Thanks Thanks:  1
Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: Imagini DM 500
    Default Imagini DM 500
    The Original Enigma1 PLi® Jade Final suite contains the following images:
    * PLi®-Jade-DM500
    * PLi®-Jade-DM500-MaxVar
    * PLi®-Jade-DM500-Old-Framebuffer
    * PLi®-Jade-DM500-MaxVar-Old-Framebuffer
    [Old-Framebuffer: only needed if you have a greenish OSD when using the normal DM500 software, if in doubt use the standard DM500 software]
    * PLi®-Jade-DM500Plus
    * PLi®-Jade-DM56x0
    * PLi®-Jade-DM600
    * PLi®-Jade-DM7000
    * PLi®-Jade-DM7020
    See below for what's new & fixed since the initial PLi® Jade RC release
    Highlights:
    - Satellite.xml split in Ka, Ku, C, S, L band
    - Remote control behaviour reverted to pre-Jade
    * (Some remotes suffered from very bad reception in the Jade RC)
    - North America scan fix by Updatelee
    - CDK Flashtool: support flashing between standard partition layout and 'MaxVar' partition layout!
    * ('Var' partition is erased when the layout changes)
    - Rotor improvement for the OpenEmbedded (OE) boxes
    Enigma1:
    - CVS Repository June 29th 2008
    - PLi® Repository September 29th 2008
    - Enigma Movieplayer fixed by ims
    - Default sleeptimer now 30 minutes
    - Insert and delete character support for DM500 remotes (Red and Green)
    * Now Red (delete) en Green (insert) can be used.
    * For all other boxes Vol+/Vol- and Red/Green can be used - it does not care...
    - Remote control behaviour restored to pre-Jade
    - Fixed 'DM7000 style' remote control for DM500
    * (Added the ability to use the DM600, 7000, 7020 large remote on your DM500, DM56x0)
    - Show serviceselector again with TV/RADIO key, but only if the mode already was TV resp. RADIO.
    * Toggling TV/RADIO doesn't bring up the service selector
    - Timeshift delay input value limited to 999 instead of 60 seconds
    - Timeshift / recording support for DM500+ (settings equal to DM600)
    * (Smooth start and faster rotating at 18 V, motor stop detection improved)
    Plugins:
    - Bitrate plugin fixes for NTSC
    PPanel:
    - Channelsetting reload in PPanel fixed
    EPG Features:
    - Use audio key for searchEPG in EPG channel
    OSD Features:
    - OSD transparancy setting in smaller steps for DM500+ and DM600 (5 instead of 25)
    Web Interface Fixes:
    - Some info in WebIf missing for IE fixed by ims
    Network:
    - Enable network and DHCP as default in case the Enigma config is not copied from /Var_init
    * May fix some move /Var to network issues
    - Do NOT add manually created mounts to the Enigma mount.conf
    * It can cause double mounts if such a mount was already done in /Var/etc/init
    Highlights DM500 MaxVar:
    We've created 1Mb extra /Var space for you...
    The removed items are now available via the PLi® downloads at the Software Management
    We rebuilt the internal Flash tool completely!
    So now you can flash back and forward between the standard PLi DM500 images and the PLi DM500-MaxVar images without using the serial cable!!!
    We advise you to use the 'root.cramfs' method for this!
    See the url below on how to Flash your DM500 via the 'root.cramfs' method:
    See our DM500 Installation Wiki...
    Moved to Software Management downloads:
    - MV EPG plugin, Mediapli_8 skin, CCcam SoftCam, Cables/Terrestrial.xml, Translations, Games, traceroute, nslookup, IPtables, Netfilter drivers
    Further:
    - Thanks to Updatelee for North America scan fix
    Thanks to the PLi testers for several fixes and features
    Support:
    - Online update support (IPKG feed) for OpenEmbedded boxes
    * (DM500Plus/DM600/DM7020)
    - Global satellites.xml updated September 29th 2008
    * (DVB-S: FEC = Automatic; DVB-S2: FEC = Normal; DVB-S2 can't handle auto-FEC)
    - Satellites.xml split in Ka, Ku, C, S, L band
    See our PLi® Wiki...
