Thanks Thanks:  51
Likes Likes:  20
Page 1 of 81 123451151 ... LastLast
Results 1 to 15 of 1201
Thread: OSCAM file
    23 Apr 2007
    P3X-888
    Default OSCAM file
    in aceast topic se vor posta doar arhive ale noilor versiuni de oscam si comentarii despre ce probleme sunt rezolvate de fiecare versiune nou aparuta orice alte comentarii sau intrebari vor fi sterse .
    va multumesc
    11 Apr 2008
    Fost mebru
    Post
    O mică completare pentru a şti de care versiune aveţi nevoie :
    - powerpc-tuxbox-smartreader = DM500, DM500+, DM600, DM7000, DM7020 compatible STBs with usb for smartreader
    - powerpc-tuxbox-without_smartreader = DM500, DM500+, DM600, DM7000, DM7020
    - mips-tuxbox = DM500HD, DM800, DM7025, DM8000
    - sh4-amino = IPBOX 9000 HD, IPBOX 910 HD, IPBOX 91 HD, Kathrein UFS 910
    - i686-pc-linux = 32 Bit Linux PC
    - x86_64-pc-linux = 64 Bit Linux PC
    - openwrt-little_endian-kernel24 = OpenWRT Router with Kernel 2.4.x
    - openwrt-little_endian-kernel26 = OpenWRT Router with Kernel 2.6.x
    - arm-coolstream = CoolstreamHD1
    - arm-nslu2-openwrt = OpenWRT Linksys NSLU2
    - arm-nslu2-unslung = Unslung Linksys NSLU2
    - dbox2-tuxbox = Dbox2
    - mips-fonera2 = La Fonera Router
    - mips-freetz = Fritzbox Router
    - tripledragon = Triple Dragon
    23 Apr 2007
    P3X-888
    r2954 | rorothetroll | 2010-08-26 14:48:14 -0700 (Thu, 26 Aug 2010) | 1 line
    fixes for the utils/CMakeLists.txt for Dockstar platform
    r2953 | rorothetroll | 2010-08-25 10:11:44 -0700 (Wed, 25 Aug 2010) | 1 line
    added Seagate FreeAgent DockStar support. thanks Robby
    oscam-svn2954-full-Distribution
    29 Mar 2009
    Austria - TM
    Default oscam-svn2955-full-Distribution
    r2955 | polo | 2010-08-27 03:15:01 -0700 (Fri, 27 Aug 2010) | 4 lines
    - Add 'reread' command in monitor to reload entitlements
    - Improve logging message
    oscam-
    webif is on all versions included
    dvb-api is on all dvb-api stbs included like dreambox and sh4 stbs with enigma2, also availble on azbox (openxcas)
    smartreader support is included in all versions except on 'without_smartreader' versions in filename
    azbox version can be installed by copying Camd.tgz to /tmp and installing from the plugins menu
    23 Apr 2007
    P3X-888
    Changeset #2955:
    Timestamp: 08/27/2010 12:15:01 PM (less than one hour ago)
    Author: polo
    Message: - Add 'reread' command in monitor to reload entitlements
    Changeset #2956: | schlocke | 2010-08-27 09:40:40 -0700 (Fri, 27 Aug 2010) | 2 lines
    cccam: loadbalancer: Fallback is now secondbest reader
    Changeset #2957:
    Timestamp: 08/27/2010 11:19:58 PM
    Author: alno
    Message: Commit patch from manio related Ticket #739 (separate DES Key configurable for each newcamd port) THX
    !!! No WebIf support yet !!!
    Changeset #2958:
    Timestamp: 08/28/2010 07:25:59 AM
    Author: landlord
    Message: Documentation for multiple newcamd DES keys.
