Results 1 to 2 of 2
Thread: Inetbox 3000
    Standard RSP member maximuss's Avatar
    12 Aug 2007
    Default Inetbox 3000 s
    Am vazut pe un site clona de dm 7020 cu numele de INETBOX 3000 difera de dm lipsa display-ului , stie cineva ceva de el ? Deja am vb cu un amic sa il caute , clonele nu s-au dovedit a fi petarde asa cum spun unii .
    COMPATIBILE CON TUTTE LE IMMAGINI DEL 7020
    NO DISPLAY
    250 MHz IBM PowerPC (350 Mips)
    · Linux OP - supports standard Linux
    · API (DirectFB, Linux-FB, LIRC, ...)
    · 1 x DVB Common-Interface Slot
    · 2 x Smartcard-Reader · Embedded DreamCrypt CA
    · Integrated Compact Flash Interface Slot
    · MPEG2 Hardware decoding (DVB compliant)
    · 100 MBit full duplex Ethernet Interface
    · USB Port Keyboard
    · RS232 Interface
    · 12V switch connector
    · RF-Modulator
    · A/V output (Audio/Video cinch)
    · Big Size LCD Display
    · 64 MByte of RAM
    · Intergrated IDE UDMA66 Master/Slave
    · Support for internal HDD up to 300GB
    · Unlimited channel lists for TV/Radio
    · Channel change time < 1 second
    · Full automatic service scan
    · Supports EPG (electronic program guide)
    · Supports Videotext (insertion)
    · Multiple LNB Switching control (DiSEqC)
    · Adaptable OSD in many languages (skins)
    · SPDI/F interface out (AC-3/DTS)
    · 2 x SCART interfaces (software controlled)
    Nota: COMPATIBILE AL 100% CON TUTTE LE IMMAGINI DEL 7020
    12 Aug 2007
    Default Re: Inetbox 3000
    Am citit aici pe forum ca are cineva receptorul asta , daca poate sa ne dea detalii ar fi super.
