Results 1 to 8 of 8
Thread: IPBOX 910 **DGS firmware**
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default IPBOX 910 **DGS firmware**
    DGS official Cuberevo-3000HD r8471
    1. You should download all the attached images in order.
    2. That is better for you to backup channel list using PC Editor before downloading the above images.
    Reference)
    You can get s/w image from http://www.dgstation.co.kr/release/cuberevo-3000hd_r8471.zip
    Caution)
    1. If you use the software of the previous version, you should dowload the usb_kernel_root_db.img using flashtool via usb cable.
    2. Unplugging the power code may cause serious damage on Cuberevo while usb_kernel_root_db img's downloading.
    Please refer to README file before you start downloading the firmware attached above.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8718 910HD
    DGS release r8718: ( 24/Dec/2008)
    1. Added "post-descrambling with CAM" function on system settings menu
    : When this option is enabled and the smartcard and the CI CAM is used for another work, it records the program without descrambling,
    and then you can descramble the recorded file later.
    - The channel in record cannot be watchable.
    - The recorded file can not be descrambled before post-descrambling with CAM enabled on the menu.
    - even if Post-descrambling with CAM option is diabled, the scrambled program can be recorded, but not descrambled.
    (Caution)
    The recorded file must be performed ˇ°descramblingˇ± before the next smartcard update.
    If descrambling is not running, it is impossible to do the file descrambling anymore
    or able to damage the smartcard since the smartcard has already been updated.
    2. Added HUB function for USB host.
    3. Fixed record programs with DVB subtitle.
    4. Support adjust LipSync using page up/down buttons in Videoplayer
    5. Support NFS function for Linux System in Mount manager
    - changed NFS config in /etc/exports
    ex) /home/user_path/share 100.100.100.0/255.255.255.0(rw,no_root_squash,sync)
    - Removed the firewall of system
    - Removed the firewall of IP table when your system is Fedora
    # iptables -F
    6. Support displays elapsing time on banner of MP3 player
    7. Support Sort function on TMP folder in Recorded files menu
    8. Support auto adjustment local time during boot up if the time variation is less than 10 minutes.
    9. Updated language table for Slovak, Bulgarian, Polish and Russian
    10. Fixed DVB EPG bug for HB13 10891
    11. Fixed elapsing time error when schedule recording.
    12. Added ITV HD audio or video type options as AC3, H.264, MPEG 2 etc in Advanced Search menu
    13. Fixed bugs in scanning and zapping of the channels with diseqc and usals.
    14. Added WSS function through SCART
    http://dev.dgstation.co.kr/release/c...718.242044.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r8728 910HD
    Th is README is for CubeRevo HD model series.
    This document was approved on 26/Dec/2008 by the DGSTATION.
    DGS release r8728: ( 26/Dec/2008)
    1. Support *.mkv with video player.
    - If the file needs higher class CODEC, the file will not be playback with video player .
    - In case of too higher bitrate file, it possible to make a problem for playback (especially *.vob and *.mkv.).
    2. Fixed crashing problem with higher symbol rate as 30,000(S/R) TP.
    3. Fixed some bug for schedule recording.
    4. Fixed record subtitle.
    known issue : DVB subtitle color problem
    http://dev.dgstation.co.kr/release/c...728.270214.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    26 Dec 2008
    Dublin, IRL
    Default DGS r8873 910HD
    Image version : r8873
    DB version : r8118
    This README is for CubeRevo HD model series.
    This document was approved on 22/Jan/2008 by the DGSTATION.
    DGS release r8873: ( 22/Jan/2009)
    1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet.
    press once FF or REW button, the interval is 10 seconds.
    press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
    2. Add Scan option on Channel Scan Menu
    When there is no channel list, all these options create with the same result.
    - Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list.
    - Smart scan : remove current channel list , and scan, and then update FAV list according to the new channel list.
    - Reset scan: remove all of the current channels and FAV group, then scan with new channel data.