    Changeset #2959:
    Timestamp: 08/28/2010 08:29:35 AM
    Author: alno
    Message: WebIf: add separate (per port) DES key config support
    oscam-svn2959-full-Distribution
    14 Feb 2007
    Oscam-svn2965-full-Distribution
    r2965 | cogsi | 2010-08-29 00:28:52 -0700 (Sun, 29 Aug 2010) | 1 line
    nds: fixed skyit 9cd atr detection and more cosmetics
    r2964 | cogsi | 2010-08-29 00:27:02 -0700 (Sun, 29 Aug 2010) | 1 line
    nds: removed old sky uk atr and other cosmetic changes
    r2963 | cogsi | 2010-08-29 00:24:07 -0700 (Sun, 29 Aug 2010) | 1 line
    nds: added skyit 9cd atr (thanks .:foggy:.) and other cosmetic changes
    r2962 | cogsi | 2010-08-29 00:17:51 -0700 (Sun, 29 Aug 2010) | 1 line
    updated SkyIt tiers table
    oscam-svn2965-full-Distribution
    Default 2 fisiere lipsa
    In arhiva in version.txt zice:
    available versions:
    - oscam-svnX-arm-coolstream CoolstreamHD1
    - oscam-svnX-arm-nslu2-openwrt OpenWRT Linksys NSLU2
    - oscam-svnX-arm-nslu2-unslung Unslung Linksys NSLU2
    - oscam-svnX-dbox2-tuxbox Dbox2
    - oscam-svnX-i686-pc-linux 32 Bit Linux PC
    - oscam-svnX-x86_64-pc-linux 64 Bit Linux PC
    - oscam-svnX-mips-azbox AZBox HD
    - oscam-svnX-mips-fonera2 La Fonera Router
    - oscam-svnX-mips-freetz Fritzbox Router
    - oscam-svnX-mips-tuxbox DM500HD, DM800, DM7025, DM8000
    - oscam-svnX-openwrt-little_endian-kernel24 OpenWRT Router with Kernel 2.4.x
    - oscam-svnX-openwrt-little_endian-kernel26 OpenWRT Router with Kernel 2.6.x
    - oscam-svnX-powerpc-tuxbox-smartreader DM500, DM500+, DM600, DM7000, DM7020 compatible STBs with usb for smartreader
    - oscam-svnX-powerpc-tuxbox-without_smartreader DM500, DM500+, DM600, DM7000, DM7020
    - oscam-svnX-sh4-amino IPBOX 9000 HD, IPBOX 910 HD, IPBOX 91 HD, Kathrein UFS 910
    - oscam-svnX-tripledragon Triple Dragon
    dar
    nu este
    Exact de asta am nevoie. Daca stie cineva de existenta lui il rog sa-mi zica si mie.
    Multumesc
    01 Feb 2008
    oscam-svnX-i686-pc-linux (32 Bit Linux PC) se compileaza
    (Cross-) compiling
    Linux i686 or x86_64:
    Step 1:
    Make sure you have a current make (debian package: build-essential) and cmake version (>= 2.6) installed. You furthermore need gcc, svn (debian package: subversion), libusb-dev and openssl (debian package: libssl-dev) installed. Consult the handbook of your linux distribution on how to install them if they are missing. Debian and Ubuntu for example uses "sudo apt-get install <package>" or "sudo aptitude install <package>".
    Step 2:
    Download source repository
    svn co http://streamboard.gmc.to/svn/oscam/trunk oscam-svn
    Step 3:
    Just do
    cd oscam-svn
    mkdir build
    cd build
    cmake ..
    make
    Binary output will be located in the folder where you are (oscam-svn/build). If you get any compilation errors, search our forum for similar issues. If you don't find a solution, then open a new thread there (do NOT open a ticket!).
    Fritzbox / DD-WRT Router / Dreambox / NSLU2:
    All provided toolchains will only work in a Linux-based environment.
    Step 1:
    Before you can start to compile OSCam for any platform, you need to get the right toolchain. Copy the toolchain to your Linux-based system. cmake 2.4 or higher will be needed.
    Step 2:
    Step 3:
    Create a build directory in oscam-svn
    cd oscam-svn
    mkdir build_dir
    cd build_dir
    Step 4
    Create a shell script in the directory build_dir
    vi install.sh
    #!/bin/sh
    export MYPATH=$PATH
    export PATH=/toolchain/ANYPLATFORM/bin:$MYPATH
    make clean
    cmake -DCMAKE_TOOLCHAIN_FILE=../toolchains/toolchain-ANYPLATFORM.cmake ..
    make
    chmod 755 install.sh
    Remember to set the toolchain path correctly. Also take a look inside the toolchain cmake script. You have to add the right compiler for your platform.
    Step 5
    Execute the shell script
    ./install.sh
    The output will be located in the build_dir
    sursa: oscam wiki
    succesuri!
    23 Apr 2007
    P3X-888
    Changeset [2975] by schlocke
    loadbalancer: caid-filter checks original caid
    Changeset [2974] by schlocke
    cccam: fixed client signal 11 on NOK
    Changeset [2973] by schlocke
    loadbalancer: modified handling of reader-errors and softblocks cccam: …
    Changeset [2972] by rorothetroll
    added sky NZ atr
    Changeset [2971] by schlocke
    loadbalancer: finer specifying of errors
    Changeset [2970] by schlocke
    cientdyndns=1 : fixed signal 11 error
    Changeset [2969] by schlocke
    cccam: fixed card loosing
    Changeset [2968] by landlord
    Removed 'cccforceresendecm' from documentation.
