Likes Likes:  3
Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
Thread: Un nou player Smart DVB
    Thumbs up SmartDVB
    SmartDVB 0.5.0 RC2 is available!
    v0.5.0.36RC2
    ◾HEVC playback has been improved with this version, lentoid codec should work now also.
    ◾AAC playback might also work better with the LAV and MS AAC decoders.
    ◾Also MadVR support has been updated for the current MadVR versions.
    Código:
    https://mega.nz/#!7N8AXCzT!I7bh6aav7...7lEoMGoGygA9sg
    SmartDVB 0.5.0.51 RC3 is available!
    v0.5.0.51 RC3
    ◾Initial PLP (DVB-T2) support added.
    ◾Some enhancements to the normal scanner for INI management.
    ◾Ability to add a new channel in the channel properties dialog.
    ◾Various fixes and improvements to channel tuning.
    ◾Remotes were not working for non TBS devices, should be better now.
    Código:
    https://mega.nz/#!jQEl3T4T!_sP9LNsRx...ii-ZlOOjAX4yVc
    Pacat ca pe un tv 4K lista prg tv din stanga nu se distinge , scris foarte mic
    win32 0.5.1 portable release
    This 32 bit portable update should have all the recent 0.5.1 x64 build changes, such as unicode support, and (additional) fixes. Some added features or improvements include:
    - better zoom capabilities through a zoom dialog. You can save zoom settings on a per channel basis.
    - Somewhat better H.264 4:2:2 support, but your mileage may still vary depending on the used codecs, as usual LAV is recommended.
    - XMLTV EPG/EIT importing (experimental for now, if you find issues here please report them).
    https://mega.nz/file/7gBVVIDD#b9Yac2...DcOZBeUli-uapA
    0.5.3 x64/x86 beta test portable version now available.
    0.5.3 x64/x86 portable versions are now available. The build includes many fixes and the following improvements:
    -Added support for external splitters, including LAV Splitter support. Please note that LAV Splitter support is experimental and initial connection is slow compared to the default splitter (SmartAVSrc). So if you care most about tuning speed, and not so much about picture quality, do not use the LAV Splitter
    -Added windowed EPG viewer
    -Better support for 4:2:2, including 4k and 8k
    -Added EVR-CP (Custom Presenter) video renderer, with support for HDR and external shaders. Including support for rendered subtitles (DVB/Teletext Subtitles)and exclusive fullscreen mode.
    -improved 4:2:2 support (LAV Splitter in combination with the LAV Video Decoder plays 4:2:2 quite well)
    -improved 4k and 8k support
    -MDAPI improvements/enhancements (including x64 build fixes)
    -Extended zooming support dialog. Zoom settings can be saved per channel.
    -Improved MadVR support (also works well with the LAV Splitter)
    -Support for external multiplexers (including Microsoft MPEG2 demux, Elecard demux, Mainconcept demux etc)
    -Graph performance settings (experimental, leave the default settings if you don't really know what you're doing here)
    -Blindscan.dev improvements/fixes, added blindscan.dev device settings to set the defualt blindscan.dev tuning method.
    -Initial (experimental) CAM Menu support for TBS CI CAM devices only. Please report if you have issues with this feature as it has not been tested extensively.
    -Improvements to DVB Transport Stream file play mode video quality/stability, play HEVC DVB File option added. Please do not use transport stream recordings of sizes lower than about 100Mb as otherwise transport stream playback can be somehwat unstable.
    -Improvements to SmartOSD default scaling. Default OSD graphics changed, including EPG.
    Please note that this is a beta build, mainly due to the new features like EVR-CP which have not been tested extensively yet, otherwise the app should be stable.
    x64:
    https://mega.nz/file/f1YBGQ5D#VOkaTF...YcivgXbu9_xz_I
    x86:
    https://mega.nz/file/HkBVhQKR#4KOEeI...DzLqviiwKUZeW8
    45 Post(s)
    De 2 zile smart-dvb 0.5.3.26 si v-plug 2.4.6 nu mai lumineaza pe film now si film now hd. Pare ca citeste si decripteaza streamul dar nu lumineaza. Pe celelalte programe criptate din pachet e totul OK, bineinteles cele doua 4K nu intra in discutie.