    Further, our Pli member Jonc created a Wikipedia Tool and PDA WYSIWYG Desktop Application for the PLi Dreambox images
    If this DM500 version proves all OK, he will put the other Wikipedia Tools and PDA WebIf version online for the DM56x0, DM500+, DM600, DM7000, DM7020 and the limited E2 wiki.
    http://www.pli-images.org/downloads....download_id=56
    Default Nabilosat DarkStar II DM500s
    Nabilosat DarkStar II E1
    For dm500
    What is new in this DarkStar II DM500 ?
    Updated CVS: 30 August 2008
    The image has been completely recoded based on the latest CVS
    Updated Skin by porto
    New DarkStar II skin customized by porto
    Enigma 1 Integrated 8 Days Sky IT EPG
    Download 8 days Sky IT EPG, and have it integrated to Enigma1
    EPG Event Search
    Select a single channel EPG, press 0, enter a keyword and search for your preferred events
    EPG Channels Selection
    Customize the list of EPG channels to download.We reccomend to restart Enigma upon completing the selection
    EPG Channels Update List
    Update the EPG channels list when there are changes
    Standby after reboot
    Your DM will automatically standby after an accidental reboot, such as after a powercut
    Scheduled Reboot
    Schedule an automatic daily reboot
    Network fix
    This feature is for DM7020 versions
    Updated OpenVPN Kernel Module
    The OpenVPN module has been updated. Fully included in DM7020.
    Warning Do not download the OpenVPN plugin from the Yellow Panel to DM7020
    Main Function Keys
    Button 1xOK = Light Info OSD
    Button 2xOK = Extra Info OSD
    Button Blue = Nabilo Blue Panel
    Button 2xBlue = Nabilo Extra Settings
    Button Yellow = Nabilo Yellow Panel - Plugins List
    Button 2xYellow = Nabilo Yellow Panel - Addons Manager
    Button Red = Current Channel EPG
    Button 2xRed = Select Channel EPG or MultiEPG
    Features
    Addons
    Dedicated Addons Server
    Download and install additional packages from Nabilosat server
    Infobar/OSD
    Enigma1 Analogic Clock
    Channel Orbital Position
    Signal SNR, AGC, BER
    Infobar Picons
    Advanced EMU information
    Nabilo Panels features
    1) Blue Panel
    Extra Settings
    Swap File Settings
    Inadyn
    Hard Disk Settings
    Nabilo EPG Settings
    Nabilo OSD Preferences
    Nabilo Scheduler
    Network Services Panel
    NFS Server Panel
    Mount Points
    System Info
    Dreambox
    Mount Points Info
    Process Info
    Memory Info
    Enigma Setup
    Bitstream
    Save
    Select/Start/Restart EMU
    2) Yellow Panel
    Forums
    Shoutbox
    Addons
    Scripts
    Addons Download Manager
    Manual Install Panel
    Addons Uninstall Panel
    Images Uninstall Panel
    Nabilosat Statistics
    Many thanks to the Beta Testers Team
    Black33, ^^Corrado^^, ^^Maximo II^^, greg, Matrix10, Porto, ^)0(^Nabilo^)0(^, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, frimmino, astemio, DeepDiver
    Credits
    Sky IT Epg fully integrated to Enigma 1 by the great MaxZ4.
