Results 1 to 6 of 6
Thread: incubusCamd 0.55 + newcs 1.63 SIF
    23 Jun 2008
    Default incubusCamd 0.55 + newcs 1.63 SIF
    Vreau sa dezvoltati ideea:
    incubusCamd-0.55-newcs-1.63.tar.gz
    23 Jun 2008
    Default Re: incubusCamd 0.55 + newcs 1.63 SIF
    Pare totusi facatura ..newcs nu are acelasi nr de octeti iar nu cred ca merge...
    23 Jun 2008
    Nu a testat nimeni?
    E pentru E2...
    25 Oct 2007
    Chisinau
    Dar Incubus, de exemplu 94, poate fi instalat shi sa functioineze pe Dreambox 800 HD, Enigma2? A incercat cineva? sau Sa incercam noi? sau mai bine Sa nu incercam?
    02 Feb 2007
    Somewhere in Aegean Sea!!
    nu se poate incubus e fixat sa functioneaza numai pt cpu SH4.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    15 Nov 2007
    iote aici...............
    iCVS-Image-dm800-20090707
    Enigma = 07.07.2009
    Plugins = 07.07.2009
    Drivers/Modules = 07.07.2009
    Second Stage Bootloader = 73
    Kernel = 2.6.12-r13
    - Own iCVS bootlogo's by yvessun and HD / HD-Picon Skin by kerni
    - USB, USB HID, USB MON drivers in kernel
    - satellites.xml - enigma² by IhaD
    - incl. liba52 (only DM7025)
    - Smargo USB Cardreader support FTDI_SIO and PL2303
    - MHW EPG
    - .recordings patch
    - pmt.patch
    - AIO / Grab Screenshot
    - dccamd and wdog removed
    - the following softcams incl. startscripts which you can find in /usr/script/ can be installed via internet:
    * CCcamd
    * CCcamd incl. NewCS
    * CCcamd incl. MPCS
    * dccamd incl. wdog
    * Evocamd
    * Evocamd incl. NewCS
    * mbox
    * mbox incl. NewCS
    * MGcamd
    * MGcamd incl. NewCS
    * rqcamd
    * SCAM
    * Camd3
    * incubusCamd
    additionaly:
    * enigma2-plugin-icvs-userscripts
    * enigma2-plugin-icvs-nfs.server
    * enigma2-plugin-icvs-schaedelmeister.hd.settings.astra
    * enigma2-plugin-icvs-schaedelmeister.hd.settings.astra.hotbird
    * enigma2-plugin-icvs-schaedelmeister.settings.astra
    * enigma2-plugin-icvs-schaedelmeister.settings.astra.hotbird
    * enigma2-plugin-extensions-cccaminfo
    * enigma2-plugin-extensions-mediacenter
    * enigma2-plugin-extensions-pauli
    * enigma2-plugin-extensions-mediaplayerdeluxe
    * enigma2-plugin-extensions-permanentclock
    * enigma2-plugin-extensions-remotetv
    * enigma2-plugin-extensions-dreamexplorer
    * enigma2-plugin-extensions-webbrowser
    * enigma2-plugin-extensions-plugins2cf
    * enigma2-plugin-extensions-plugins2usb
    * enigma2-plugin-extensions-plugins2hdd
    * enigma2-plugin-extensions-logdscript
    * enigma2-plugin-extensions-swapscript
    * enigma2-plugin-systemplugins-satelliteeditor
    * enigma2-plugin-systemplugins-serviceeditor
    * HD Picon by ismail.demir
    * HD Picon 36E
    * enigma2-plugin-icvs-hd.picon.skyitalia by skywatcher
    * enigma2-plugin-icvs-hd.picon.kabeldeutschland by skywatcher
    * enigma2-plugin-icvs-hd.picon.astra3 by skywatcher
    * enigma2-plugin-skin-icvs by Kerni
    * enigma2-plugin-skin-dtv-hd
    * enigma2-plugin-skin-dreamtv-hd
    * enigma2-plugin-skin-kerni-hd1
    * enigma2-plugin-skin-nemesis.blackbox
    * enigma2-plugin-skin-nemesis.blueline
    * enigma2-plugin-skin-nemesis.blueline.extended
    * enigma2-plugin-skin-nemesis.blueline.single
    * enigma2-plugin-skin-nemesis.chromeline
    * enigma2-plugin-skin-nemesis.chromeline.cobolt
    * enigma2-plugin-skin-nemesis.flatline
    * enigma2-plugin-skin-nemesis.flatline.blue
    * enigma2-plugin-skin-nemesis.glassline
    * enigma2-plugin-skin-nemesis.greenline
    * enigma2-plugin-skin-nemesis.greenline.extended
    * enigma2-plugin-skin-nemesis.greenline.single
    * enigma2-plugin-skin-nemesis.greyline
    * enigma2-plugin-skin-nemesis.greyline.extended
    * enigma2-plugin-skin-nemesis.greyline.single
    * enigma2-plugin-skin-nemesis.shadowline
    Experimental (2.6) ist set aktive for Enigma, Plugins and skins. New git is also now active (please report problems related to this)