    La dvb viewer, dvb dream nu sunt probleme cu acelasi softcam, acelasi v-plug, aceleasi setari Cred ca problema este de la vreo modificare din engine-ul intern smart dvb, nicidecum de la v-plug care isi vede de treaba. Dar cum s-a intamplat nu inteleg. Am incercat si pe alt PC dar este la fel.
    ---------- Post added at 19:54 ---------- Previous post was at 19:14 ----------
    Adaug ca fenomenul este notat doar pe versiunea beta x64, pe 86 este totul OK
    17 Jan 2008
    nici Progdvb x64 nu merge cu vplug, ia varianta x32 si nu observi nicio diferenta
    45 Post(s)
    @marcghi
    Numai la filmnow si filmnow hd se intampla fenomenul. celelalte programe criptate sunt deschise la fel ca si mai inainte.
    V-plug e OK pe alte playere, a fost si pe smart-dvb dar acum a deraiat si nu stiu de ce.
    Nu cred ca e de la v-plug, sunt sigur ca trebuie cautat in alta parte. Poate vreo actualizare de windows sau un conflict din alta parte, e ciudat.
    Nu stiu cum e pe progdvb, nu-l mai folosesc de multi ani.
    17 Jan 2008
    ma refeream la smartdvb x32 sa folosesti, nu sa schimbi playerul.
    cand scanezi cablu, ce setari de tara folosesti, oricum aleg imi pune in lista fiecare program de doua ori.
    acum observ ca nici subtitrarea dvb nu apare, chiar daca aleg din optiuni
    45 Post(s)
    Cred ca nu ne-am inteles, nu ne referim la alte playere. Nu am zis de schimbat player-ul, vorbim strict doar despre Smart DVB, unde doar cele doua programe, repet FilmNow si FilmNow HD sunt problematice si nu inteleg de ce anume!
    Dar cert nu din cauza de V-Plug care citeste si decodeaza streamingul respectiv.
    Iar ce spui de subtitrare este alt subiect, functioneaza la smart dvb, pe video render EVR sau EVR-C (EVR Custom) pe x64, iar pe x86 beta functioneaza si pe VR9.
    17 Jan 2008
    Am schimbat pe evr si merge subtrarea
    Cu lista de canale se intampla la fel ?
    De ce nu folosesti varianta x32 ? Ce are in plus x64?
    Sau vrei sa sapi sa afli care este problema, daca te pricepi atunci spor la treaba. Undeva exista un conflict intre vplug si aplicatiile x64, cum spuneam se intampla la fel si la alte playere.
    45 Post(s)
    Am spus clar ce urmaresc, ti-am raspuns si ce sa faci pentru a avea subtitrare iar tu imi tot spui sa schimb playerul. Nu asta urmaresc, ci ca sa rezolv acest conflict sau sa inteleg de unde vine. Lista scanata se memoreaza normal nu dublata indiferent de versiunea folosita. Editezi personal lista de frecvente pentru cablul tau sau folosesti optiunea de scanare full dar dureaza mult scanarea.
    17 Jan 2008
    cred ca ma intelegi gresit, spuneam sa folosesti tot Smartdvb daca asta este preferinta ta, dar varianta x32 care nu are probleme ca varianta x64
    daca ai deja instalat Smartdvb x64 si trecand la Smartdvb x32 si consideri ca asta inseamna ca schimbi playerul, atunci cauta in continuarea remediu pentru problema, cu toate ca nu vad mare lucru in a instala varianta care nu are probleme
    45 Post(s)
    Hai sa inchidem subiectul asta cu ce trebuie sa folosesc. Problema am pus-o pentru Smartdvb x64 si atat, restul comentariilor sunt pe langa subiectul ridicat.
    Am instalate si smartdvb 32 si alte playere dar asta este altceva. Daca aveam vreo problema acolo o precizam pentru sugestii.
    Sa nu-mi spui de progdvb care nu vreau sa-l mai folosesc de vreo cinci ani.
    Daca ai intrebari pune-le, daca stiu raspund, dar nu-mi spune ce sa folosesc.
    17 Jan 2008
    ai gasit rezolvarea, atunci de ce nu ne spui si noua ? ca doar tu ai deschis subiectul si ai cerut ajutor.
    45 Post(s)
    @marcghi
    Doar am semnalat aspectul, a schimba playerul in nici un caz nu era solutia asteptata.
    Editasem gresit in lista *ini cele doua canale amintitite. V-plug si SmartDVB nu au nici o treaba cu eroarea mea.
