Thanks Thanks:  45
Likes Likes:  54
Page 9 of 11 FirstFirst ... 567891011 LastLast
Results 121 to 135 of 154
Thread: AltDVB
  1. #121
    bine ai revenit prietene drag ......sa faci ALTDVB cum sti t mai bine....deh a fost si ramane prima iubire
    LA MULTI ANI!!!!!!!!!!!!!!!!!
  2. #122
    17 Jan 2008
    O veste buna pentru inceputul de an. Multumesc.
  3. #123
    Thumbs up AltDVB version v2.3 (2020-01-04)
    AltDVB version v2.3
    v2.3 (2020-01-04)
    Application:
    – added support for HEVC
    – added support for AAC,AAC-LATM and EAC3
    – added support for EVR – Enhanced Video Renderer
    – experimental built-in support for PLS and MIS.Currently only for TBS devices using my Dev_BdaDriver.int.
    – simplified directshow config
    – portable: doesn’t use registry to store settings, run as standard user (without admin rights)
    – new version of DvbAvSrc.ax, used directly, does NOT need to be registered in the system using regsvr32.exe
    – added support for “internal” directshow decoders (only LAV filters, for now)
    – some optimization in TS packets demuxer & A/V stream path
    – removed some unused/obsolete features (SDX files & coverage images,…)
    – new directory structure.(files from dir. [SatFiles] moved to \Channels, \Configs, \Transponders)
    – new file format for channel list.
    – new file format for transponders with saving informations about signal
    – channel search by name moved above list
    – new options for better filtering channel list
    – introduced kHz precision for frequencies
    – external config file for CA names
    – added more MODCODE’s and Roll-off values
    – fixed a lot of bugs, added new ones 🙂
    Old Non-BDA interfaces:
    * New: Dev_TTBudget.dll
    – need drv. 2.19h (28.11.2006)
    – you have to copy “ttlcdacc.dll” (ver. >= 2.19.8.1) into ..\AltDvb\Devices\
    – tested with S2-3200
    * Dev_SkyStar2:
    – fixed DiSEqC command when using driver >= 4.4.0
    – built without VCL
    https://www.mediafire.com/file/4xpyz...B5220.zip/file
  4. #124
    17 Jan 2008
    In sfarsit, anuntat de 4 ani a aparut . Multumim.
    Testat pe cablu, merge foarte bine.
    Nu am gasit cum sa activez subtitrarea dvb, daca se poate.
  5. #125
    45 Post(s)
    @marcghi - Nu cred sa aiba subtitrare in aplicatia originala. Versiunile anterioare nu aveau, eu nu am gasit nici in 2.3.
  6. #126
    Nu reusesc sa gasesc tutorialul colegiului Staric referitor la subtitrarile dvb pe AltDVB + VLC.
  7. #127
    Din păcate nu, tin minte ca vizionarea se făcea prin VLC.
  9. #129
    Quote Originally Posted by marcghi View Post
    Cum ai testat pe cablu?
  10. #130
    17 Jan 2008
    Cu un DVB-T2/DVB-C/FM/DAB (https://www.aliexpress.com/item/1762...37b92e0eLswucy) + vplug + softcam + cablu gigi.
    Pe programele care au subtitrare dvb -ex. FilmAcum
    La asta te refereai ? nu prea e clar ce vrei sa afli.
  11. #131
    Nu stiam ce tuner ai!
    Deci sa inteleg ca merge cu Astrometa !
    Multumesc de raspuns!
  12. #132
    45 Post(s)
    Alt-Dvb 2.3
    PowerVuEmu este cu Softcam-ul cu key-le actualizate, AltDvb 2.3 le vede dar nu face lumina!
    Pe softuri alternative, cum ar fi fi SmartDvb acelasi softcam este luminat, am folosit aceeasi aceasi versiune PowrVuEmu si acelasi softcam pe ambele.
    Pe Smart Dvb se deschide, pe altdvb este citit si vazut dar nu deschide
    Unde ar fi problema?
  13. #133
    13 Dec 2015
    Cluj-Napoca
    Alt-Dvb 2.3
    Salut !
    Problema este la AltDVB: plugin-ul decripteaza streamul dar pachetele decriptate nu sunt folosite de engine-ul intern. Cand l-am optimizat pentru FFDeCSA nu credeam ca o sa se inventeze plugin-uri care fac singure decriptarea
    O sa incerc sa rezolv problema in urmatoarea versiune !
  14. #134
    45 Post(s)
    Plecand de la sugestia ca ar fi posibil subtitrare ALTDVB+VLC, am gasit urmatoarea modalitate:
    1)Se deschide functia record
    2)Se selecteaza modul AV0
    3)Se bifeaza subtitrarile dorite si pistele audio dorite.
    Obligatoriu se activeaza PAT iar PMT ramane activat
    4)Se apasa record, apoi se merge in folderul definit: AltDvb/Records.
    5)Se deschide cu VLC fisierul respectiv, apoi se selecteaza subtitrarea si pista audio dorita.
    Pe timpul vizionarii nu se opreste AltDvb si functia Record.
    Va fi un mic delay, mai mare sau mai mic in functia de intarzierea cu care se deschide VLC de la inceperea opertiei.
    Sunetul pe AltDvb va fi dat la minim pentru a nu se acoperi cu sunetul VLC
    Se poate incerca si cu alte playere, nu doar VLC
  15. #135
    02 Jun 2008
    Timisoara, Banat
    Va salut,
    Am cateva probleme cu ultima versiune. De ce dupa scanare ( satelit), nu-mi pastreaza lista de canale ? Faptul ca nu am imagine video dupa scanare tine probabil de configurarea codec-urilor ?
    Multumesc
    ---------- Post added at 16:52 ---------- Previous post was at 16:41 ----------
    Prima parte am rezolvat-o. Scuze, eu nu am fost atent, lipsa de exercitiu.
