Results 1 to 3 of 3
Thread: IPBOX 91 **NLB firmware**
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default IPBOX 91 **NLB firmware**
    Aici o sa gasiti firmware pt ipbox 91HD.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default NLB r8873 v.1.27 91HD
    NLB8873 fur CubeRevo-200HD/250HD/91HD
    CubeRevo nlb svn8873 v1.27
    for CubeRevo 200HD/250HD
    WEBIF
    login: root
    password: relook
    First time boot with Remote not working, is not fixed yet.. sorry!
    Reboot at lang screen and all is okay.
    Prepared by : Dexter
    Release date : January 22. 2009
    Changes:
    * updated - SVN8873 official from DGStation.
    * Added - newcs 1.65 with updated configs (added 357 mhz to all configs).
    * Added - nlbpanel 1.41 - now option to install pack.tar.gz from /tmp in panel.
    * plugins - updated bitrate 0.0.5, favpip 0.9.5
    * skins - deepblue update 3.5 (new livebanner) Thanks to @Crash
    * Fix - PANIC situation when DGS Webif is open on pc during bootup.
    * Changed - HDD Format of ext2 formatted usb/harddrive even if it was ok.
    * Updated - multiboot had some issue with usb sticks above 2GB.
    * Updated - multiboot install now works on boxes where usb is mounted as harddrive.
    * Fix - multiboot webif on port 81 was using old webif directory.
    * Changed - ECM info in webif now showing correct info again.
    * SVN --- - Recording problem with short HD recordings and 2hr stop fixed.
    * - DVBSubtitles color fix.
    * - Media player got FastForward/rewind on divx support now (not .VOB files).
    * - EPG Contents display changes
    * - blind scan - now default/advanced/reset scan.
    * - OSD Teletext - some data not update occassionally.
    * - Fixed local time auto update
    * - updated Polish language table
    * - WebIf updated
    http://www.upload-drive.com/7601/nlb8873-250_zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default NLB r9047 v1.29 91HD
    Abcom CubeRevo Series NLB svn9047(binaries) v1.29
    WEBIF
    login: root
    password: relook
    FIRST TIME BOOTSCREEN PANIC IS FINALLY FIXED!
    Release date : March 7. 2009
    Changes:
    * updated - SVN9047+ sbox+skin binaries +po files only.
    * plugins - updated favpip 2.1.0
    * plugins - updated hddtemp 0.0.7
    * plugins - all default in /var/plug-in again.
    * emu - mbox 0.4 beta 0023
    * webif - emu and newcs selection made simpler.
    * skins - deepblue and grey updated.
    * emu - EVOCAMD is no longer included in NLB image, no support for it.
    * cardreader- DGS Release had problems with Nagra3 cards. this one works.
    * DGS webif - updated Geckow webif to 1.3.1 (07.03.2009)
    Images for CubeRevo 250HD / IP 91HD
    nlb9047-250
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