    Many Thanks to lukkino (VDR-Italia) for opentv source code.
    http://www.dreambox.it/news/view.php?id=7098
    13 Feb 2007
    Earth
    Post PLI-Jade with Gbox+CcCam 2.0.11 Ems (Backup)
    PLI-Jade latest
    fully installed to work with:
    Gbox2.1b
    CcCam 2.0.11 (latest)
    Both emulators can be working together
    Gbox Share Center 1.50 added
    Stable and fast sharing
    Note: the file should be sent to your DM500S via Flashwizard
    download :
    http://fbx.ro/fzccdqirnhloga9o
    38 Post(s)
    Default SifTeam 1.9.3C 500MV
    SifTeam 1.9.3C 500MV vom 19.12.08
    DB500:
    Usable to flash
    * Enigma of: 18.12.2008
    * Linux version 2.6.9
    * GCC 3.4.4 Original CVS
    * Web Interface: 6.0.2-Expert
    * Busybox 1.01
    * Tuxtxt v. 1.99
    ALL DECODER ( same options not present to Qbox-one
    - IPBOX200s - DM500 - DM500+ - DM5620 ):
    Buttons:
    * 1 x BLUE = Emu Panel
    * 1 x Yellow = Plugins
    * 1 x Green = Addons Panel
    * 1 x Red = EPG ( settable from Control Pannel )
    * BLUE > 1 sec = Control Panel ( new version "visual" )
    * Yellow > 1 sec. = Personal Plugin ( settable from Control Pannel )
    * Green > 1 sec. = Personal Plugin ( settable from Control Pannel )
    Features:
    * Advanced MINICROND system configuration, with more script
    added (restart cam, restart openvpn ecc..)
    * Advanced FIREWALL with graphics start/stop/configuration
    * Advanced HDD with graphics configuration
    * Advanced SWAP with graphics start/stop/configuration
    * Advanced OPENVPN with graphics start/stop/configuration
    (have to install online package)
    * Advanced DROPBEARSSH with graphics start/stop/configuration
    * Advanced INADYN-DNS with graphics start/stop/configuration
    * Advanced NFS with graphics start/stop/configuration (have to install
    online package)
    * Settable PICON directory
    * Automount HDD USB CF
    * Advanced SCRIPT options for personal set ( name to button is modifiable
    from Control Panel)
    * Formatting USB ( into 500 and 200 not have USB option, have manage
    remote control and free memory)
    * Advanced EPG options (is possible set personal EPG from Control
    Panel or use standard EPG)
    * Advanced Manage of Button Yellow and Green, is possible add one
    plugin to this buttons
    * Simple BACKUP with graphics start/stop/configuration (for save one dir.
    to extern support)
    * Advanced SAMBA with graphics start/stop/configuration (7020 - 600pvr
    - 500plus have samba installed from default)
    * Color set to RGB from default ( for lcd TV)
    * Inserted DM7020 Network Fix
    * Reiserfs and VFAT supported
    * Synchronize date from Internet
    * WebIf information (ecm.info with reload option)
    * New Button for second url (for download personel addons)
    * Autostandby if decoder turn off in bad mode (crash power ecc..)
    Display Function:
    * Set zap without OSD (if press OK return OSD)
    * Set OSD always on when OK is pressed (required from nokia9k
    * Display Snr, Agc, Ber
    * Display video information
    * Display frequency, polarization, symbol rate
    * Display emu in use
    * Display service providers name
    * Display CaID, ProvID, PID (you can hide from options)
    * Display Decoding Source (you can hide from options)
    * Picon, already inserted to enigma code (thanks to jlmota)
    * SkinPreview (thanks to jlmota)
    * Skin Lite/Full, when Lite ..if no OSD present, and press OK see Full
    (thanks to tension for help)
    * Emu Panel now have image with icon report of decode
    * Fulltime
    * Analogic Clock
    * Move OSD (thanks to tension9000)
    * Always 16:9 settable in all decoder
    * Time visible in screen
    * Name channel visible in screen
    EMU:
    * Set Default CAM
    * Set channel CAM
    * Set provider CAM
    * Stop active CAM
    Addons:
    * Internet addons download
    * Manual addons install
    * Remove installed addons
    Misc:
    * Italian, English language
    * Many language in download
    * Picon for -skyit+italian channel- is already installed
    * Several Plugins/Games/Addons installed
    * IPBOX200S have UHF in/out
    * IPBOX200S ...for free memory (if is necessary):
    1) Go to free channel
    2) Click to "Free Memory"
    ...now is possible to start/stop install/remove visualize script ecc..