    Changeset [2967] by schlocke
    cccam: fixed timeout-handling
    Changeset [2966] by cogsi
    oscam.tiers file now availble to define tier names (videoguard-only for …
    oscam-svn2975-full-Distribution
    ---------- Post added at 21:30 ---------- Previous post was at 21:25 ----------
    dar
    nu este
    Multumesc
    oscam-0.99.4-SB-svn2975-i686-pc-linux-trunk
    oscam-0.99.4-SB-svn2975-i686-pc-linux-trunk-webif
    sper sa-ti fie de ajutor
    Default Multumiri
    Multe multumiri Stargate si celorlalti colegi. Merge
    Ma luptam cu sursa de vreo ora si nu o dovedisem, ba ca n-are una ba alta....
    Poate cu asta pacalesc si eu cardul ala irdeto care ma freaca de ceva timp
    PS Primele bancuri de acum incolo le postez in cinstea ta.
    04 Jan 2010
    Default svn 2980 full
    http://www.easysurf.ro/vrv8utq3zs7w/...ion.tar.gz.htm
    Changes :------------------------------------------------------------------------
    r2980 | rorothetroll | 2010-09-03 10:33:50 -0700 (Fri, 03 Sep 2010) | 1 line
    new patch to save emm even if we block them
    r2979 | rorothetroll | 2010-09-02 18:56:50 -0700 (Thu, 02 Sep 2010) | 1 line
    added atr for NDS NZ card. Thank you rebdog
    29 Mar 2009
    Austria - TM
    Default oscam-0.99.4-SB-svn3001
    Changeset #3000:
    Timestamp: 09/06/2010 09:28:20 PM
    Author: schlocke
    Message: cccam: caid-filter fix, cccam-server: update_interval parameter in
    seconds when to renew share list to the client
    Changeset #3001:
    Timestamp: 09/06/2010 09:55:09 PM
    Author: landlord
    Message: Documentation for new parameter 'updateinterval'.
    build #3001 from trunk, with pcsc support & webif:
    build #3001 from trunk, with pcsc support (no webif):
    29 Nov 2008
    Cu capu' in nori
    Default oscam-0.99.4-SB-svn3005
    Changeset #3005:
    Timestamp: 09/07/2010 01:24:22 PM
    Author: schlocke
    Message: cccam: fixed au on first reader
    Oscam-0.99.4-SB-svn3005
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-0.99.4-SB-svn3009
    Changeset #3008:
    Timestamp: 09/07/2010 09:59:45 PM
    Author: schlocke
    Message: cccam: reshare-hop in log fixed
    cccam: reshare-list filtered by services
    Changeset #3009:
    Timestamp: 09/07/2010 10:01:22 PM
    Author: alno
    Message: Oscam client -> Oscam Server via camd35 protocol: show transmitted auprovid (to client) in Log on serverside (CMD05)
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-0.99.4-SB-svn3017
    Changeset #3010:
    Timestamp: 09/08/2010 06:12:34 PM
    Author: schlocke
    Message: cccam: sharelist-updateinval: "interval unknown"-fixed
    cccam: reader-restart-time: Fixed if zero
    Changeset #3011:
    Timestamp: 09/08/2010 07:44:06 PM
    Author: alno
    Message: some whitespaces to make irdeto code more readable - no functional changes
    Changeset #3012:
    Timestamp: 09/08/2010 09:08:06 PM
    Author: rorothetroll
    Message: more adjustment for irdeto chid entitlement date
    Changeset #3013:
    Timestamp: 09/08/2010 09:12:25 PM
    Message: fixed a typo
    Changeset #3014:
    Timestamp: 09/08/2010 09:43:01 PM
    Message: revert my changes as it fixes some chid date for some card but it show bad dates for other ones (s02)
    Changeset #3015:
    Timestamp: 09/08/2010 10:58:03 PM
    Author: schlocke
    Message: dyndns/resolver: new option "resolvegethostbyname=0|1"
    Changeset #3016:
    Timestamp: 09/08/2010 11:14:27 PM
    Author: schlocke
    Message: resolver-thread: possible issue missing parameters
    Changeset #3017:
    Timestamp: 09/08/2010 11:37:41 PM
    Author: schlocke
    Message: resolve/dyndns: fixed gethostbyname
    Oscam-0.99.4-SB-svn3017 Download
