Results 1 to 1 of 1
Thread: Multiboot for SifTeam-dgs in flash
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Exclamation Multiboot for SifTeam-dgs in flash
    putting these file on your box you will be able to start when your box boots choosing the image you want
    about buttons...following Tideglo's choices(he is the enigma2 developer for sifteam images on ipbox hd) you can:
    -pressing 1 =NFS
    -pressing 2= USB (without internal hd /dev/sda1)
    -pressing 3= USB (with internal hd /dev/sda1)
    -pressing 4=Flash
    at the next reboot you have only press the button to change images
    How install them:
    -rename the file for your box in usb_update.img-send and install it following the usb modality
    thx sifteam
    *Note
    the next firmware will have already it inside
    Attached Files Attached Files
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