    * For use your personal Addons server, create file:
    /var/etc/SifTeam/tmp/url2 (that it contains your link)
    after, into server have write your cpanel-dream.xml (for dream decoder)
    or cpanel-ipbox.xml (for ipbox decoder), that contains your packages
    (for simple system, download cpanel*.xml from sifteam URL)
    THANKS TO:
    See Yellow from Control Panel for other help into this work.
    All IPBOX > ..special thanks to sandali for its branch of development ..
    and Blakskettle for any info.
    FOR ALL > porto, MaxZ4, tension9000, jlmota ..and other?
    Thanks to all and good fun
    http://www.mediafire.com/?yz3uj4yzqm9
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default PB ENIGMA DM 500 Version 3.0
    Version 3.0
    Update: 08.02.2009
    Neue Skin-Features (alle Skins sind/werden getauscht im Online-Update) ...
    in der Programmübersicht wird der Fortschritt der laufenden Sendung
    angezeigt
    *** AC3
    - Aufnahme Deaktiviren und Teletext bei Aufnahme deaktivieren ist
    im Expertenmenü schaltbar!
    *** Enigma optimiert, um 100 KB kleiner (wichtig für die CVS-Images)
    *** NAS gefixed
    *** IDE gefixed
    *** Fixes in der BA-Verwaltung
    *** Diverse kleinere Fixes
    *** Deutsche Sprachfiles ok
    http://www.upload-drive.com/8002/PB_ENIGMA_500_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    12 Aug 2007
    Default Re: PB ENIGMA DM 500 Version 3.0
    Testat , nu am gasit sa vad spatiul , cred ca sta rau la capitolul spatiului disponibil , imaginea nu e asa clara in cvbs. Poate trebuia sa testez mai mult dar ...mai sant de testat si alte imagini.
    13 Feb 2007
    Earth
    Post Re: SifTeam 1.9.3C 500MV
    Pt . incepatori :
    Backup_SifTeam-1.9.3C_2-500MV_BY_ANTR@G
    *Emu
    CCcam 2.0.11
    Mgcamd 1.31
    CCcam Info
    keydownload
    Cryptinfo
    TuxBox Commander
    WeekEPG 3.1b
    Settings
    Vhannibal Dual Feed 15-02-09
    key Incluse
    BY_ °°ANTR@G°°
    Thx..by°°ANTR@G°°
    download :
    http://rapidshare.de/files/45308786/...NTR_G.rar.html
    13 Feb 2007
    Earth
    Post SifTeam_500MV_1.9.3D>>>BACKUP
    Backup_SifTeam_500MV_1.9.3D
    CCcam 2.0.11
    Mgcamd 1.31
    Setting Vhannibal Dual Feed
    Language English Italiano
    CCcam.Info
    Cryptinfo
    keydownload
    BY_ANTR@G
    download :
    http://rapidshare.de/files/45880480/...NTR_G.rar.html
    Standard RSP member eagle's Avatar
    29 Jun 2008
    Default EagleImage V5
    Eagle V5 comes in 3 different images.
    EagleV5.0, EagleV5.1, EagleV5.2
    Updates:
    1. All Logo's changed, boot, radio, mp3 & scan.
    2. Webif Media Player version:
    If you change your IP or password You must edit the
    /vartuxbox/config/enigma/htdocs/eagle.wpl with your correct eagle login details.
    To stream via media player:
    In the webif, click on "Media Player" and choose open with "Windows Media Player"
    So long as you have bitcontrol codecs registered on your pc, it will stream perfect in
    wmp.
    To stream a radio channel:
    First start streaming on a tv channel, then switch to a radio channel.
    3. Topbalk graphics updated:
    4. Default Skin:
    New Eagle Alsat (eagle.esml)
    5. Fonts:
    Updated
    6. Config Updated:
    /var_init/tuxbox/config/enigma/config
    Set the default skin to eagle.esml
    7. rcdm5xxx.xml:
    Replaced with the one advised in Team Section.