    3. Add USB upgrade menu
    - Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode
    it is useful for software upgrade with USB morory stick.
    4. Fixed EPG contents Display
    - inserted new line on the screen for EPG and extended EPG information as well
    5. Fixed DVB subtitle - color table
    6. Fixed OSD teletext - some old data not updated occassionally
    7. Fixed wrong duration with the file after schedule recording with EPG
    8. Fixed Local time auto update
    - When the last channel time of the Satellite is different from the STB time within 10 minutes,
    the STB time is automatically adjusted with the Satellite time during the STB booting.
    9. Updated Polish language table.
    10. Updated Web-interface
    11. Fixed small bugs
    known issues : sync with audio and subtitle
    artefact with premiere HD channels from satellite and cable
    no audio with such as Digifilm channel
    adjust color table of DVB subtitle for some channels
    http://dev.dgstation.co.kr/release/c...873.221307.zip
    26 Dec 2008
    Dublin, IRL
    Default DGS release r9047 910HD
    Image version : r9047
    DB version : r8118
    DGS release r9047: ( 5/Mar/2009)
    1. Added additional channel scan options for TV or Radio
    2. Added repeat function in Video Player
    3. Added navigation method for TTXT sub-channel
    4. Display the summary when searching channel
    5. Save the name of recorded file when user want to schedule in EPG
    6. Fixed bug Toptext navigation with TTXT
    7. Fixed bug which was CubeRevo always blocked when first boot After update
    new software
    8. Fixed bug which was CubeRevo-250HD and CubeRevo-mini were not updated
    local timer after AC power off even with Automatic time setting
    9. Fixed Alphacrypt German Language Encoding bug
    10. Included some of the new plugins in CubeRevo SW version.
    - Thanks as below developper for plugin.
    They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
    dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
    pong, sudoku, tetris, andd weather of Neumoteam.
    11. Updated German language translated by Nilse
    12. Removed subtitle language setting in Language Settings Menu
    users control through subtitle option on RCU.
    13. Modified pop up message 'Service is not available' disappears after 5~6
    seconds automatically
    14. Adjusted the position of Pillar box
    15. Adjusted color table of DVB subtitle for some channels
    Note.
    1. Added Multi booting function
    If you want to multi-boot, download usb_config.img in our homepage(www.dgstation.co.kr)
    Then press number button on RCU which you want booting mode.
    Multi-booting support as below. Official image is number 3.
    1) boot from cdkroot
    2) boot from USB with hdd
    3) original images
    4) boot from release
    5) boot from USB without hdd
    6) boot from SATA hdd
    7) boot from flash
    2. The Digifilm channel works in official CAM.
    http://dev.dgstation.co.kr/release/c...047.051221.zip
    26 Dec 2008
    Dublin, IRL
    Default DGS release r9207 910HD
    DGS release r9207: ( 3/Apr/2009)
    1. Added 4:3 zoom function on 16:9 TV system
    2. Added Ukraine language on the menu
    3. Added Display with channel numbers on front display instead of the non-Latin characters
    4. Keep the current file system without automatic format even though the file system is ext2 or ext3.
    5. Fixed File name bug of the main recording event on EPG Schedule Record
    6. Fixed CSLink panic on ASTRA 23.5E 11876
    7. Fixed Web interface bugs(no RCU image, 250HD didn't work Web interface, etc) and Update Web interface version
    it should be downloaded usb_all_noboot.img for upgrading this function
    8. Fixed Display strange EPG time info on the banner
    9. Fixed Subtitle sync.
    10. Fixed Audio jerky on BadrC(26.E) 11938V
    11. Fixed A/V Freeze of some HD & SD channels in Turksat, Eutelsat and so on.
    12. Updated Russian and Czech language.(Russian is translated by Andrei Nazarenko, thank you Andrei)
    13. Updated Smartcard driver
    14. Added Drag interval adjustment preciesely such as 10 sec, 30sec, 1min, 5min, 10min, 30min, 1hour in recorded files or timeshift
    - Adjustment: 1. menu, 2. direct buttons only with "Recorded files" with Pg+/- on RCU.
