Nou sifteam pt ipbox 910HD
*Nu e beta version
http://www.upload-drive.com/6090/910...noboot_img_zip
*From 0.1.9:
First release for 910HD
http://www.upload-drive.com/3954/usb_all_noboot_img
*Nu e beta version
1. Added "post-descrambling with CAM" function on system settings menu
: When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
and then you can descramble the recorded file later.
- The channel in record cannot be watchable.
- The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
- even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
(Caution)
The recorded file must be performed ˇ°descramblingˇ± before the next smartcard update.
If descrambling is not running, it is impossible to do the file descrambling anymore
or able to damage the smartcard since the smartcard has already been updated.
2. Added HUB function for USB host.
3. Fixed record programs with DVB subtitle.
4. Support adjust LipSync using page up/down buttons in Videoplayer
5. Support NFS function for Linux System in Mount manager
- changed NFS config in /etc/exports
ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
- Removed the firewall of system
- Removed the firewall of IP table when your system is Fedora
# iptables -F
6. Support displays elapsing time on banner of MP3 player
7. Support Sort function on TMP folder in Recorded files menu
8. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
9. Updated language table for Slovak, Bulgarian, Polish and Russian
10. Fixed DVB EPG bug for HB13 10891
11. Fixed elapsing time error when schedule recording.
12. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
13. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
14. Added WSS function through SCART
http://dreambox.sifteam.eu/index.php?dir=9000HD/r8718/
1. Support *.mkv with video player.
- If the file needs higher class CODEC, the file will not be playback with video player .
- In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
2. Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
3. Fixed some bug for schedule recording.
4. Fixed record subtitle.
known issue : DVB subtitle color problem
http://www.upload-drive.com/6226/910...noboot_img_zip
Version 0.2.0
Added default password as "sifteam"
Added script "advanced.command.sh" ..for:
Add NFS disk
Remove NFS disk
Make USB for use as Disk (in congiuntion with NFS option is very good)
Move /var in part1 of disk or USB (part1 = first partition)
Removed any files (script)
Added script for see proper card permission
ftp://9000hd.sifteam.eu/r8873/910HD-...ate.img.tar.gz
Sifteam r9047
http://dreambox.sifteam.eu/index.php..._update.tar.gz
Sifteam r9207
1. Added 4:3 zoom function on 16:9 TV system
2. Added Ukraine language on the menu
3. Added Display with channel numbers on front display instead of the non-Latin characters
4. Keep the current file system without automatic format even though the file system is ext2 or ext3.
5. Fixed File name bug of the main recording event on EPG Schedule Record
6. Fixed CSLink panic on ASTRA 23.5E 11876
7. Fixed Web interface bugs(no RCU image, 250HD didn't work Web interface, etc) and Update Web interface version
it should be downloaded usb_all_noboot.img for upgrading this function
8. Fixed Display strange EPG time info on the banner
9. Fixed Subtitle sync.
10. Fixed Audio jerky on BadrC(26.E) 11938V
11. Fixed A/V Freeze of some HD & SD channels in Turksat, Eutelsat and so on.
12. Updated Russian and Czech language.(Russian is translated by Andrei Nazarenko, thank you Andrei)
13. Updated Smartcard driver
14.
Added Drag interval adjustment preciesely such as 10 sec, 30sec, 1min,
5min, 10min, 30min, 1hour in recorded files or timeshift
- Adjustment: 1. menu, 2. direct buttons only with "Recorded files" with Pg+/- on RCU.
15. Added auto restart function when panic happens
Note.
1. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2.
you should download usb_all_noboot.img into STB for improving Web
interface and plugins, otherwise, the function will be the same as
previous one.
P.S. Adaug eu: un PPV canalul 1, merge audio
Exista doar un lucru bun, stiinta, si doar unul rau, nestiinta.