    8. satellites.xml:
    Updated the latest satellites.xml, all satellites in this range (45.0W - 69.0'E)
    Edited according to Eagle V2 image.
    9. Streampes:
    Updated to latest version from bitcontrol
    10. Shutdown Menu
    Changed to "restart your eagle"
    11. Image Versions updated in enigma.
    12. Webif Remote Control.
    Changed the picture to show Eagle Linux Box.
    13. Plugin Added:
    Restart Enigma Now
    14. Cpanel:
    Latest Cpanel.xml updated (19 June 2009)
    15: Ethernet:
    Ethernet is enabled with a static ip at startup eg:
    V5.0 = 192.168.0.10
    V5.1 = 192.168.1.10
    V5.2 = 192.168.2.10
    You have 10 seconds to connect and fix or flash a new image.
    Choose your correct image:
    V5.0 if your Router Lan IP Pooling Address = 192.168.0 - 100
    In "communication setup" just set a static ip which corresponds with your image version.
    V5.1 if your Router Lan iIP Pooling Address = 192.168.1 - 100
    V5.2 if your Router Lan iIP Pooling Address = 192.168.2 - 100
    Image size = 5.020 KB
    New Image works 100% atm and very fast.(26% var used)
    Default login details
    User: root
    Password:eagle
    download
    Eaglev5_0.rar
    http://www.girlshare.ro/550226.6
    Eaglev5_1.rar
    http://www.girlshare.ro/550228.8
    Eaglev5_2.rar
    http://www.girlshare.ro/550229.9
    29 Jun 2008
    Default TDW 1.70 Maxvar for DM500
    TDW DM500 1.70 Maxvar Image
    CVS Datum: 27.03.2009
    Enigma: 27.03.2009 (tdw mod)
    Busybox: v1.01 (tdw mod)
    Kernel 2.6.9 (tdw mod)
    Tasten Belegung und standart Einstellungen
    Standard keyboard layout and settings
    Blauetaste TDW Panel
    TWD Panel Button Blue
    Gelbetaste Addons/Plugins
    Yellow button addons / plugins
    Gelbetaste Untermenu/subservise
    Yellow button submenu / subservise
    Rotetaste epg-menu
    Red Button EPG menu
    OK-Taste lang drucken erreichen sie Bluepanel
    OK button long press to reach Blue Panel
    Gelbe und Blauetaste konnen sie nach wunsch belegen
    Yellow and Blue button allows them to request proof
    TDW-Panel abschaltbar unter TDW Panel/extras/TWD Utilities/Fernbedienung
    TDW-Panel, TDW-Panel under disconnectible / extras / TWD Utilities / Remote
    TDW Cron Manager
    Programmverlauf der Sender im Überblick
    Program course of the transmitter at a glance
    Standart und Netzwerk ECM in der Infobar Abschaltbar
    Standard and network in the ECM infobar switched
    Zeigen standart und Netzwerk ECM und Verschlusselungsart in der Infobar
    Show standart and network encryption and ECM in the infobar
    TDW-Panel
    OK-Taste lang drucken, erreichen sie TDW-panel
    OK button long press to reach TDW-Panel
    download
    http://www.girlshare.ro/551300.2
    Default EagleImageV5 for Dm500
    DreamBox Linux FTA Fix Aug Nagra3 (Zon) Cards Ready EagleImageV5 for Dm500 00/09/09
    9-09-09
    Ready for Nagra 3 cards as long as you know the details of your box.
    Just need to edit them on var/tuxbox/config/newcs.xml
    This image is ready for nagra 3 cards but is optimized for Tv Cabo cards and his set to Hispasat, with scanned channels on 01/09/09, due to channel changes, and a Favourites list included.
    MPCS config files have updated pids list By Joebusca, so all Tv Cabo channels are recognized and work (01/09/09).
    CCcam channels info edited to match above information
    EagleImageV5 based and includes
    CCcam 2.0.4 + MPCS + NEWCS ( The only way to have nagra 3 cards showing on localhost)
    CCcam info 1.0
    MPCS Monitor
    Scanned Hispasat on 01/09/09
    Tv Cabo Favourite list
    Image login details
    The new FTA Fix File.
