Dislikes:
- 58
Imagine noua pt dreambox
Sattv-forum image is now Evolution 2.0 Image we change domain to www.satkeynet.com
Evolution 2.0 Change log
DM500/DM56X0/DM7000/IPBox200S/IPBOX250S
Technical Infos:
CVS Version: 12.10 2008
Linux kernel version: 2.6.9
GCC 3.4.4 Original CVS
Web Inteface 6.0.4-Expert
Busybox 1.01
BLUE - Blue Panel (Emu Addons)
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Download Addons - Emus,keys,Plugins,Setting....
Manual Install Addons tar.bz2
Delite Addons
Removed ebrowser
Removed 1sec ecm.info
Add Backup Manager (make var backup install var backup)
Add new satellites.xml latest update
Add Infobar Adjust
Add Exrta Setting disable enable option
Add Disable EPG Caching (Important for ipbox200 disable this option for free memory)
Add Support for Ptest Plugin (need new skin)
Add ezap_main faild recovery
Add ecm.info in Blue panel
Add move var manager
Fix bugs on skin
Fix bug crash when try to recording (now works)
Fix bug when change Emu (now starting emu faster)
Fix crash when try mount on ipbox
And more..............
IPBox200S:
Last Kernel: 2.6.17 (Thanks to Sandali)
U-Boot: 1.2.0 (Thanks to Sandali)
New driver from sandali
IPBox200S mID 20
IPBox250S:
IPBox250S mID 25
IPBox login:
user:root
password:ipbox
Thanks for testing ohem2000 and dzoni
Support: www.satkeynet.com
This image doesn't include keys or emulators.
satkeynet is not responsible any damage caused by this software.
- 66
Re: Imagine noua pt dreambox
E veche . Asta e cea mai noua
Dreambox Evolution 2.1
Evolution 2.1 Change log
DM500 DM56X0 DM7000 IPBox200S IPBOX250S IPBOX400
Technical Infos:
CVS Version: 05.03 2009
Busybox 1.01
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Delite Addons
-------- New in Evolution 2.1------------
Add USB Manager
Add User script
Add Show EPG in Infobar from EPG-Cache
Add Gbox/Cccam/Mbox/Mgcamd/Evocamd info in infobar (decode,dns,hops,ecm time,dist,level,peers,cards,caid,pid,provid)
Add crond,crondtab
Small change in blue panel add icons in settings option
Small changes in epg
Fix libc.so.6
Fix emu start up
Fix some bugs with not working plugins on Evolution 2.0
Change Dark Center skin for more osd information
New satellites.xml with latest TP-s
New feeds for news reader(you can add you own feeds var/etc feeds.xml)
And more...................
Many new stuff in cvs.......
Max var image
- 66
- 58
Am facut o mica eroare ,in loc de imaginea recenta am postat una mai veche si imi cer scuze, dar daca cineva se uita mai atent ambele imagini sunt postate alaturat pe acel site.Inca o data mii de scuze.
