (entv,foxlife....)
-disable MHW EPG (no frezz)
-Fast image to open channels with Spcs&CCcam
-send this image withe dreamup or falshwizard .
http://www.4shared.com/file/22968811..._Skin_Ori.html
Salut
eu am verificat aceasta imagine pe un dm500s dar imaginea nu este ok are cateva nereguli si in plus ai multe de configurat la ea dupa ce ai instalat aceasta imagine nu tine minte nici macar ceasul , il reglezi si dupa primul restart revine la loc adica tot asa cum vrea ea imaginea nu dupa fusul orar unde te afli tu si are multe altele defectiuni va las sa le gasiti voi testand aceasta imagine .
eu zic , ca aceasta imagine inca nu este ok mai este de lucru la ea pana sa fie la vreo versiune finala ( corecta in toate punctele de vedere )
singurul lucru OK la ea este ca ocupa spatiu putin in var ocupa doar 26% dupa ce ai intalat imaginea .
In rest este bataie de cap cu ea .
Bafta in continuare la teste .
Am instalat-o si eu de 2 zile....in afara de nepastrarea fusului orar ales , nu am gasit nici o alta problema....De configurat nu faci in plus nimic fata de o alta img. pt. Dream500...Iti alegi satelitul dorit, dai cautare si salvezi!In rest , ceea ce ai nevoie vine preinstalat! Deci nu e chiar de aruncat ...Parerea mea!
daca zici tu asa sa fie
Eu doar miam expus parerea
dar si la transponderi nu scaneaza decat 54 si pe ceilalti pana la 80 si ceva trebuie sai bagi manual plus scrisul la info la fiecare canal in parte este foarte mare si altele .........
am pus alta imagine ca daca o mai aveam imaginea asta pusa iti spuneam tot cea ce nu este ok la ea .
EDG-NEMSSIS_4.4._Skin Rihana_Special_SPCS_2.5.16_Maxvar_27.02.2010
new modification ;
-exlusive new bootlogo arabic-sat
-Skin Rihana_Special
-Arabic&French &English language
-new logo for (scan-radio-mp3)
-big var 81% Free espace with CCcam emu and more
-add = CCcaminfo&and Ecminfo&Mgcamdinfo&Key updater v0.4&Ngrab recording&Tuxbox Commander&Teletext=inside image (Yellow Button)
-add extra (addons:emu)
-Fast image to open channels with CCcam
-send this image with dreamup or falshwizard
http://www.4shared.com/file/23236552...ihana_Spe.html
Evolution 2.4 Dreambox edition
Dreambox 500
Technical Infos:
CVS Version: 09.03.2010
Linux kernel version: 2.6.9
GCC 3.4.4 Original CVS
Web Inteface 6.0.4-Expert
Busybox 1.01
BLUE - Blue Panel (Emu Addons)
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Download Addons - Emus,keys,Plugins,Setting....
Manual Install Addons tar.bz2
Delete Addons
-------- New in Evolution 2.4------------
CVS update
Some bug fixes
DOWNLOAD DM500S Evolution 2.4
Evolution 2.4 avea ceva buguri , pornea foarte greu emulatorul. Sper ca asta sa merga bine . O testez acum .
DOWNLOAD
Evolution 2.5 Dreambox edition
Dreambox 500/56x0/7000
Technical Infos:
CVS Version: 13.03.2010
Busybox 1.01
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Delite Addons
-------- New in Evolution 2.5 --------------
Fix start Cam after reboot
Fix arabic language
Fix not working plugins on 2.4
Thanks to my freands Ohem2000,dzoni testing!!
Support and bug report: www.satkeynet.com/forum
This image doesn't include keys or emulators.
satkeynet is not responsible any damage caused by this software.[COLOR="Blue"]
Nabilosat darkstar2 with cccam 2.2.1 skin Rihana Net
New bootlogo Hd
Cccam 2.2.1 integrate with cccaminfo and ecm info hacksatkeys nagrab signal Quality .teletext
Free Espace En Var 74%
http://www.girlshare.ro/1738668.8
un link nou? asta ma duce pe ... alt site
Image Eagle5.2-_-Emo CCcam2.2.1 and Mgcamd1.35a-_-Mdmugen
Image Eagle 5.2 and Amendments by
Of amendments that I have made the following
* change the original knife knife Black Matrix HD converter from Enigma2 to Enigma1 where you convert it to this picture and the amendment at large of the fonts to the windows and Kmalk Alskinat worked in the two types of this knife, one with windows normal and the second as the new windows in the bottom of the image channels participation (2 in 1).
* HD image of a beautiful start with the possibility of change with ease.
* Arabization of Hisham's line with the possibility of changing the font, and the integration of language Kmalk Max and French languages with the ability to delete from the deletion.
* amendment to the button Help to change the menus and direct recording.
* amendment to the selection of Arabic channels of movies directly to supporting the Arabic translation.
* As you prepare a list of the settings in the Settings Monte only need to put Ebi computer and file name Elsher working sword and then mount and begins the registry directly.
* change the path of pictures ( startup , radio , search , and the MP3 ) and File Kmalk local time and one satellite and knowledge of Arabic and a fixed channel so that you can change them simply and easily.
* change file Head.ko to become the image with Megaupload faster than normal .... I'll leave the answer for you after the experiment.
* the work of two, one with the emo CCcam 2.2.1 and the other by the Imo MgCamd 1.35a .
* Merge Pelagian CCcaminfo 1.1 and Pelagian Ngrab and Kmalk Pelagian Teletext 1.114 works great all the additions in the heart of the image with the possibility if you want to delete them.
Is very fast and beautiful, and the server works and is always updated ... Deletion region accessible like this: blue button, and then to blue and then enter the Addons Addon Manager.
Important Note: After you download the image and to adjust most settings, satellite Sign directly send a file or search for channels, channels, and then choose a specific channel and stand by the channels because the picture without doing a Restart alone ... Kmalk and after sending a file subscription entry on the list and activate Aladonz emo again by pressing the blue button then Red and finally the work is to reboot to save the new settings ...
Do not forget to change the course of my edits from the var / bin / RAED to var / RAED until there is more stability to the image
All changes have been away from the area of var to maintain the area significantly and images show the following piece
Eagle + CCcam 2.2.1
Eagle + MGcamd 1.35a
Evolution 2.6 Dreambox edition
Dreambox 500
Technical Infos:
CVS Version: 04.01.2011
Busybox 1.01
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Delete Addons
-------- New in Evolution 2.6 --------------
Update CVS
Update libc.so.6 (important)
Fix Oscam new version not working (symbol getaddrinfo)
Fix total tv epg
Fix not working plugins on dm500
Fix VLCF on dm500
Fixes......
New Bootlogo
DOWNLOAD Evolution 2.6 DM500S
