G este linia pentru mbox.
Orice emulator deschide orice vrei tu, cu anumite conditii Citeste pe la sectiunea coltul pufanului chestiile de baza ale card sharing.
G ??????
ce linie este?
@gobi, am gasit treaba de mai jos pe mai multe forumuri. Tu stiu ca folosesti CCcam si poate te ajuta cu ceva:
CCcam can recieve all cards from Gbox but, Gbox can only recieve Gbox cards from CCcam server.If CCcam is connected to more than 1 Gbox server. Gbox will recieve all Gbox cards on same hop as CCcam recieves.
Gline to be added in CCcam server
Dline to be added in Gbox server as normal
syntax:
G: ABCD1234 192.168.1.10 7000 4321DCBA otherperson.dyndns.org 8000
ABCD1234 = your own password
192.168.1.10 = your IP
7000 = Your own port for sharing
4321DCBA = Servers password
otherperson.dyndns.org = The gbox server dns
8000 = The gbox server port
GboxA <---> CCCam <---> GboxB
GboxB can see card from GboxA and Vice versa.
You cant use a D line on CCcam.cfg
For connect cccam to gbox you must use G line in cccam and d line in gbox
in cccam
G: AABBCCDD cccamdyndns cccamport 12345678 gboxdyndns gboxport
in gbox
cwshare.cfg
M: { gboxdyndns { 12345678 }}
D: { cccamdyndns { gboxport cccamport { AABBCCDD { A3 A3 }}}}
No @zmeura ia zi daca dau in mbox card sky card sky2 card tvr linie CCcam
asta ar insemna ca pot rula mbox si atat? pot linie newcs?
traduce cineva !?
REGULA 12
Nu intelegi? sau nu ai inteles?
adevarul ca nu prea ai explicat tu bine exact ce vrei sa faci
linile G se faceau in cccam pentru a vedea carduri si din gbox sau mbox
exact cum s-a scris mai sus
G-line adaugata in CCcam server
D-line adaugata in Gbox server normal
syntaxa :
G: ABCD1234 192.168.1.10 12000 4321DCBA host.dyndns.org 8000
G: parola ta host cccam (sau Ip receptorului) port cccam parola gbox hostul de gbox portul de gbox
nici una , nici alta
dar
si una , si alta
- ai cam in care vrei sa dai o linie ( newcamd / gbox / cccam ) ?
asta se poate cu diablo wifi sau daca renunti la cccam poti cu wireless
- ai keys de cer si nu sti ce emu le foloseste ?
niciunul
- pe ce vrei sa rulezi cardserverul ?
- nu cred ca poti folosi linie cccam in mbox ( invers da insa conditionat )
eu insa banuiesc ca ai un server cccam si vrei sa adaogi o linie G
Pai normal ca suntem in ceata.E postat la sectiunea Cam-uri,intrebarea din titlu e" Ce emulator deschide aceste key? S*Y ?? " si vorbim despre o linie G fara sa stie nimeni despre ce e vorba.Puzzle e putin spus.
Code:SKY ITALIA Hotbird 13E FOR TEST ONLY Provider : 0919 1st Index: 00 2nd index key 00 : 194D42463D8C4679 2nd index key 10 : D9D235A645DF7E6F G 0919 00 00 0919 00 00 194D42463D8C4679D9D235A645DF7E6F G 0919 00 01 0919 00 01 AF2F16ACFDEEFA496D3DE50B11E56B86 G 0919 00 02 0919 00 02 E59C6000EF33D453C1544D6F96269520 G 0919 00 03 0919 00 03 EB53A24EF747E1CA1E52BD1E54A1AACA G 0919 00 04 0919 00 04 78B28B7051A1F5DF542DE0D89942152F G 0919 00 05 0919 00 05 E1C512D4207A516AE5151E4A4FDA8187 G 0919 00 06 0919 00 06 2049427283A99F700C5B951FFC733AEF G 0919 01 2C 72D8ED821C44 ;Emu 001x02C G 0919 A1 D9 99392B349069 ;Emu 0A1x0D9 G 0919 D1 B0 98638A9586CB ;Card AU Hash (anaimgr key) G 0919 81 5D 00A56449B399 ;Card AU Hash G 0919 C1 A7 C8EE39A0F4F3 ;C1xA7xFF Hash G 0919 51 F1 860F36DCDCB2 ;51xF1xFF Hash G 0919 E0 00 81FB1D8EF2EA0D3A73C31C8FDCA318D5 ;EMM Generated G 0919 E1 06 5A76047736FD039742CE549E511AA33A ;ECM Generated G 0919 F0 00 D40C9728FD211DC1267E88CE9683DD37 ;EMM Hash G 0919 F1 06 76D960B05795DBE0B64FEA0FC5CD149B ;ECM Hash
Deci astea sunt tot ptr Gbox sau mbox?
Nuuu,alea sunt povesti de adormit copii.
Deci asta era intrebarea straniu si ptr mn ptr ca , nu am vz lini "G" cu k*y desi 0b 00 00 sunt active in cardul 0919 dar nu sunt cuprinse in aceste k*y
ok tinere prea putini inteleg ce-a ce frei sa spui dar de metoda asta de criptare sincer nu am auzit .......G......vad ca ai lansat si key cel care lea lansat e un adevarat pacalici nu te mai lua dupa vorbe ..ori cum te apreciez pentru efortul depus
Nustiu ce a-i intele!? eu am avut o dilema legata de linia "G"