    Load the new FTA Fix File and set auto roll to "ON" and wait up to 15 min for the keys to auto roll.
    Make sure that the Auto Roll feature is turned "ON." You will find the Auto Roll feature in the Menu options.
    If you don't have the picture after 15min Reboot your system using the switch at the back of the receiver.
    * Change*
    ( Main software upgrade )
    - AR Fixed
    Note:
    - Always use Remove Device Safely function in USB Menu before remove USB drive (thumb drive/USB HDD)
    - Always format USB thumb drive before any update
    - Do not extract file direct on to the UBS thumb drive, extract to a folder then copy to USB thumb drive.
    - Do a hard reboot (power OFF-ON using rear switch) after every update.
    http://www.dvb-upload.com/index.php?...iew&pid=284467
    14 Feb 2007
    Default Evolution 2.3 Dreambox 500S edition
    Evolution 2.3 Dreambox edition
    Dreambox 500/56x0/7000
    Technical Infos:
    CVS Version: 05.12 2009
    Linux kernel version: 2.6.9
    Web Inteface 6.0.4-Expert
    Busybox 1.01
    BLUE - Blue Panel (Emu Addons)
    YELLOW - plugins
    RED - EPG
    GREEN - subservices
    Blue Panel Info:
    Start/Stop Emu
    Green - News
    Red - Sys Info
    Blue - Addons
    Yellow - Settings
    Addons info:
    Download Addons - Emus,keys,Plugins,Setting....
    Manual Install Addons tar.bz2
    Delete Addons
    -------- New in Evolution 2.3------------
    Fix CCcam bug with external card reader
    Fix restart Enigma i hope!!
    Changes in Enigma code
    Removed epg faster we have now in cvs
    Removed not needed files
    Update libc.so.6
    New boot logo
    Latest satellites.xml if you dont like it update your with dreambox edit
    New stuff in cvs
    Thanks to my freands Ohem2000,dzoni,Alucard for helping me!!
    Support and bug report: EVOLUTION
    This image doesn't include keys or emulators.
    satkeynet is not responsible any damage caused by this software.
    DOWNLOAD Evolution 2.3 for Dreambox 500S
    11 Apr 2008
    Fost mebru
    Post Gemini Project 4.70 DM500 MaxVar
    Download : http://www.easysurf.ro/j45k1ndoadw3/...122009.zip.htm
    Technical Infos:
    * Enigma of: 19.12.2008
    * Web Interface: 6.0.4-Expert
    * Busybox 1.01
    * Tuxtxt V1.104
    * CIFS 1.44
    Remotecontrol:
    * BLUE - Blue Panel (BP)
    * 2x BLUE - BP -> Extras/Settings
    * YELLOW - Quick-Button (can be configured via BP)
    * RED - EPG list for active channel
    * 2x RED - EPG style menu
    * GREEN - subservices
    Addons:
    * own Addon-Server via Internet, many addons with preview
    * Retreiving additional functions via internet from the Gemini-Server and install them automatically
    * Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
    * Create your own Satellites.xml, which only contains the Satellites you really need
    * Manual installation or deinstallation of addons
    Camd:
    * Different Camd´s can be linked to channels/provider (Autocam)
    * Changing the name and settings with a menu of its own
    * Possibility of establishing a second socket (/tmp/cam1.socket)
    Daemon / Server / Clients:
    * Automatic test whether the box is connected with the internet or not (To be shown in the infobar)
    * Dropbear (SSH) can be set on and off (DM500 - DM7000: Standard->off)
    * Added editor to configure the cron-daemon
    * Little Apache (HTTP-Server based on HTTPD)
    * Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
    * Inadyn (Daemon for different DYNDNS-Services)
    * Settings for syslogd
    * Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
    * Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Perfect for DVD- or Net-Drives (Editor can be found in the BP)
    * NFS-Server (based on the NFS-Kernel-Modules, not for DM500, DM500+ and DM56xx)
    Infobar / OSD / Skin / Background-Pictures:
    * Position of the Infobar can be changed without editing the skin files
    * Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins supports this function)
    * Display of EMM, ECM or "Expertinfos" are adjustable
    * Picon (displaying the Channel-Logo)
    * Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
    * Background picture can be turned off (Plasma - Fix)
    * Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
    * Changing Bootlogo via menu ( 7020 only)
    * Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
    * Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
    * Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
    Files / Devices
    * Support for CD-ROM/DVD-drives ,regardless of using IDE or USB
    * Random function for all kind of soundfiles
    * Backup function
    * Two new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
    * Support of the bigger remote on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
    * Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
    * Functions for SWAP (virtual memory). Create, delete, size and location.
