Likes Likes:  3
Results 1 to 2 of 2
Thread: RTL-SDR with Enigma2 by SatDreramGr team
    Thumbs up RTL-SDR with Enigma2 by SatDreramGr team
    Our experimental images include a new plugin that converts Enigma2 into an FM radio receiver with the help of RTL-SDR project and one supported usb stick
    Button Usage:
    0 .. 9: you can choose the favorites button.
    up / down: you can increase / decrease the frequency with step 0.1 MHz
    left / right: you can increase / decrease the frequency with step 1 MHz
    OK: you can tune to new frequency
    Red: closes plugin
    Green: can save the frequency on selected position (0..9)
    Blue: displays the last messages from rtl_fm program
    Info: displays rtl_eeprom tuner info, you need to retune after using info
    Enjoy SatDreamGr Team!
    PS. For supported devices have a look here:
    http://sdr.osmocom.org/trac/wiki/rtl-sdr
    A short video link of this plugin working near Atlanta, Ga. U.S.A.
    (About 100MB download)
    https://mega.nz/#!Cp8CFCCT!ySrNar_Na...aov1Sc4Ex2sB80
    Astrometa T2/C works for sure on newer kernel (like Edision) using a small trick. The T part should be working with RTL driver, even on VU+.
    You can not use stick for TV and FM at the same time. TV uses kernel drivers, FM uses libusb without kernel drivers.
    There is a kernel module in new kernel (again Edision can have it since it follows kernel releases), that uses FM with a kernel module and TV is possible, we might enable it for supported boxes.
    A short video showing 162.4 and 162.425 NOAA reception. (VHF band, FM Narrow Mode)
    https://mega.nz/#!WtViVRzD!JN3QlMjLX...kMFqVR4JxXO5Rs
    I created a new branch dev, where we can test new features before merge into master.
    https://github.com/satdreamgr/SDGradio/tree/dev
    Here is the full file: https://raw.githubusercontent.com/sa...ugin/plugin.py
    https://github.com/satdreamgr/SDGRadio