    15. Added auto restart function when panic happens
    Note.
    1. ext3 file system is slower than ext2 normally.
    If you record two HD channels with ext3 at the same time, it may fail in record.
    we have checked the speed as below
    ext2 speed : approximately 7MB/s
    ext3 speed : approximately 3MB/s
    Known issues(on going).
    1. Artefact with Premiere HD channels from satellite or cable.
    Caution.
    1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
    2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
    DOWNLOAD
    02 Feb 2007
    Default Re: IPBOX 910 **DGS firmware**
    DGS release r9580: ( 29/May/2009)
    1. Add function displaying time always on Front panel
    2. Add schedule recording title name on webif
    3. Fixed video player panic when spdif is off
    4. Fixed slow icon on TrickPlay and FilePlay
    5. Mapping blue key as check key for 250-hd in filebrowser
    6. Change hdd clean process on hddinit script
    7. Syunchronized sleep Mode as power_control option
    8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
    9. Update tp information Thor0.8W and Astra 19.2E
    10. Fixed many small bugs
    Note.
    1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
    As you know, even if the Filename Extension is different each other,
    if the video codec is same each other, the two files work like same.
    If the video file's resolution is more than 720 X 576, it will works very well.
    So, we recommend below conditions.
    1) resolution : 720 X 576.
    2) FPS : 24, 25 and 30 fps.
    3) Following video and audio codec.
    Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
    Audio Codec : MP2, MP3, AC3
    When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
    If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
    2. ext3 file system is slower than ext2 normally.
    Caution.
    http://dev.dgstation.co.kr/release/cuberevo-3000HD/cuberevo-3000HD_r9580.292137.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DGS r10336
    This document was approved on 08/Aug/2009 by the DGSTATION.
    DGS release r10336: ( 08/Aug/2009)
    1. Add iCubeRevo function
    : If you have the iPhone(or iPod), you can operate the STB via iPhone(or iPod).
    More description is attached. The file name is "iCubeRevo_manual.pdf".
    2. Add streaming player function
    : Bi-directional stream transmission between STB and PC is possible.
    Several protocols(UDP, RTP) are supported. And Multicast or unicast are supported.
    More description is attached. The file name is "MultiRoom and Streaming manual.pdf".
    3. Add multiroom service function
    : Several STBs can access the Server STB and see the Server's file, mp3, video player and channels.
    4. Add M3U Player function
    : M3U is a format that stores multimedia playlists.
    Our M3U player can play XVID(Without GMC and Qpel), MPEG1, MPEG2, H.264.
    5. Improv Nordic subtitle (Canal Film HD, Silver HD, BBC HD and so on)
    : For the meantime, we didn't display subtitle without PTS or with wrong PTS.
    But, at present, we support these subtitle.
    6. Improve the channel navigation
    : You can see the faster movement at the channel, Fav, epg list and so on.
    7. Fixed incorrect aspect ratio for 4:3 channels
    : For the meantime, our STB displayed PillarBox, Zoom with a little distortion.
    8. Fixed subtitle overlaping on Hotbird.
    : Hotbird 13E 11766 V 27500 (channel name : Rai1, Rai2, Rai3)
    9. Fixed ttxt subtitle page at the specific pages(775~777)
    : Hotbird 13E 11919 V 27500 (channel name : Italia 1, Canale 5, Retequattro)
    10. Update russian language file by uncle fedor.
    11. Update german language file by Nils.
    Note.
    1. When multiroom service and streaming player is running, recording and pip doesn't support.
    2. Our Video player is related with CODEC, FPS(frame per second) and resolution.
    3. ext3 file system is slower than ext2 normally.
    2. The timeshift function of multiroom will release on the next.
    Caution.
    http://dev.dgstation.co.kr/release/c...336.080130.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