    * Device-Manager for HDD / DVD / CF / USB
    * Drivers for USB-Cardreaders are now included in the Image but are not loaded automatically!
    EPG
    * additional functions (e.g. dishnetwork, cache, location)
    * search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
    * Infos of the recorded movies can be shown without starting the movie
    * refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
    * autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
    * Duration of current event in the programm overview ( Menu -> Info -> EPG)
    * general information about the EPG Data (BP -> Info-> EPG-Settings)
    * a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
    Extras:
    * Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
    * RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
    * System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
    * Own scripts can be started via Blue Panel
    * Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
    * change the settings for recording (before Time, after-recording time,, location and recover-function)
    * Create your own satellites.xml including only the satellites you really need.
    * Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
    * alarm-clock with volume offset playing own WAV-Files
    * Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
    * Support for DreamDVD no matter wether a DVD-Drive is available or not
    * New screenshot routines (have a look at the Webif)
    * eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
    * disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
    * update system time via transponder or internet ( Protocol RFC868 )
    * eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
    * create password using the BP (BP -> Extras -> Pwassword)
    * rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
    * Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
    * Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
    * the Jukebox, Please install as addon.
    Recordings:
    * records into different folders ( the settings have to be done in the Timer-Menu)
    * LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
    * import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
    * Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
    New:
    * USB-Cardreaders can be activeted over the menu (BP->Extra->USB-CardReader
    * With the variables "show_gemini_server" and "show_camd_plugins" the addondownload and the server can be influenced (/var/etc/Gemini.conf)
    Fix + update:
    * After- and Prerun at records increased to 20 minutes
    * after a backup-restore the datas are available immediately, eg. bouquets
    * Crash at web-access to PMT-Pid without a valid PAT
    * Flickering of the popup "Channel change: Service not found"
    * Prevent the popup "Channel change: Service not found" while the rotor is moving
    * have a look at the CVS
    Interfaces WebIF:
    http://127.0.0.1/cgi-bin/GeminiInfo
    http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/InitCam
    http://127.0.0.1/cgi-bin/ResetCam
    http://127.0.0.1/cgi-bin/setKey?typ=...est&val=blabla
    http://127.0.0.1/cgi-bin/getKey?typ=...tedvb/int-test
    We'd like to thank everybody who participated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized by us, but must be developed by the CVS-Team
    This images doesn't contain any keys or softcams. Backups or other modified Images are not released by and won't be supported in any way!!!
    Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
    The use of this Image is on your own risk.
    Recommendation:
    If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
    if several processes running in background. We take no responsibility for direct or indirect damages!
    11 Apr 2008
    Fost mebru
    Post Gemini 4.70 DM Ara drhg NO-Bomb
    Gemini 4.70 Ara drhg NO-Bomb
    Download : http://www.easysurf.ro/pot53vekt61e/...O-bomb.zip.htm
    14 Feb 2007
    Pentru posesorii de clone fani GP care nu vor sa isi asume riscul, aceasta imagine pare a fi o solutie OK, deoarece la prima vedere pare ca s-a eliminat din cea postata de IHAD doar time bomb, in rest este identica. Daca mai punem la socoteala si faptul ca logo-ul de boot poate fi schimbat cu unul personalizat atunci chiar ca merita sa i se acorde o atentie sporita fata de celelalte alternative.
