Reborn Neo 4.05
New sr4n_405.bin for Matrix Reborn Cam
Quote:Speedy Reborn 4 Neo for CAM Matrix Reborn
sr4n_405.bin - Full binary file for CAS2 interface programming
+++ SURVEY GUIDE +++
IF YOU LOCKED YOUR CAM PROGRAMMING WITH LAPTOP, CARDS OR SERIAL DEVICE:
Use CAS interface to recover it, this way:
Press "Erase all" button
You will get:
"erasing error on block 0"
"erasing error on block 1"
"erasing error on block 2"
After these three messages, press "ESC" and then "Erase all" again
When deleted, then you can normally program your cam
HISTORY
4.05
Added UK & Ireland nagra cable providers
4.04
Nagra3 smartcard (White Spanish D+ card) bug solved
4.03
ORF ok
4.02
Premiere improvements (problem for some channels fixed)
Added ORF N2
Added DigiTV
Updated keys
4.00b
Programming Neo 4.00 with laptop or cards can fail, so use only cas interface
4.00
Seca3 smartcard driver improvements (spanish blue card OK)
Nagra2-Nagra3 smartcard driver added (spanish nagra3 white card OK too)
Nagra1 boxkey menu changed to Nagra2-Nagra3 boxkey and key0D
Premiere OK (MECM 60)
Multicanal OK
Polsat OK
Updated keys (SRG,Premiere,Polsat,Multicanal)
Memory optimization
New math functions
Other
TROUBLESHOOTING
If you experience problems for some receivers decoding Premiere channels, follow these steps:
- Tune an FTA channel
- Switch off and on receiver
- Zap to a Premiere channel now
ENTERING KEYS
Go to Setup, edit CAS key for changing provider keys
Go to Setup, Nagra2 Boxkey and Key0D for changing your nagra2 or nagra3 card data
(first 8 Bytes are boxkey, next 24 Bytes are Key0D)
You can use the attached bk_convert tool for converting hexadecimal numbers (2 digits) to
decimal numbers (3 digits)
Edit the key.bin file (using the XVI32 tool) with your hex key and then run bk_convert
For detailed information read the nagra3_smartcard_howto.txt file
http://www.mediafire.com/?bwvgvgvkxz1
