Results 1 to 15 of 15
Thread: PLi? Jade3 Enigma1 images released
    20 Mar 2009
    Iasi
    Default PLi® Jade3 Enigma1 images released
    dupa cum spune titlul, imagine noua de la Pli Jade lansata ieri!
    Azi, testam :-)
    New features highlights:
    - Fixed MediaHighway EPG for Dutch 'Canal Digitaal' and Belgium 'TV Vlaanderen' provider
    - Improved movieplayer
    More new features:
    - CVS Repository 31/05/2009
    - PLi® Repository 14/06/2009
    - CCcam updated to version 2.1.1 for normal DM500 image and DM56x0 image
    - MultiEPG channelnames are scaled too, just as the program name
    - Turkish and Dutch translations updated
    - Removed LAN selection box in network setup
    - The global (all satellites worldwide) satellites.xml updated 15/06/2009 (DVB-S: FEC = Automatic; DVB-S2: FEC = Normal)
    Fixes:
    Languages:
    - Dutch language update by dAF2000
    - Turkish language update by Kerem
    Known bugs:
    - There is maybe some rotor related bug in the Open Embedded boxes like the DM7020, DM600 and DM500Plus images.
    * An online internet fix for the rotor users will be released soon.
    - Picons may not work if a satellite has both Ku and C band channels
    O zi frumoasa! Snow's Avatar
    Default Re: PLi® Jade3 Enigma1 images released
    si un link de download?
    38 Post(s)
    PLi® Jade3 DM500MV
    DOWNLOAD
    38 Post(s)
    O alternativa la linkul de mai sus pentru ca am vazut ca sunt probleme cu rapidshare:
    PLi® Jade3 DM500MV
    DOWNLOAD
    Member Addicted Member
    11 Feb 2007
    Șoseaua Kiseleff nr. 10
    Nu inteleg de ce va complicati cu rapidshare si alte situri cand puteti sa-l luati direct de la sursa.
    http://www.pli-images.org
    38 Post(s)
    A testat cineva aceasta imagine?...ca pe forumul pli-images au scos-o de la upload pe motiv ca nu ar merge cccam instalat.
    14 Feb 2007
    Am pus aceasta imagine pe DM, dupa instalare am sters lista cu sateliti inclusi in imagine si am lasat doar satelitii pe care ii receptionez, am pus doar CCcam 2.1.1 din BP cu key aferente, configurarile specifice in var/etc iar ca skin am instalat X Line tot din BP, in acest fel imi arata /var used 53% . Imaginea se misca destul de bine la prima vedere, citeste fara probleme cardul nds mioritic iar in share vad ca merge in mod obisnuit. In cele cateva ore de la instalare nu am avut probleme iar in comparatie cu Jade2 MaxVar pare ca se misca ceva mai bine. Cam astea ar fi primele impresii despre aceasta imagine, in rest totul este incadrat in standardele cu care ne-a obisnuit PLI.
    20 Mar 2009
    Iasi
    Cand am postat anuntul ca a aparut acesta imagine, am fugit acasa dupa job si da-i la instalare.
    Mi-au trebuit 3 incercari (flasuiri) sa o pot face sa mearga si cand a mers nu se putea conecta la server sa iau add-onuri. am incercat sa instalez manual cccam si nu a pornit de loc.
    Presat de timp, am repus un backup mai vechi si m-am lastat pagubas.
    Deocamdata sunt rezervat sa spun ca merge, (desi Pli "rules" ), mai incerc in weekend.
    14 Feb 2007
    La mine a mers din prima si vad ca nu sunt probleme si inca ruleaza fara cusur. Incearca sa o instalezi prin null modem si nu o incarca la inceput decat cu ceea ce ai nevoie pt a avea totusi spatiu in var.
    Si eu am avut probleme cu versiunea anterioara Jade2 tot de la MaxVar. Probabil ca exista inca bug-uri la versiunea MaxVar pt ca nu degeaba au retras-o de la download la sectiunea DM500, dar sa speram ca vor fi rezolvate cat mai curand.
    14 Feb 2007
    Default Re: PLi® Jade3 Enigma1 DM500 revizuita
    A new Enigma1 PLi® Dreambox release is available for download.
    PLi® Images [27-06-2009] ALL Enigma1 images are updated, the DM500 Softcam and the Harddisk detection problems are fixed!
    Therefore we decided to update all boxtype to the same new revision, 6494.
    PLi® Jade3 MaxVar - for the Dreambox DM500
    PLi® Jade3 - for the Dreambox DM500
    09 Jun 2007
    Transylvania
    Salut.Am instalat si eu.Cu care skin se vede de la cine primesc cartela cu CCcam?Am probat cateva , dar cu nici una nu vrea sa-mi arate.Extra OSD-ul este activat.
    20 Mar 2009
    Iasi
    salut, incearca Xline
    11 Feb 2007
    O imagine care se misca mult prea greu. Am facut efortul de a o instala, dar nu merita. Am testat cu gbox si diseq cu 7 sateliti. Gemini ramane cea mai stabila dupa parerea mea. Am avut 22 de zile cand nu am restartat receptorul. Si atunci datorita unei pene de curent.
    18 Jul 2009
    Default super
    super imagine pli e un picut mai complicata dar fata de altele are un plus la viteza si nu se blocheaza des
    23 Apr 2007
    P3X-888
    ce descoperire ... te-ai gandit tu sa aduci la lumina acest topic uitat de doi ani
